14
I was wondering, what is the method (or the methods) that linguists adopt to understand and know the etymology of a word?
Are these methods reliable and in what measure?
The knowledge I have on the matter is not that deep so I wanted to know exactly what happens "behind" that Origin entry in my dictionary.
Alenanno
  • 9,388
  • 48
  • 80
  • Sorry for my English, I speak Spanish. Instead of linguistics, philology is the one responsible to corroborate, establish or determine the etymology of words, to be exact –  Jan 17 '12 at 21:28
As you can probably guess, there are several ways to determine the etymology of words. Probably the most reliable is to look at the genetic relationships between languages - i.e. we know that a word comes from Latin or Greek because it is preserved in a similar form across several modern languages, and we have historical documents in the original language that also use this word (or a very similar form).
Often, a historical phonological process such as I-mutation (umlaut) is observed for a group of words, which can help to prove that they came from the same language.
The etymology of a word becomes more speculative the further back we go - we can be pretty sure that a word came from Sanskrit, Arabic, Latin, or Greek, because these languages are (relatively) modern and well-documented. However, determining which proto-language a word is descended from can be more controversial.
In summary, historical documentation and phonological similarity are the two main ways to determine a word's etymology.
hippietrail
  • 14,687
  • 146
chokamp
  • 124
  • Thanks for the answer! :) Sorry for the late feedback. I have a side-question: Are there particular "schemes" that linguists follow to search an etymology? I mean, some phases that can increase the chances of success, or they just start from a point and start investigating from there? – Alenanno Feb 09 '12 at 11:44
Most English words have roots in Indo-European, either through original Germanic or through borrowed Latin, French, or Greek words. For all of the 19th Century, every linguist in the world (which principally meant Europe, in this case) was busily engaged in bringing Ordnung to the prehistory of the Indo-European languages.
In the century since, this immense scholarly undertaking has been codified and turned into individual etymologies, which are normally looked up in a principal source, like Pokorny's Indo-European Etymological Dictionary. To make sense of these, you need some linguistic training.
There are secondary sources available that skip a lot of details but still do the job.
  • Buck's monumental Dictionary of Selected Synonyms in the Principal Indo-European Languages: A Contribution to the History of Ideas is now available in paperback. It's organized like a thesaurus, in 21 chapters by topic (4. Parts of the Body; 8. Agriculture, Vegetation; 15. Sense Perception), and in each chapter about a hundred or two ideas -- like head (4.20), rose (8.58), restore (11.23), or good smelling, fragrant (15.25) -- are given with a list of synonyms and a discussion of the roots involved and the history of the words and concept in different languages. This is a fascinating book to dip into anywhere; Buck really meant his subtitle -- the first sentence in his Preface is "How do we get our ideas?"
  • Watkins' American Heritage Dictionary of Indo-European Roots was compiled specifically for the words in the unabridged American Heritage dictionary, but they cite Pokorny and have illustrative examples.
jlawler
  • 10,042
  • 55
    This seems to answer more how an everyday person would find the etymology when the etymology is known (or suspected), not how these linguists discovered the etymologies in the first place. – Muke Tever Jan 14 '12 at 18:01
    The 19th Century scholars did it by learning amongst them all the ancient and modern Indo-European languages, comparing every word in each with words in the others, and tracing correspondences. Like Grimm's Law, which was another output of the brothers Grimm, and was the reason they were collecting Haus- und Kindermärchen in the first place. Holger Pedersen's Linguistic Science in the Nineteenth Century documents all this, which was not without controversies and false trails. – jlawler Jan 14 '12 at 18:38
    Etymology is the sort of thing, like atomic number, that can be decided once and then looked up. Historical linguistic research currently focusses on non-IE languages, which is where the challenges are. – jlawler Jan 14 '12 at 18:40
    As for methodology, etymology is mostly what happens when you've successfully tracked down a historic sound change like Grimm's Law, and find that the consonants in Germanic words like heart and corn have to be related to the ones from Latin words like cardiac or grain, which means both come from the same IE root; then you get several thousand etymologies at a time. But it's the sound changes that get tracked, because they can be, and because they determine the etymologies. – jlawler Jan 14 '12 at 19:00
    @jlawler these comments would be great as a full answer! – Floating Tone Jan 15 '12 at 02:36
  • Thanks, but I already gave one. These are just addenda to it. There's a lot of information here. – jlawler Jan 15 '12 at 16:38
    jlawler: @MukeTever's point is that your existing attempt at an answer doesn't respond to the OP directly, but your 1st and 3rd addenda do. So the suggestion is to edit your existing answer, making the addenda your official answer, and your current answer an aside. – Mitch Jan 16 '12 at 16:57
