13
Arabic languages include only three vowels: /a/, /i/ and /u/.
Japanese is the only language I know about that doesn't have a /u/ sound - it has /ɯ/ instead.
Do there exist any languages that do not use /a/ or /i/ or they could be considered universal vowels?
Arsen
  • 577
    Arabic has 8 vowel phonemes: /a/. /i/, /u/, /aː/, /iː/, /uː/, /aj/, /aw/. – Yellow Sky Sep 26 '15 at 23:44
    Yes, but they are all made of three sounds /a/, /i/ and /u/ (lengthened or mixed with each other). I might have been a little inaccurate. – Arsen Sep 26 '15 at 23:48
    I'm afraid they are not made of anything. You write them between the / / which means they are phonemes, and phonemes are not divided into anything smaller. – Yellow Sky Sep 27 '15 at 00:07
  • Thanks. Phonology is only my hobby, so I'm far from the expert. I was aware of the [ ] and / / distinction, but I couldn't fully catch this up. I guess I will know the difference from now. – Arsen Sep 27 '15 at 11:50
    @YellowSky. The three long vowels /a:/, /i:/, /u:/are indeed best analysed as separate phonemes, though traditional Arabic grammar does analyse the last two as /ij/ and /uw/ resepctively. /aj/ and /aw/ are vowel+semivowel clusters. – fdb Sep 28 '15 at 08:03
8 Answers8
21
It depends on what you mean by "/a/", "/i/". First, slash brackets refer ambiguously to "phonemes" or "underlying forms". Only phonetic forms, notated with square brackets, have directly-observable phonetic properties. A propos that point, there is a high back vowel phoneme in Japanese, which is pronounced more like [ɯ] than like [u], and on that grounds you might claim that Japanese has no /u/ but it does have /ɯ/. The principle here would be that the underlying / phonemic value of a segment is the same as (one of) it's surface values. On that basis, we would have to conclude that Norwegian does not have /u/, because if you compare the pronunciation of French "tout" and Norwegian "to", the vowel of Norwegian is /ʊ/, not /u/ -- the vowel typically transcribed in IPA as [u] is noticeably lower than the cardinal vowel standard. The problem then is that language descriptions typically leave out that level of phonetic detail, so you often can't tell if supposed "u" or "i" are pronounced as [u, i] or [ʊ, ɪ] or something else. With that caveat, Somali Zigua has the vowels [a ɛ ɔ ɪ ʊ], and not [i, u].
Answering the question for "/a/" is even more difficult. The vowel "a" of Arabic is distinctly different from the vowel "a" of North American English (as in the word "cot"). The Arabic vowel is rather close to the standard cardinal vowel value of "a", so under any interpretation, Arabic has /a/. English, at least certain dialects, do not have that vowel (though in some New England dialects it exists in words like "park"). In fact, there is no distinct IPA symbol for notating the low central vowel of "cot", and language descriptions typically use the letter "a" in case there is only one low unrounded vowel, so it is only when you have a contrast like in Norwegian that people are forced to distinguish "a" and "æ", or "ɑ" and "a".
In some west coast dialects (e.g. in Seattle) the vowel of "cot" is the same as the vowel of "caught" and furthermore the vowel is phonetically more like [ɔ] than it is like canonical [a]. If by "a" you mean a low unrounded vowel, then I would say that Enumclaw English is a language without /a/ (I pick Enumclaw because there is an urban / rural distinction that complicates the matter).
There is a classical analysis of Kabardian by Kuipers where the language does not have /i/, or many other vowels, although phonetically the language has a huge number of vowels. This would be an instance of economy-driven phoneme-elimination, for the sake of reducing the vowel inventory to just one phoneme. There is a similar many-to-few reduction of vocoids in Marshallese, which has been analysed as having just a 4-height distinction between /ɨ ɘ ɜ a/, where the 12 surface vowels derive by phonetic interaction between these 4 vowels plus palatalization and labialization on neighboring consonants. Under that interpretation, Marshallese has no /i/. Mark Hale has argued cogently that it is inappropriate to claim that vowels have any specific values of rounding or fronting in the phonology.
J-mster
  • 291
user6726
  • 83,066
  • 63
  • 181
  • This was a comprehensive answer. But there is one thing that seems strange to me: You wrote "it is only when you have a contrast like in Norwegian that people are forced to distinguish "a" and "æ", or "ɑ" and "a".", I'm not a native English speakers but doesn't most of dialects of English contrast /ɑː/ like in "guard", /æ/ like in "mad" and /ai/ like in "guide"? – Arsen Sep 27 '15 at 12:07
    @arsen, yes, English would be an example where one has to use two letters for low vowel phonemes -- though not /a/. Norwegian is a canonical example of /a/ vs /ɑ/, but the low vowel of English that isn't /æ/ is between /a/ and /ɑ/, so it's reasonable to notate the distinction as /æ, a/ or /æ, ɑ/. I omit diphthongs like /aj/ because they have no front / back contrast and phonetically the vowel is a third thing (closer to [a]). – user6726 Sep 27 '15 at 15:52
It's been claimed that Margi (Chadic branch of the Afro-Asiatic language family, Nigeria) has only two vowels, /ɨ/ and /a/.
There have also been sporadic claims of other languages with small or anomalous vowel systems, for example Iatmul (Ndu language family, Papua New Guinea) has been described variously as having: one (/a/), two (/ə/ and /a/), three (/ɨ/, /ə/ and /a/), seven and twelve vowel phonemes. So by at least some analyses Iatmul has no /i/ phoneme.
So the answer may depend on how flexible /i/ and /a/ are allowed to be. It may be better to recast the question in terms of features, front/central/back and high/mid/low and ask if there are languages with no (e.g.) high vowels, no low vowels, only mid vowels, etc.
Gaston Ümlaut
  • 6,697
  • 30
  • 46
Nearly all languages have at least three phonemic vowels, usually /i/, /a/, /u/ as in Classical Arabic and Inuktitut (or /ɐ/, /ɪ/, /ʊ/ as in Quechua), though Adyghe and many Sepik languages have a vertical vowel system of /ɨ/, /ə/, /a/. Very few languages have fewer, though some Arrernte, Circassian, Ndu languages have been argued to have just two, /ə/ and /a/, with [ɨ] being epenthetic.
It can also be said that English has no [a] because typically it has only [æ], [ɑ] and [ɒ]
One of the most common vowels is [a̠]; it is nearly universal for a language to have at least one open vowel, though most dialects of English have an [æ] and a [ɑ]—and often an [ɒ], all open vowels—but no central [a]. Some Tagalog and Cebuano speakers have [ɐ] rather than [a], and Dhangu Yolngu is described as having /ɪ ɐ ʊ/, without any peripheral vowels.
Some other languages without [i] or [u]
[i] is also extremely common, though Tehuelche has just the vowels /e a o/ with no close vowels. The third vowel of Arabic-type three-vowel system, /u/, is considerably less common. A large fraction of the languages of North America happen to have a four-vowel system without /u/: /i, e, a, o/; Aztec is an example.
https://en.wikipedia.org/wiki/Vowel#Vowel_systems
Lưu Vĩnh Phúc
  • 794
You write: “Japanese is the only language I know about that doesn't have a /u/ sound - it has /ɯ/ instead.”
Although you are using slashes, I think you are really talking about phonetics (“a /u/ sound”) and not about phonology. Phonology is an abstraction. There is no overwhelming reason why you should not analyse the Japanese [ɯ] as phonological /u/, nor is there any good reason not to analyse English [æ] as phonological /a/. These are just abstract symbols, like the symbols used in algebra. It would be better to ask whether there are any languages that have fewer than three vowel phonemes. Your question, as it stands, in unanswerable.
fdb
  • 24,134
  • 35
  • 70
  • "Overwhelming" is an unjustifiably high standard. There is also no overwhelming reason to analyse Japanese [ɯ] as /u/. Insofar as the vowel is actually pronounced as [ɯ], that is sufficient grounds for claiming that it is /ɯ/. While the reason for positing /ɯ/ is not "overwhelming", it is stronger than the case for /u/. – user6726 Sep 29 '15 at 15:54
  • @user6726: What does it even mean for there being a stronger case for one vs. another phonemic transcription? IPA is just an alphabet, and /u/ and /ɯ/ are both just symbols. Do you mean to make some kind of featural argument, for example, that /u/ is misleading because it implies +rounding? Phonetically, the vowel is actually compressed, and fronted compared to both cardinal [u] and cardinal [ɯ]. To really strictly transcribe the vowel as it is "actually pronounced," we'd something like ɯ˖ᵝ – brass tacks Sep 30 '15 at 00:10
  • @sumelic, I agree that the unalloyed phonetic symbol [ɯ] is not an accurate representation of Japanese phonetics, but virtual no languages pronounce their vowels according to cardinal-vowel based standards. Common practice is to select the IPA symbol that is closest to the phonetic value of the sound in the language, especially when settling on a single symbol for a given sound (as opposed to a scheme involving readjustment diacritics). There is no IPA symbol that is closer to that vowel of Japanese -- though perhaps you are claiming that it is closer to u than ɯ, in which case... – user6726 Sep 30 '15 at 00:26
I don't have much knowledge on the language, but the Arapaho language is the only language I have ever seen without any low (/a/) vowels. There is still a four vowel system, but whereas Central Algonquian languages like Ojibwe and Cree have /a e i o/, Arapaho has /ɪ ʊ ɛ ɔ/.
Interestingly, there's pretty good evidence that Proto-Indoeuropean didn't have any kind of /a/ sound. The /a/ sounds in descendent languages all seem to have come about through consonants low-colouring their phonetic surroundings.
Anonymous
  • 29
  • Sounds convincing. I've read before that Proto-slavic didn't put a distinction betwen [o] and [a], and I think leftovers of this are still visible in Polish (my mother tongue), as for example shorter for Aleksandra (Alexandra) is Ola (instead of Ala). – Arsen Sep 27 '15 at 14:14
    Evidence for the phonology of a proto-language? Show it to me! – Sir Cornflakes Sep 27 '15 at 16:40
Proto-Indo-European is widely believed (see e.g. Beekes) to have only /e/ and /o/ (and their leghtened variants). This is somewhat a simplification because u̯ and i̯ which behave as consonants morphologically, could be vocalized into vowels between consonants. So it is better to just say that PIE had only /e/ and /o/ kernel vowels.
This may be not the case for the most older stage of PIE, the so-called pre-PIE. In that language it is quite possible that the only two vowels were /e/ and /o/ and possibly even only /e/ because /o/ appeared as unstressed /e/.
For instance, the traditional reconstruction for the word for daughter is dhuga̯tēr which has vocalized /u/, but according to Kloekhorst the most ancient form was dhu̯ega̯tr.
Anixx
  • 6,643
  • 26
  • 38
  • Both of these reconstructions (a horizontal two-vowel system and a one-vowel system) are quite possibly typologically unique, so I'd hardly consider them convincing (especially the pre-PIE one, which is a huge reach). – user54748 Sep 29 '15 at 18:38
  • If /eH/ becomes /a/ in every (?) language, wouldn't this imply a phonetic [a] allophone? – b a Sep 10 '19 at 20:53
Iranian Persian and Tajik have lost straight /a/, and you can make the case that some English and some German dialects have too.
See: Persian phonology and its historical shifts
It is surely the case for many more languages, but asking us or reading eg https://en.wiktionary.org/wiki/Category:Alemannic_German_terms_with_IPA_pronunciation does not scale. The more interesting question is: What sites or tools exist to search over IPA pronunciations of an entire languages or many languages?
Adam Bittlingmayer
  • 7,664
  • 40
