I am transcribing an oral text into IPA in order to compare it with the "correct" pronunciation of words (e.g. according to the dictionary). I am using slashes for both versions, but it feels incorrect. Example: (actual written text); /hɛː san was/ (text as pronounced by the speaker); /hə(r) sʌn wəz/ (text according to dictionary). Should I use square brackets for the transcription of the actual pronunciation? Thank you!
furendaaa
  • 83
    Slashes are for a phonemic transcription, and brackets are for a phonetic transcription. The notation depends on the kind of transcription you’re making. It sounds like you’re making a phonetic one, so brackets; is that what you’re intending? – Jeremy Needle Jan 17 '16 at 14:19
Since your stated goal is to compare someone's actual pronunciation with some standard pronunciation, you should use square brackets, to indicate that you are talking about actually pronounced sounds. It does not matter whether the level of detail is narrow or broad; square brackets are for phones, slash brackets are for phonemes.
If you use slash brackets, you are asserting that what you write is a phonemic representation of speech, which should represent all (and only) the sounds that you believe to be contrastive sound categories in the talker's or listener's mental representation of the language (phonemes are abstract constructs, and are never spoken or heard).
To use your example, if you write /hɛː san was/ then you are asserting that the vowels in the second and third words are identical in the speaker's mental representation. That may or may not be the case; e.g., they could be different phonemes that have a partially overlapping distribution for this speaker, such that in this particular sentence they came out sounding very similar to you. Or, they could be totally non-overlapping distributions, but each of their sounds happens to overlap with different parts of your distribution for the phoneme you represent as /a/, so you classify them as the same sound, even though the speaker thinks they are producing two different sounds.
drammock
  • 824
  • I agree that phonemes are not spoken. But they are heard, by native speakers. – Greg Lee Jan 18 '16 at 18:40
    If the goal was to represent how an individual supposed perceives an utterance that could be valid. In this instance the purpose is comparing an actual pronunciation by someone else, as indicated by the OPs use of the expression "transcription of the actual pronunciation". Square brackets are what is appropriate for actual pronunciation. – user6726 Jan 18 '16 at 18:51
    Perhaps I'm splitting hairs here @GregLee, but how do you hear a mental representation? I would say listeners (and not just native listeners) hear phones and perceive phonemes. – drammock Jan 18 '16 at 22:33
    If you're a human, you're hearing a mental representation. I'll go along with "perceive". But I don't think "hear" is usually used to refer to sound waves striking the ear drums, so I use "hear". Wouldn't it make sense to say for this example that "son" was transcribed /san/ because @furendaaa heard the English phoneme /a/ there? – Greg Lee Jan 19 '16 at 01:11
  • I'll concede that standard usage of "hear" could apply in both cases, but (as is often the case) standard usage does not reflect the conceptual difference that is important here (namely: what the transcription is supposed to represent --- details of pronunciation, or mental representation). I suppose could have said "phonemes are never aurally sensed" rather than "phonemes are never heard", but that seems less clear (even if it's more precise). – drammock Jan 19 '16 at 19:05
  • So you mean I should in fact use square brackets for the actually pronouced sounds as perceived and slashes for the dictionary transcription? – furendaaa Jan 20 '16 at 15:44
    @furendaaa I think you should definitely use square brackets for the speech you are transcribing. Ideally you would also convert the dictionary's (presumably phonemic) transcription into a broad phonetic one (and use square brackets for it), doing things like substituting ɾ for t where appropriate. Exactly which allophonic details you include depends on what aspects of the speech you're interested in (i.e., if you are only interested in vowels you may choose not to bother with differences between ɾ and t). – drammock Jan 20 '16 at 19:04
Short answer: use slashes.
Slashes are used for phonemic transcriptions or for very approximate phonetic transcriptions, and brackets are used for phonetic transcriptions. A phonemic transcription has only enough information about the pronunciation to identify which words are being said, for someone who knows this language and dialect. A phonetic transcription has additional details about the pronunciation, which would be enough information for a knowledgeable person to make himself understood, even if he is not familiar with the language being spoken.
Phonetic transcriptions are language independent, at least in principle, though practically speaking, they will often omit some important information (for instance information about pitch and stress).
Phonemic transcriptions are language dependent, and they omit information which a person who knows the language would not need in order to understand what is transcribed.
In your example, I don't see a lot of phonetic detail -- the vowel of "son" is not written with a tilde indicating nasalization, for instance, even though the vowel probably is nasalized. So I'm guessing that you are only trying to capture phonetic information that you think is relevant to what is being said. That's why I recommend slashes.
Greg Lee
  • 12,466
  • 32
  • But surely there's going to be a problem, because if the speaker uses some vowel that isn' talready represented in the set used for that standard variety of English they are going to have to choose another existing symbol to assign it to. At this point the OP's transcription becomes useless, it seems to me. – Araucaria - him Jan 20 '16 at 16:24
    @Araucaria, yes, that's why it would be better to use phonetic notation, with square brackets. When you transcribe the speech of a language or dialect you don't know using the phonemes of your own language, the result will be a weird sort of thing that is neither phonemic (with respect to the language transcribed) nor phonetic. All the same, even though such a transcription ought to be phonetic, that doesn't mean it actually is. – Greg Lee Jan 20 '16 at 17:26
The Original Poster is going to have a massive problem here, brackets or no brackets. When we use slanty brackets, we use language-specific symbols to represent different phonemes. For example, the convention for transcribing the STRUT vowel in RP English is to use the upturned 'v': /ʌ/. This symbol does not relate in any meaningful way to the position of the notional sound on the vowel quadrilateral used on the international IPA chart.
If the Poster feels that a particular word produced uses a different sound from the one we would expect from the dictionary transcription, then, if they use slanty brackets, they are going to have to choose a different English-specific IPA symbol to represent that sound. It is highly unlikely that the sound produced by the speaker will neatly fit into the same slot as a different English phoneme. So for example, if they are saying /bed/ but with a very open /e/, the poster might decide to use an /æ/ instead. But of course, this sound is very unlikely to actually be more like a typical /æ/ than an /e/. So using an /æ/ here is not really appropriate. Apart from anything else the speaker clearly will be using their own allophone of /e/, not /æ/.
So that would seem to suggest that we need to use square brackets so that we can use an appropriate symbol from the international IPA set to describe the sound. But then the problem is that we can no longer use the remaining set of symbols chosen specifically for the transciption of English. The reason for this is that the strut vowel will no longer be able to be transcribed using /ʌ/, because the proper symbol for this when using the international set of symbols is going to be [ɐ], not [ʌ]. Similarly nearly all the other vowel symbols are going to have to change or have some diacritic added. This means that it will be very difficult to compare the output with what is given by the dictionary. Apart from this we can never be certain what target sound the dictionary transcription is intending anyway - because their transcription was from the set of English specific symbols relating to phonemes, not necessarily a clearly identified sound on the IPA vowel quadrilateral!
Although this second method might be better, it will take a lot more time and thought on the part of the Original Poster, and will necessarily be flawed to some degree.
Araucaria - him
  • 4,002
  • 39
    On a conceptual level, this is exactly why I decided to ask for an opinion on this matter. Especially because it seems to me there is no way to work with a non-flawes method... Thanks – furendaaa Jan 20 '16 at 18:25
