I am reading introductory phonology by Bruce Hayes, in chapter 12 he proposed an abstract analysis for English stress.Based on his proposed a word like cassette has been through a process like below:
/kəssɛttɛ/ → Underlying forms
kəˈssɛttɛ → Stress Assignment
kəˈsɛtɛ → Degemination
kəˈsɛt → /ɛ/ Drop
[kəˈsɛt] → Surface forms
How can these rules work for words such as "baton" and "Dupont"?
liza
  • 71
  • Replace the string kəssɛtt with bətɔnn. The final /ɛ/ isn't necessary but it's harmless. – user6726 Apr 18 '16 at 23:25
    I think about that, but he added /ɛ/ when we have /e/ at the end of the word. Can we add it without any reason?Also, he geminated when we have double consonants in surface form, can we geminate it without having two consonants in surface form? – liza Apr 18 '16 at 23:34
  • You're confusing spelling with underlying forms. It depends on how you state the stress rule – user6726 Apr 18 '16 at 23:39
  • I got you. Then I can have /bətɔnn/ and [duˈpɑntɛ] as underlying forms. – liza Apr 18 '16 at 23:44
  • I think that a final /ɛ/ for /bətɔnn/ is necessary, because without it, the SPE Main Stress Rule could skip over final tɔnn and assign stress to the next to last vowel (as in "moment", "forest", "modern"). – Greg Lee Apr 19 '16 at 20:37
  • True for SPE rules, but not since. Geminates are necessarily moraic (Hayes 1989) but not so with CC clusters. Hayes of course expresses the syllable-weight generalization moraically, not segmentally. – user6726 Apr 20 '16 at 15:02
The abstract analysis is not actually Hayes' own analysis, but was proposed by Chomsky and Halle in The Sound Pattern of English. The number of phonologists who actually accept this analysis surely hovers around zero. I don't know about Hayes, but when this analysis is discussed, it's generally understood that the analysis is wrong, and the reason for even mentioning it is to make some methodological point about why we should reject such a silly proposal. I'm not even sure that Chomsky and Halle themselves didn't have their tongues in their cheeks when they proposed it.
Even in SPE, the analysis is not proposed as a way to describe ordinary English forms, but only for certain exceptional English forms. C&H compare several ways of describing forms that are irregular in the sense that they do not conform to the rules that C&H have developed for describing the great majority of English words, and conclude that the abstract representations are the most economical way of describing such irregular forms.
Overall, the SPE analysis of English proposes that at the deepest level -- the lexical level, I suppose -- English words have no stresses marked, and all stresses are assigned by phonological rules. This is mistaken, but it is a reasonable idea, since there are regularities in the English stress system, and in a theory that describes phonological regularities with phonological rules, it seems to follow that stresses should be assigned by phonological rules.
Actually, it doesn't follow. We can have some stresses assigned lexically, and others assigned by rules. In general, morphophonemic rules affect parts of pronunciation that are lexically assigned (a reasonably clear case is the Backness Harmony rule of Turkish), and English stress is phonologically morphophonemic. Stress is phonemic, but it can also be assigned (or perhaps changed) by phonological rules of English.
There is a complication in English that makes this difficult to see, which is that English stress assignment is dissimilatory, like the stress in other alternating stress systems. I discussed this briefly earlier, in another answer here (see answer #7).
So, in my view, the difference between English "baron" with regular stress on the first syllable and "baton", with irregular stress on the second syllable, is appropriately described by assigning phonemic forms with the stresses as observed. The SPE Main Stress Rule is dissimilatory, so that it cannot assign the main stress to a syllable which is followed by a stressed syllable, and that's why it can't apply to the first syllable of "baton". The stress of "baton" is irregular, because if the stress were not known to an English speaker, the Main Stress Rule would make the first syllable stressed, rather than the second syllable.
Greg Lee
  • 12,466
  • 32
I agree with Greg Lee. What Hayes is getting at here is that in English, the final syllable in nouns is invisible to stress: it is extrametrical. kə.sɛt.(tɛ), bə.tɑn.(nɛ), du.pon.(tɛ). Furthermore, for the middle syllable to receive stress, it must be heavy, e.g. CVC; otherwise, you would get ˈkə.sɛ.(tɛ). This chapter is on Abstractness (a controversial idea), so that's why these weird underlying forms are proposed, without any apparent motivation (it would be better if there were some plausible explanation to justify them).
k8i
  • 161
