15
Watching a movie recently I found I couldn't make out the dialogue because it was all whispered.
I turned the volume up, and had no problems hearing everything. It seems to me that all words are articulated normally when whispering - the only diference is the vocal cords aren't activated.
Is this true? Is there anything you can't say properly in English or any other language without using your vocal cords?
Mark Beadles
  • 6,860
  • 46
FumbleFingers
  • 998
    It might be useful to point out that in whispered phonation, the vocal cords are actually used. They do not vibrate, but they are tensed in such a way that the friction of air passing them produces turbulence, leading to the characteristic sound. This is different from unvoiced phonation, where the cords are lax. – Mark Beadles Apr 03 '12 at 23:26
  • @Mark Beadles: Are you sure about that? It seems to me (as a layman on such matters) that when whispering I create "turbulence" by raising the back of my tongue so as to restrict outflowing air. I'm not aware my vocal chords (which are much further back and down) are involved at all. – FumbleFingers Apr 04 '12 at 21:11
    Yes, this is fairly well-known in linguistics. See for example this (basic) and this (PDF, much more extensive). There is probably lots of variation between individuals, of course. – Mark Beadles Apr 04 '12 at 21:22
  • Okay, well it says there Whisper sound quality is produced through turbulences generated by the friction of the air in and above the larynx with vocal folds not vibrating, which I guess means at least some of the turbulence is created by the vocal chords. Perhaps the back of the tongue is just "modulating" that turbulence. – FumbleFingers Apr 04 '12 at 21:32
I've done a couple of little experiments on the identification of stop consonants in whispered speech, though I haven't published the results or even fully analyzed the data, and don't know if I ever will. One of them was with a single Gengbe speaker, and the other was with 15 Korean speakers (if my memory serves me correctly). With that caveat in mind, I'll venture some guesses about whispered speech.
It seems that whisperers articulate stop consonants in such a way that the aerodynamic effect of producing them is similar to normal speech. In normal speech voiced consonants have less pressure buildup behind the closure than do voiceless consonants phonation will not occur with too high of a transglottal flowrate. In whispered speech I think that talkers produce a voiced stop so that it has a pressure gradient across the constriction similar to what would be experienced if phonation were occurring. Listeners can then identify a voicing contrast by the intensity of the release burst. I think this is true because for both the Gengbe and Korean participants, identification of voicing/laryngeal contrasts was best for velar stops. Velar stops have a higher burst intensity overall than stops at other places of articulation, so differences between more and less intense bursts will be more palpable. Identification for Gengbe was worst for labial velar stops, which have a very faint burst release, and Korean labial stops were also poorly distinguished. Korean listeners were also able to distinguish at better than chance rates the fortis-lenis distinction, and I think that they were able to make use of duration differences to help with this.
Place of articulation is determined by spectral properties of the speech signal which do not require periodic excitation of the oral cavity, so we would predict that vowel and consonant place of articulation information is well preserved in whispered speech, and I didn't find anything to contradict this. Gengbe makes a distinction between lamino-dental and apico-alveolar voiced stops, and these two were never confused by my participant.
As expected, tonal contrasts are very poorly preserved, and my Gengbe participant could not distinguish at better than chance rates high and low tones. I don't think tonal contrasts should be ruled out altogether: one could in principle differentiate tones by altering the tension of the pharyngeal walls, making the airflow more or less turbulent, though this is just speculation.
If anyone can contribute any references to published work on perception of whispered speech, I'd love to see them.
  • An example for English speakers: English stress is normally conveyed by a combination of pitch, syllable length, loudness, etc.. I find that when whispering, I tend to exaggerate length of stressed syllables. – Mechanical snail May 18 '12 at 09:58
