13
The English word angst, taken from German Angst, seems to ultimately originate from Proto-Germanic *angustiz. This word has descendants in many Germanic languages, including, but not limited to, Danish, Norwegian, Swedish, German and Dutch. The English word anger is also related to this group.
The English word anxiety has a similar meaning and seems to derive from Latin anxietās. This word has cognates all over the Romance languages, including, but not limited to, French, Italian, Spanish and Portuguese.
These two groups of cognates mean similar things. If we go even further back, is there a link between the two groups, for example in Proto Indo European?
I would prefer if answers included a source.
Fiksdal
  • 858
  • By the way, angst is not an inherited word in English. It was borrowed from German Angst "fear." – brass tacks Apr 30 '16 at 15:58
  • @sumelic Does that mean I made a mistake in the question, or are you just providing additional information? – Fiksdal Apr 30 '16 at 15:59
  • From the way you phrased the question, I wasn't sure if you knew. Generally, in historical linguistics the term "cognate" only refers to words that have a continuous line of transmission from a common ancestor. By this definition, English "angst" does not have any cognates, as it is a loanword. See this question for more explanation: Is a loanword also a cognate or are the two terms mutually exclusive? – brass tacks Apr 30 '16 at 16:05
  • @sumelic I see. No, I totally didn't know that. Could you edit my question to remove the inaccuracy? – Fiksdal Apr 30 '16 at 16:15
  • @sumelic Anguish as cognate was taken from Wiktionary. Etymology Online also relates anguish to anger. – Fiksdal Apr 30 '16 at 18:01
  • "Anguish" is ultimately related, but it is not Germanic. I wasn't sure where to put it. It comes from French angoisse from Latin angustia. – brass tacks Apr 30 '16 at 18:02
  • @sumelic Oh, I see. In that sense, it is probably more related to the second group. Maybe better to just leave it out. – Fiksdal Apr 30 '16 at 18:03
  • That's what I was thinking :) – brass tacks Apr 30 '16 at 18:03
    @sumelic: That is not how I have ever seen the word cognate used, in such a narrow sense! To me, sharing a common root is synonymous with being cognate. Nor, frankly, has that answer convinced me to use it differently from now on. I've never seen its mening limited such that borrowing between languages should destroy cognation. And there is considerable dissent among the answers to and comments on that question. – Cerberus Apr 30 '16 at 19:27
  • I have the same terminological intuitions as @Cerberus. – jlawler Jun 13 '22 at 21:38
Yes, Germanic angst and Latin anxiety are are derived from the same Proto-Indo-European root, which was something like *h₂enǵʰ- "constrict, narrow".
Philippa (2003-2009) confirm that they are cognates: under angst they say, "see eng"; under eng they say that the word is related to Latin ango and they give the Proto-Indo-European root as above. Also related is angina, from Greek.
De Vaan (2008) says anxius is derived from ango as expected, and mentions the same root as Philippa.
Idle speculation: the root may be onomatopoeic, because an emphatic sound /ŋ/ resembles the sound one makes when one's throat is blocked or constricted.
Cerberus
  • 7,976
  • 49
