It seems the retroflex d and t are present in some Germanic languages but not in most Romance, Slavic, and other IE languages.
I know that it occurs in IE languages of Asia, like Sanskrit, Pashto, and north Indian languages, (but not Persian), which could be explained as contact with people having these sounds in their language, but my focus is specifically on Europe.
Has there been any explanation given why it occurs in Germanic but not others?
PS: I am a rank amateur in linguistics, so I have used "some" and 'most' just to be on safer side.
EDIT: I am a bit embarrassed that I mistook the alveolar stops t and d to be the retroflex ones; to me they sounded the same. It appears that only Norwegian and Swedish have them, as opposed to English, German and Dutch that I had listed in the original question. However, this information won't affect my interest in the topic. I have updated the question accordingly.
vin
  • 576
  • Could you give a simple example of an English word (or words) where a retroflex d (and/or t) can be found? I'm seeing this term for the first time in my life and it is almost impossible to figure out what the hell is this by just reading the description in Wiki :)) Thank you. – tum_ Jun 30 '16 at 16:02
  • 'date' has both retroflex d and t (as I had assumed, please check the update) – vin Jun 30 '16 at 17:42
  • Thanks for the edit. I upvoted the question as I know that the lack of reputation is too restrictive.. Unfortunately, I still don't fully understand what "retroflex" means but I can live with this :) – tum_ Jun 30 '16 at 20:09
    Sicilian also has developped a retroflex d sound that contrasts regular dental d, see here https://en.wikipedia.org/wiki/Sicilian_language#Characteristic_sounds – Sir Cornflakes Jun 30 '16 at 20:39
The only Germanic languages with retroflex consonants are Norwegian and Swedish (where it is a dialect feature -- not found in e.g. Bergen Norwegian where <r> is uvular). The origin appears to be <r>, reflected in the spelling, where [kɑʈʈ] "map" is spelled <kart> and [kɑtt] "cat" is spelled <katt>. Assuming the facts on Kristofferson's The phonology of Norwegian, ɽ is "more phonemic", and can be traced back in some contexts to earlier rd clusters in Old Norse that were simplified to [ɽ]. The retroflex flap also appears (depending on dialect) as a variant of /l/ after back vowels. There is a poorly-understood connection in a number of languages between preceding vowel backness and the r, l distinction (though one can either find the pattern [il, ur] or [ir, ul]).
In some dialects of American English, there is a coarticulatory process where in an onset cluster with <t,d> causes some retraction of the stop, which many people think sounds like [tʃ]. The actual quality of <r> in American English is fairly variable, but under a liberal interpretation of what "retroflex" means, one could say that <r> is a retroflex glide, in which case one could also say that /t,d/ also become phonetically retroflex.
Actually, many people say that Russian /ʃ, ʒ/ is retroflex and Polish has them too. Retroflex consonants are said to exist in dialects of Italian. All in all, these are probably natural phonetic developments that just happened to make it on the map of linguistic documentation in these languages. Basque and (dialects of) peninsular Spanish have what are usually termed apico-alveolars, which could be lumped together with retroflex consonants. It turns out that "retroflex" is not such a unified phonetic thing, so Indic and Dravidian languages differ in the values of the "retroflex" consonants.
brass tacks
  • 18,116
  • 45
  • 91
user6726
  • 83,066
  • 63
  • 181
    I made a mistake in recognizing the consonants, seems what I thought were retroflex are actually alveolar. Thanks for the informative answer. (Sorry I can't upvote you yet) – vin Jun 30 '16 at 17:57
  • The Russian, Ukrainian, Belarusian, and Bulgarian Ш and Ж together with the Polish SZ and Ż are definitely retroflex [ʂ] and [ʐ]. – Yellow Sky Jul 01 '16 at 01:15
  • @YellowSky Right. And the sound in pleasure or leisure is not? Or in French bonjour? Still trying to grasp the difference... – tum_ Jul 01 '16 at 18:50
  • @A.Toumantsev - the English /ʒ/ is a voiced palato-alveolar sibilant (listen), the Russian /ʐ/ is a voiced retroflex sibilant (listen). There's a note about [ʐ]: Some scholars transcribe the laminal variant of this sound as /ʒ/, even though it is not palatalized. In such cases the voiced palato-alveolar sibilant is transcribed /ʒʲ/. – Yellow Sky Jul 01 '16 at 22:16
    There is a poorly-understood connection in a number of languages between preceding vowel backness and the r, l distinction -- can you elaborate on this? Do you mean that the r/l distinction is neutralized in some languages after a back vowel? – TKR Jul 16 '16 at 21:58
  • The cases I know myself are about allophonic distribution but I think I've seen a neutralization case – will post if I can ever find it. – user6726 Jul 16 '16 at 22:20
There are two different things to consider:
Contrast between dental and retroflex d's and t's: Such a contrast has developped in the Indic subbranch of the Indoarian languages, probably due to contact with Dravidian (or Austronesian or Sino-Tibetan or other [e.g., Burushaski]) languages. It also occurs in the Sicilian dialect and in Norwegian and Swedish (in both cases due to internal development of the respective languages).
Quality of the d's and t's: Speakers of Indic languages hear the English d's and t's as retroflex and borrow them into loanwords as such. Portuguese d's and t's are borrowed as dental sounds in loanwords. I don't know the reason for this phenomenon.
Sir Cornflakes
  • 30,154
  • 128
    Perhaps for the very reason that @Vin confused alveolar and retroflex? An Indic speaker hears a native English speaker saying Ds and Ts with the tongue retracted [but not curled] and to him, the sounds are closer to his retroflex consonants. So whenever he speaks English, he uses retroflex Ds and Ts. – David Garner Jul 05 '16 at 08:06
    @DavidGarner You are spot on in guessing why I made the mistake. However, while speaking English I use what I thought was "soft retroflex" as opposed to "hard retroflex" in my language. It never occurred to me that these 'soft' ones were not retroflex to at all, but rather alveolar. – vin Jul 05 '16 at 09:35
    @jknappen That 'internal development' is what I am interested in. Do you know of other features in these languages that are peculiar to the said languages and absent in the languages that surround them? That could give us a clue. – vin Jul 05 '16 at 09:41
I came across this question and wanted to give this input that might interest you. Even for Indic (Indo-Aryan) languages, the debate whether development of retroflex sounds was due to contact with Dravidian or an internal development is still open. The internal development account claims that the palato-alveolar sibilant underwent a context-free change to a retroflex sibilant. This introduced the retroflex manner feature, leading to the development of the stop series. My intuition is that the contact-based account makes more sense since there are other features (such as affixal conjunction, quotative complementizer) whose timeline matches with the retroflex sounds.
SudKol
/ll/ > /ɖː/ in several Italian dialects (and, under Calabrian influence, in Calabrian Greek): https://en.wikipedia.org/wiki/Sicilian_language
ḌḌ— The -ll- sound (in words of Latin origin, for example) manifests itself in Sicilian as a voiced retroflex stop with the tip of the tongue curled up and back, a sound rare in the Romance languages. [...] The sound itself is not /d/ but rather [ɖ]. For example, the Italian word bello [ˈbɛllo] is beḍḍu [ˈbɛɖʊ] in Sicilian. This sound [ɖ] also evolved from Latin -ll- in Sardinian, to an extent in Asturian, elsewhere in Southern Italy, and in many northwestern Tuscan dialects.
(Southern Calabrian is a branch of Sicilian.)
So it does in fact happen in Romance; and in fact, it doesn't sound like retroflexes are that much more common in Germanic than in Romance. As for why some language features occur more in one language family than in others, it can be any of (a) areal diffusion (hence Calabrian Greek); (b) common inheritance; (c) coincidence.
Nick Nicholas
  • 3,276
  • 45
