26
How did the name "מֹשֶׁה‎" come to be transliterated with a [z] at the end?
The OED entry notes that "Moses" derives from Biblical Hebrew "Mōšeh" and that the earliest attestations with a strident coda on the second syllable are Hellenistic Greek "Μωσῆς", "Μωυσῆς" but fails to show how or when the former gave rise to the latter. Are there other examples of open syllables or final vowels having "ς" appended like this in Greek transliteration?
Alenanno
  • 9,388
  • 48
  • 80
WAF
  • 629
    There is an interesting discussion incorporating this question in the comment thread on http://www.rationalistjudaism.com/2010/12/prince-of-egypt.html – Isaac Moses Dec 23 '10 at 20:43
    @Isaac Moses Thanks. I am reading through the relevant pages now. I continue to find it very strange how so many people give so many explanations for etymologies of the name "Moses" that magically skip straight from "Ancient Egyptian" to Greek/English, excluding Hebrew. – WAF Dec 24 '10 at 01:36
  • Related: https://hermeneutics.stackexchange.com/q/5161/177 & http://english.stackexchange.com/q/139869 – TRiG Dec 20 '23 at 21:31
Moses is transliterated this way because of the way it is declined in Ancient Greek. While the root of the proper noun משה in Greek is indeed μωυση, which is roughly transliterated "moyse" or "moise", it can take the following forms based on its function in a sentence:
  • Nominative: μωυσῆς (Moises): e.g. Deuteronomy 1:1: "These are the words that Moshe said". Used when Moshe is the subject of a sentence.
  • Genitive: μωυσῆ (Moise): e.g. Joshua 1:1: "after the death of Moshe", and in the same pasuk, "servant of Moshe". Used to indicate possessive.
  • Dative: μωυσεῖ (Moisei): e.g. Exodus 31:18: "He gave [the luchos] to Moshe"; Exodus 16:22: "and they told it to Moshe". Used when Moshe is the indirect object. (Note the subtle difference between להגיד inducing the dative versus לדבר inducing the accusative.)
  • Accusative: μωυσῆν (Moisen): e.g. Exodus 2:15: "Pharaoh wished to kill Moshe". Used when Moshe is the direct object. Also all the "vayidaber Hashem el Moshe"'s are in this case.
  • Vocative: μωυσῆ: e.g. Exodus 3:4: "He said 'Moshe! Moshe!', and he replied 'hineni'". Used when calling out Moshe's name.
These declensions follow particular rules, such that any noun with a certain type of stem will be declined following a particular pattern; so it is not just Moses that has a sigma added to its root to form the nominative. Some other names in the Torah that are found declined in the Septuagint are Judah/יהודה/Iουδας/Iουδα/Iουδαν, Joshua/יהושע/Ἰησοῦς/Ἰησοῦ/Ἰησοῖ/Ἰησοῦν and Sarai/שרי/σαρας/σαρα/σαραν.
The nominative form, as opposed to the root or vocative, could be considered the "primary" way to refer to the person, since it's how you form sentences having them be the subject, or the main actor.
    @Yosef Thanks! Were the English translators naively defaulting to the nominative in every instance of משה? If so, why did the same not happen in the cases of the other names you mentioned, which made it into the Christian bible, if I'm not mistaken, with no such vestige? – WAF Dec 13 '10 at 23:11
    That's a good question, I don't know! It seems that in other languages into which the Bible was translated, there aren't the same problems with inconsistency in transliteration. However, with English, the main early translations were even internally inconsistent (Judah/Judas is one example in the King James version). Also, even English spelling in general was in great flux at the time the early translations were done. But that still doesn't explain why Moses consistently retained the final 's'. –  Dec 14 '10 at 12:15
In Chumash Binas Miqra, by Rav Aryeh Leib Gordon (author of Siddur Otzar HaTefilos) he brings that he saw in old secular sources that in ancient Egyptian the word mo means "water" and the word yses means "was saved from", hence the Alexandrian translator always refers to Moshe as "Moyses".
alt text
    "Moses" does sound kind of like an Egyptian name, when you think about it. Like Raamses. So, who Hebraicised it? Par'o's daughter? – Isaac Moses Dec 13 '10 at 21:27
  • @Isaac I agree with your question about how it went from Moyses to Moshe (scratching my head) but is there more reason - based similarly on the root "yses" - than the sound to conclude that these names sound Egyptian? – WAF Dec 13 '10 at 23:05
  • There are many Egyptian words in Chumash, e.g. "lot" = lotus (in Latin), "Teneh" = clay head basket, etc. This discussion could be related to this answer of a different discussion : http://mi.yodeya.com/questions/295/where-can-i-find-hebrew-etymologies/390#390 –  Dec 14 '10 at 00:50
  • @WAF. This isn't the first time people have posted pictures. I'm not going to go search them up now, but there are a few. – Isaac Moses Dec 15 '10 at 17:38
  • @Yahu Do you mean the name לוט in your first example? @Isaac - OK! They somehow escaped me. – WAF Dec 15 '10 at 17:47
  • I think Yahu is referring to the plant or spice לוט, mentioned as one of the items that the Yishmaelim who bought Yosef were transporting (Gen. 37:25) and in the brothers' gift to Yosef (ibid. 43:11). And maybe indeed Lot was named after it too. –  Dec 15 '10 at 20:41
  • Alex is correct. I was referring to the "lot" mentioned as one of the items the Yishmaelim were carrying. Interesting that it was a very prized herb in ancient Egypt. I think the first pictoriel reference (or one of the first) was the graphic I uploaded and added to here: http://mi.yodeya.com/questions/1641/shnayim-vearbaim-mi-yodeya/1648#1648 –  Dec 16 '10 at 03:36
    @Yahu Just for linking to that, a new answer was added to 42 from things I was just reading this week. – WAF Dec 16 '10 at 05:50
    I just discovered that @josh_waxman has an extensive piece in which he expresses strong doubts about the Egyptian origin of this name: http://parsha.blogspot.com/2005/04/vayikra-1-moshes-name.html – Isaac Moses Dec 23 '10 at 20:41
    I don't know about these 'mo' and 'yses', but I do know that Rameses contains the root mese ('born'), as that was one of the clues Champollion used to decipher Egyptian. I have a strong suspicion that the -s on the end of Rameses is no more Egyptian than the -s on the end of Moses is Hebrew. – Colin Fine Jul 25 '12 at 00:02
Well, another example (lehavdil) is "oso ha'ish"'s Hebrew name, ישוע (a shortened form of יהושע found in a few places in Tanach), which ends up in Greek and English with a final S.
I can't recall the source for this now, but somewhere I read that this is because in classical Greek, names ending in a vowel were (or at least sounded) feminine or barbarian.
In the audio course on the History of Ancient Egypt, professor Bob Brier mentions the similarity between the name Moses and the names of Egyptian pharaohs like Ramses or Thutmose. In ancient Egyptian "mes" is the word for "son", and "mesu" means "to be born". So "Ramses" means "the son of Ra" or "Ra is born", and "Thutmose" means "the son of Thoth" or "Thoth is born". Bob Brier argues that since Moshe was born in Egypt and raised as a member of the Egyptian royal household, his name may well be Egyptian in origin.
Dima
  • 141
    Ibn Ezra says he was called Monios in Egyptian, which means "drawn"; the Torah is translating the name into Hebrew for us. Netziv says she in fact called him something that means "son" in Egyptian but "drawn" in Hebrew; she could call him "son" because she drew him out of the water. –  Dec 15 '10 at 17:30
  • @Dima - Do you know exactly where in that course he draws this conclusion or how etymological/correlative it is? Also, do you think this explanation can be reconciled with Yosef's above? Thanks! – WAF Dec 15 '10 at 17:40
  • @Shalom - Can the Ibn Ezra's opinion explain the connection to the name "Moses"? Is the Netziv explaining the Ibn Ezra so as to reconcile his opinion with that of Bob Brier above (so to speak), or is he arguing on Ibn Ezra to claim that the name she gave him was actually "Moshe" and not "Monios" or something else? And is the Netziv really ascribing all of this knowledge to the daughter of Par'o or simply stating that it is true enough for the Torah to tell us as "narrator" of the event? – WAF Dec 15 '10 at 17:45
  • @WAF: 1.) I don't know. 2.) Arguing. 3.) She said "I'm calling him 'son' because I rescued him." The Torah narrated it (and I think possibly tweaked the word slightly) to imply the water-drawing word. –  Dec 15 '10 at 19:49
  • @Isaac Moses: thank you for your kind words. –  Dec 15 '10 at 20:29
  • @WAF: It's been a while since I listened to the course... IIRC, there is a whole lecture on how well the story of Joseph in the Torah squares with what is actually known about the daily life in ancient Egypt, and I think this is where he talks about it. He said that the name Moses sounds perfectly Egyptian to him, just like Ra-moses (Ra is born) or Tutmoses (Tut is born). Unfortunately, he did not really elaborate much beyond that, and it struck me as odd that he is using the anglicized version of the name, rather than the original "Moshe". –  Dec 15 '10 at 20:34
