My understanding is that the reflexes of Proto-Germanic velar consonants before front vowels were usually palatal consonants in Old English, which in turn generally yield palatal or palato-alveolar consonants in Modern English, as in yellow from Proto-Germanic *gelw-.
So why does Modern English have /g/ at the start of the second syllable of "begin," which the OED says is from Proto-Germanic *ginnan?
I know there are words where /g/ is thought to have been established before a front vowel due to Scandinavian influence, such as get and give, but I haven't found any mention of that for begin. The OED and Etymonline say that in Old English, a more common word built on the same root was onginnan, but this still seems like it should have palatalization.
However, the OED does record some OE spellings of onginnan with the letter y instead of i (e.g. ongynnan) which according to my understanding usually represented /y/ in Old English, a vowel which was not usually preceded by a palatalized consonant.
My guess is that the /g/ is due to some kind of analogical leveling under the influence of the past-tense and past-participle forms, which have back vowels and therefore wouldn't have regularly developed a palatal consonant. Is this thought to be correct? If so, I'm curious about if we have any evidence of the date of this, and if the word is ever thought to have had /y/, or if the spellings with "y" are likely just ways of representing /i/ after a velar consonant (or mere unconditioned variants of the spelling with "i" used by scribes who had lost the phonemic distinction between /i/ and /y/). I don't see any real phonetic basis for rounding this vowel, unlike in "busy" (< PG *bisig-) where there is at least an adjecent labial vowel, but perhaps the "u" of the past participle and some past tense forms provided an analogical basis.
brass tacks
  • 18,116
  • 45
  • 91
  • Interesting. I wonder if perhaps it's because a) the presumptive root ginnan isn't actually cited in OE or any other Germanic tongue, and b) the more common OE term, which we might assume would exert considerable influence over the pronunciation, was onginnan, and the ordinary phonotactics for n-g clusters calls for a stopped /g/. – StoneyB on hiatus May 22 '17 at 20:48
  • ... My wife suggests there might be a little folk-etymology involved, too: that it was apprehended by OE speakers as 'rooted' in gan, "go" rather than the vanished ginnan, "gape, open". . . . However, Mitchell and Robinson dots the ‹g› in both be- and on- versions; I have no idea whether there's any actual evidence for that, or just an inference of regularity. – StoneyB on hiatus May 22 '17 at 21:02
  • ... AND My OED, which is the first edition, doesn't have any spellings with ‹y› for ‹g›; when ‹y› shows up it's one of the vowels. MED doesn't give any spellings with ‹y› for ‹g›, either. – StoneyB on hiatus May 22 '17 at 21:13
  • @StoneyB: Well, my understanding is that an "ng" cluster before a front vowel would normally be palatalized to /ndʒ/, but it might be different when there's a morpheme break after the /n/. I wouldn't expect to get /ŋg/ though. Yeah, the "y" is a vowel in the online version also; I should clarify that. – brass tacks May 22 '17 at 21:26
So far, this is a short general post about some exceptions in which palatalization of /g/ before a front vowel did not happen.
This is a well-known phenomenon and virtually all books on historical phonology of English worth reading devote a special section to this topic - see e.g. Hogg 1992, Lass and Anderson 1975 or Minkova 2014. cf. Durkin 2014: 195
See the quote below from Lass and Anderson 1975:enter image description here
It is even discussed in slightly "less technical" literature, e.g.
Upward and Davidson 2011 write the following:
One recurring feature in words of Scandinavian origin that sets them apart from Anglo-Saxon-derived words is the retention of /g/ before a front vowel, as in get, give, begin (if these words had derived from Anglo-Saxon English, it should have resulted in Modern English forms such as * yet, * yive, * beyin)"
(pp. 28-29; emphasis mine - Alex B.).
Sara Pons-Sanz (2015) traces this idea back to Björkman 1900.
As for Scandinavian influence on English vocabulary, I strongly recommend reading at least Part IV. Scandinavian Influence (pp. 171-221) in Durkin 2014, Borrowed Words (Philip Durkin is the chief etymologist of the OED, by the way).
One very important thing to remember - as Durkin reminds on p. 192
"in some of these instances, it is perhaps more likely that what we have is substitution of the Scandinavian form for its similar-sounding native cognate within a particular bilingual speech community, with the Scandinavian form then gradually spreading at the expense of the native form" [emphasis mine - Alex B.].
NB! by Scandinavian Durkin means "the ancestor varieties of both West Norse (Norwegian and Icelandic) and East Norse (Danish and Swedish), but at a time earlier than our earliest substantial surviving documents for any of the Scandinavian languages, and at a time when the differences between West and East Norse were still very slight" (p. 175).
Back to your OP - we don’t really know why, and this happens not infrequently in historical linguistics. For example, we don’t really know why OE ceorfan > PDE carve (and not *cherve).
As for OE beginnan, two explanations are possible.
1. Scandinavian influence (Dieter Kastovsky, e.g. Kastovsky 1992 specifically mentions OE beginnan):
However, there is no direct evidence to support this hypothesis but we may have some indirect evidence.
First, even though we can find OE beginnan, another verb was much more common – OE onginnan, until it was superseded by ME beginnen around the fourteenth century.
An interesting similar case could be the development of OE ongean (> PDE again). The ODEE (ed. Onions, 1966) says “the native forms in aȝ-, ay- did not survive beyond XVI, being superseded universally by forms in ag-, derived from Scand. and appearing first in northern and eastern texts XIII.”
More information about the chronology of this change could come from the development of OE giefan (> PDE give). The ODEE mentions that the non-patalal variant appears c.1200 and that the regular ME forms yive, yeve etc. “prevailed in southern and midland writings till XV.”
So, the remark by darkgamma that "the etymology is off and the chronology is wrong by a few hundred years" is irrelevant.
However, the biggest problem is the apparent lack of a Scandinavian (Old Norse) cognate, and I'm by no means the first linguist to notice this.
2. (Analogical) leveling:
However, there is no conclusive evidence to support this, either. We have to remember that even though it is “inherently irregular,” it is a “fairly systematic process” (Hock and Joseph 2009: 152; emphasis mine - Alex B.), which means we should be able to find other examples – very few but they should be out there.
Cf. Hogg 1992 “with the degree of allomorphic variation noted in §7.41, it would be expected that there should be considerable analogical levelling and extension” (Hogg 1992/2011: 269) and later he claims that “[a]mongst strong verbs there appear not to be clear-cut examples [of analogical levelling – Alex B.] in OE” (p. 270; emphasis mine - Alex B.).
However, in our case this would contradict the directionality of Mańczak’s seventh tendency of analogy, which states that “the forms of the present more often bring about the reshaping of other tenses than vice versa” (as cited in Campbell 2013: 265).
Examples of levelling (strong verbs, West Saxon):
OE gyllan – geal – gullon, cf. PDE yell (yelled)
OE gyldan – geald – guldon, cf. PDE yield (yielded)
Also, the analogical levelling hypthesis cannot explain why OE onginnan > ME aginnen was superseded by ME beginnen.
To conclude, as Pons-Sanz 2015 writes,
"In the end, it is up to the linguist’s judgement and his / her willingness to accept the Norse derivation of a term without a formal Norse imprint that determines whether or not it will make it to the list of medieval English words with a Norse etymon. This, of course, is a serious problem for historical linguistics, given the central place of many Norse-derived terms in the English language."
Alex B.
  • 8,744
  • Well, sorta. Get is certainly of Scandinavian origin; but give in fact is regularly yeve in ME through the 14th century. OED 1. “The g forms, however, certainly originated in the north (though the want of 12th c. northern texts renders direct proof impossible); and, as they do not admit of being (like the guttural g of begin) explained as the products of analogy, it seems most probable that they are due to Scandinavian influence.” OED points out that give reflects Danish or Swedish rather than ON. – StoneyB on hiatus May 23 '17 at 05:50
    “Why does begin have a /g/?” “Because it is of Scandinavian origin.” “How do we know it is Scandinavian?” “Because it has retained the /g/.” I smell a circular argument. – fdb May 23 '17 at 07:48
    I am not sure they are correct, since that verb wasn't inherited in Scandinavian. It resembles such a verb, but the etymology is off and the chronology is wrong by a few hundred years (as the verb was borrowed into North Germanic only in Hanseatic times) – Darkgamma May 23 '17 at 11:38
  • Thank you! This is helpful, but based on @Darkgamma's comment, I still feel a bit unsure. It's too bad that Upward and Davidson use it as an example in a list rather than explaining its derivation in more detail. – brass tacks May 23 '17 at 12:52
  • @sumelic I can write a more detailed answer on the weekend. – Alex B. May 23 '17 at 13:04
    Thanks; I would like to know more about the Scandinavian source word and how it entered English. – brass tacks May 23 '17 at 13:05
  • Thanks for the edit! It seems strange to me to describe /ge/ as "impermissible" considering the existence of /geː/ in words like /geːs/, the plural of /goːs/. My impression based on this word and was that velar softening before front non-round vowels had to be considered a pre-OE rule that didn't continue to be "active in all contexts" so to speak into OE times, unless the unrounding of the "geese" vowel occurred later than I thought. – brass tacks May 24 '17 at 02:10
  • (Another example I just found that seems similar is "cemban" the source of "unkempt".) I know Lass and Anderson say "original front vowels" at the start of that quote, but to me, their example of word-initial clusters like /dv/ or /vl/ that don't occur at all in English words outside of loanwords seems not very analogous. It seems more similar to something like word-final /ldz/, which occurs in English but only as the result of suffixation in native words. – brass tacks May 24 '17 at 02:16
  • @sumelic but here we need an analogy affecting the word-initial position - hence their examples Dv- and Vl-. – Alex B. May 24 '17 at 03:13
  • Hmm, maybe word-initial /ð/ would work since it is in only "function words" in native English vocabulary. – brass tacks May 24 '17 at 03:15
    Very interesting stuff with this latest edit! – brass tacks May 30 '17 at 03:27
  • @fdb Well, even though I must admit the proposed argument may indeed appear somewhat circular, there is solid evidence for Scandinavian influence in the cases of absence of palatalization of /g/ before a front vowel, particularly in the word initial position.I think it would be rather unwise - or even better "uneconomical" in the Ockhamist sense - to discard such a natural explanation. – Alex B. Nov 26 '19 at 13:27
It is possible it was an analogical development. I checked Guus Kroonen's Etymological Dictionary of Proto-Germanic, and he lists Old English beginnan as a direct descendant of PGmc *(bi/du)-ginnaną, a strong verb:
*ginnan- s.v. 'to begin' - Go. du-ginnan s.v. 'id.', OE be-ginnan s.v. 'id.', E to begin, OS be-ginnan s.v. 'id.', Du. be-ginnen s.v. 'id.', OHG bi-ginnan s.v. 'id.', G be-ginnen s.v. 'id.' (EUR?).
He further lists the North Germanic synonym as deriving from *burjaną, which is definitely not its cognate. Furthermore, byrjȧ is attested in Old Norse, and byrja is its descendant in Icelandic, Faroese and western Norwegian, all meaning "begin". The verb begynne is a loan from Low German into the continental Scandinavian languages. Furthermore, Wiktionary lists the Old English verb as beġinnan, obviously showing a palatal /j/. I am not sure what the source of the Wiktionary entry is, but this is a possible sign that analogy had taken place — since it, as a strong verb, must have had a /g/ in the preterite.
The spelling begynnan/ongynnan is unetymological, and would probably not represent an original i-umlauted PGmc. /u/ vowel (since the verb is strong, it cannot be anything like **begunnijaną, though such a weak verb would indeed be well-formed); if anything, it would represent a rare-ish u-umlaut of an /i/, or (far more likely) a hypercorrection or scribal error.
There is nothing contradictory in that it now has /g/; it never inherited the /g/ into early Old English in the first place, but generalised it out of a paradigm that showed a /g~j/ alternation.
Darkgamma
  • 1,427
