Recently I've begun to wonder how many possible forms can be made from a single Japanese verb.
I asked a similar question first on the Japanese Language & Usage site, where I received some comments and answers that surprised me. So I'm expecting interest from a different angle by the linguist types here on this site.
For comparison, typical English verbs have four or fives forms depending on whether they have a regular or irregular past participle but the copula to be has eight forms, not counting archaic forms such as art.
I believe I have also seen the number of possible forms of Arabic verbs calculated before, and that's a language with very complex verb morphology.
Japanese verbs are of an agglutinating type. They are built up by adding various endings onto an invariable root and onto each other. But they cannot be added arbitrarily and surely some combinations are prohibited on either grammatical or semantic grounds. It could be that two differently spelled forms have identical meaning (this happens in Spanish) in which case each counts. There are surely also obsolete and archaic forms or variants which are no longer used in Modern Japanese. These should not be counted.
I'm happy with a number, a description of how to calculate the number, or references to papers or books which address this topic
hippietrail
  • 14,687
  • 146
You know I read this question a bit ago, and later while I was browsing the book The Languages of Japan (Shibatani,1990) I literally happened upon the section (11.4) "The syntax of agglutinative morphology" (chapter 11 grammatical structure). I looked through it a bit and it seems to discuss specifically causative and passive morphology too. To blatantly plagiarize (I don't understand all of it):
Due to the lack of agreement between the head and the dependent constituent, Japanese is not as highly agglutinative as Turkish, especially in the domain of nominal constituents. However, in the realm of verbal constituents, Japanese shows a high degree of agglutination involving a fair number of suffixes in a row. As in many other languages, the order of these verbal affixes is generally fixed, though alternative orders are infrequently observed. In Japanese the following is the typical order:
(1) Vstem-causitive-passive-aspect-desiderative-NEG-tense
All the possibilities are not, of course, exploited in each expression, but the following illustrates some of the lengthy but commonly observed forms:
  • 行かせられない 'go'-CAUS-POTEN-NEG-PRES
  • 行かせられたくない 'go'-CAUS-PASS-DESI-NEG-PRES
  • 歩かせ続けたい 'walk'-CAUS-CONT-DESI-PRES
You might want to check that book out then. I don't know how the morpheme あげく (example 迷ったあげく、彼の誘いをことわってしまった) fits into this form. Are words like this あげく just derivational morphemes, whereas you're talking about inflectional paradigms? Well if (1) completely captures the structure of inflection, then the answer to your question would be counting the permutations by filling in the possible words, right? But I think there is some real complication to computing this maximal set.
Consider how you might actually count the forms though. Say that the total number of causative morphemes is C, the total number of passive morphemes is P, the total number of aspect morphemes is A, the total number of desiderative morphemes is D, and the total number of NEG morphemes is N, and the total number of tense morphemes is T. Then the theoretical upper bound is obviously C*P*A*D*N*T. But obviously not all permutations will be accepted as grammatical by native speakers (for whatever reasons), so we should remove those deemed ungrammatical. We would check the grammaticality of a particular permutation by just asking a native speaker if its grammatical. If it is then we increment the count of forms, if not then we just continue on to the next permutation. However, if some specific permutation is only accepted by some speakers and rejected by others, then its state of grammaticality is manifestly not yes or no, but rather some number 0 to 1 (the proportion of speakers that accepted it). In other words inclusion of a particular inflected form into the set of all grammatical permutations of an inflectional paradigm is fuzzy.
In ignoring the fuzziness, we could include only those forms which are deemed grammatical by a sufficient number of people. In other words we have to define an arbitrary numerical threshold for which we segregate nongrammatical forms from grammatical forms, that numerical threshold being the proportion of a number of speakers.
I have an idea on how one might compute a number that captures the idea of "the maximal number of forms". The set of C*P*A*D*N*T permutations might be slimmed by removing certain permutations on semantic/pragmatic grounds. But then you would need a theory of semantics, and it might only allow us to remove a marginal number of permutations from C*P*A*D*N*T. The point is, that at some point you are going to have to look at real-world data to get this computation done. To keep the computation simple we should aim to minimize theoretical overhead.
There might be a way to do this with data. Fix some verb V for investigation. The data to be collected then consists merely of observed inflected instances of V. For every instance, it will fall into one of C*P*A*D*N*T categories. In other words, you are just counting how many instances of a particular permutation you observe in the data. For example, "行かせられない" forms one of the C*P*A*D*N*T categories. If you happen to hear this exact permutation spoken, say, 5 times throughout an observation session, then the category "行かせられない" gets a tally of 5. We indeed have a large number of categories, C*P*A*D*N*T categories to be exact. Then counting the maximum number of forms amounts to counting the total number of categories that receive a significant number of tallies, dismissing categories that have very low tallies as ungrammatical outliers. So, for example, if every category is filled uniformly, the we can say that C*P*A*D*N*T is the maximal number of forms. On the other hand, if 99% of the instances fall into only 3 categories while the other 1% falls into some other 4th category, then we might have grounds for dismissing the fourth category and concluding that 3 is the total number of forms.
To formalize the procedure, we have C*P*A*D*N*T categories, each category is associated with a tally, and the only thing we have to do is eliminate those categories that have low tally counts. Each time we eliminate a category we subtract 1 from the "maximal number of forms" count, which starts out at C*P*A*D*N*T. But now we are charged with the task of defining exactly the tally threshold for which we will dismiss a category.
And we have just gone full circle. To avoid a "numerical threshold of grammaticality" we circumvented ourselves all the way into a "significance of a tally". And I think this is the inherit problem of your question. To answer it, an arbitrary decision that has no precedence or justification must be made. In fact, this probably the plague of any scientific endeavour, at some point of analysis a decision with no precedence or justification must be unquestionably made. hhhhmmm.... Well, anyways, in summary, I have no idea how many legitimate forms exist for a given verb.
hippietrail
  • 14,687
  • 146
taylor
  • 434
Just because some combinations are prohibited, that doesn't mean that there aren't a whole lot left. If some of the positions in the sequence of agglutinating suffixes is inhabited by an open class, you end up with an upwards unbounded number.
I don't know about Arabic, but it seems to me that it's possible to have a very complex morphology, and still end up with a finite number, if the part you consider a "form" has no open-class morphemes.
This question is all about how you define "form". Do you consider verb root + suffixes (all the way to the last suffix) a "form"?
Are 食べ始める (tabe-hajimeru, start to eat), 食べ終える (tabe-oeru, finish eating), 食べ慣れる (tabe-nareru, get used to eating) etc. forms of 食べる (taberu, eat)?
If yes, then the number is upwards unbounded, since the agglutinated verb is an open class (Not in the sense that anything goes, but in the sense that there's a continuous spectrum from verbs that commonly occur in second position and are completely productive, to verbs which sound marked in the second position and/or are unproductive and only work in some combinations).
If no, you might argue that 食べ (tabe) is the form in play here (the 連用形 ren'yokei of the verb). But then, is 食べます (tabemasu, polite form of eat) a "form"? Polite form is always created by attaching ます(masu) to the ren'yokei.
To me, it seems that the whole exercise of counting verb forms really doesn't seem to make much sense for agglutinating verbs, or at least Japanese. It might make more sense for languages like IE langauges, where
  1. the concept of a word (and thereby a "verb form") is usually easier to agree upon. (With some exceptions: In spanish, are comerme (eat me), comerte (eat you) etc. forms of the verb comer, or are they written as one word as an orthographic convention?)
  2. the endings that a verb can take are a closed class.
So it really comes down to the question of why you want to know. Is it
  1. because you want to know how machines parse Japanese verbs? If so, I don't know and would be interested in answers.
  2. because you are looking to master all forms of the verbs? If so, you could use tools like this one, but the list of included forms will always depend on the creator's subjective choice.
  3. something else?
hippietrail
  • 14,687
  • 146
dainichi
  • 1,564
  • It seems it does depend entirely on the concept of "word". It seems the two major meanings of word for this question would be "orthographic word" and "spoken word". I'm primarily interested in written language and analysis (and generation) by computers. But when something is clearly a mere orthographic convention then the spoken word is equally interesting. But I'm also interested in random comparative linguistic typology, morphology, etc. I would consider a "verb form" to be any length verb which is a "word". It stops where the next word starts. But just inflectional, not derivational. – hippietrail Jul 31 '12 at 06:13
  • I would very much like to see an example of a hypothetical long verb (or better a real one actually used in print) based on these open morphemes so we can get the idea without your depth of understanding of Japanese. Also could this be something like "serial verbs", or "derivation" within the "root" before the "inflection" part of the verb endings? – hippietrail Jul 31 '12 at 06:31
    @hippietrail, not sure what you mean by a "long verb". I am only talking about sequences of 2 verbs, and I'm listing examples of those. If you are looking for sequences of more than 2 verbs, e.g. 食べ終わり始める (tabe-owari-hajimeru, begin to finish eating) definitely makes sense in some contexts. – dainichi Jul 31 '12 at 07:13
  • @hippietrail, your point about derivation vs inflection is valid, but I think it's a common characteristic of agglutination that this distinction isn't clear-cut. For example, 食べられ始める(tabe-rare-hajimeru, begin to be eaten) is grammatical, but doesn't fit your pattern unless you also consider the passive morpheme to be derivational. – dainichi Jul 31 '12 at 07:18
  • Interesting points @dainichi! The agglutinating language I was just studying, Georgian, is very different in this respect. They's no way to incorporate two roots which could be analysed in any way as a single form. I guess not all agglutinating verb morphologies are created equal (-: – hippietrail Jul 31 '12 at 07:49
  • @hippietrail, interesting! To be fair, I think one reason I'm pushing the "it doesn't make sense" point is that I have a personal bias against the "memorizing forms" way of learning (and I don't think it would make sense for a machine parser to memorize all forms either). I remember people in my Spanish class needing their "505 Spanish verbs" book, even to conjugate regular verbs =) This approach makes even less sense to me for Japanese, where so few verbs are irregular. – dainichi Jul 31 '12 at 10:08
  • Please consider this a theoretical linguistics question rather than a question of how best to learn (-: – hippietrail Jul 31 '12 at 10:12
  • From what I've learned from your comments, I wonder if the Japanese verbal system is ever analysed as being polysynthetic? Maybe the basis for a good follow-up question? – hippietrail Aug 01 '12 at 09:39
  • @hippietrail, regarding your two definitions of "word", you may already be aware of this, but Japanese orthography doesn't employ spaces, so the concept of "orthographic word" is probably not relevant in this case. – musicallinguist Aug 03 '12 at 12:56
  • Japanese doesn't employ spaces but I'm pretty sure literate Japanese speakers still have a concept of orthographic word ... it might stand up to less analysis than in other languages though. It seems some morphemes within the verb complex are not traditionally considered to be particles (words) but that this leads to a situation where one verb can contain multiple roots. – hippietrail Aug 03 '12 at 13:05
  • @hippietrail, the idea that a speaker would have intuitions of an "orthographic word" independent of orthography doesn't make sense to me. Check out the quotes from Bauer (2000) and Sproat et al. (1996) on this wiki page. – musicallinguist Aug 03 '12 at 17:40
  • I didn't say independent of orthography, but independent of whether the written language uses spaces between words. Even I have some intuitions such as that for a verb it could start with a "head" that could be a) one or more katakana or hiragana characters or b) one or more kanji, possibly with some intervening hiragana, followed optionally (always?) by a tail consisting only of hiragana and terminating with one of several possible recognizable endings such as "-mashita". After such hiragana tail, a kanji or katakana is definitely not part of the same word (following hiragana is harder). – hippietrail Aug 03 '12 at 18:18
    Ah, OK. So this is just a terminological issue. I thought you were using the term in the more traditional sense of word boundaries being explicitly demarcated orthographically (usually with spaces). – musicallinguist Aug 03 '12 at 23:02
