I am trying to understand the function of double (?) nasals in Lycian. Usually an /ñ/ is followed by /n/ and so does /m̃/ which is followed by an /m/. What was the function of this spelling in Lycian? Did they really try to produce both nasals or is it an attempt to render a nasal that has lacked a letter.
Midas
  • 2,522
    Those were originally perhaps syllabic [m] and [n], later coda [m] and [n]. – Yellow Sky Jun 24 '18 at 15:19
    Good question! I've also seen them listed as syllabic nasals, but they almost always precede normal and . I don't know Luwian very well, but it's entirely possible that <m̃m> and <ñn> were their ways of writing the syllabic nasals. – Draconis Jun 24 '18 at 22:20
Kloekhorst 2008 writes the following:
"the difference between /n/ vs. /nn/ and /m/ vs. /mm/ is only relevant in initial and intervocalic position. In all other cases the ‘geminate’ spellings with -ñn- and -m̃m- are automatic and directly comparable to the geminate spellings of the other consonants (p. 128).
He also provides an extremely useful chart:
If I understand Melchert 1994 correctly, this gemination could be viewed as "continuants spreading across a syllable boundary" (p. 265), e.g.
Arm̃ma- = [arm.ma-] < /arma-/
If such a cluster was in initial position, then an anaptycic vowel was insterted there:
km̃mi- [kəm.mi-] < /kmi-/
Alex B.
  • 8,744
  • Thank you very much! The chart link is broken though. – Midas Jun 25 '18 at 10:06
  • @Midas Which link doesn't work for you? Kloekhorst 2008? – Alex B. Jun 25 '18 at 16:53
    Forget it. I was refering to https://i.stack.imgur.com/rdfXP.png I am temporarily in a country that tends to block various internet resources. I logged remotely to a computer at home and I can see the image. You don't need to edit anything. :) – Midas Jun 25 '18 at 19:22
