I’m a freshman who is taking Introduction to Language classes at my college. I’m struggling to answer a question but my mind gets confused.
My question is: When the word “secret” becomes another word “secrecy” (or when vacant becomes vacancy), there is an insertion of “s” as far as I can see. However, when the word “modest” becomes “modesty” there is no insertion or what so ever. What is the rule behind the derivation of these words?
Thank you so much.
wjandrea
  • 125
ayse
  • 55
Modest ends in /st/, unlike vacant or secret
If we assume that secrecy, vacancy and modesty all contain one derivational suffix (the same for each), along with one base morpheme each (the adjectives secret, vacant and modest respectively), and that the form of each of these three nouns is given by some morphological rule, then the most likely explanation is that modesty ends in /ti/ rather than /si/ because of the presence of the consonant cluster /st/ at the end of the base modest.
This is probably the answer you are supposed to give.
Challenging some assumptions
The assumptions mentioned in the first paragraph may be a bit problematic. English has more than one morpheme used for deriving nouns from adjectives: this is shown by the existence of multiple nouns that correspond to the same adjective such as falsehood/falsity/falseness. And even when we're dealing with nouns that are formed from adjectives by suffixing the same derivational morpheme, there is no guarantee that there will be a reasonable rule that accurately predicts the phonological form of all of the nouns based on the phonological form of the adjective. For example, for many speakers the nouns clarity and sincerity do not rhyme, even though the corresponding adjectives clear and sincere do rhyme: there is no way of explaining this by phonological rule (unless you resort to something ad hoc).
The historical basis of these forms (which is almost certainly not the same as any synchronic rule that could be used to explain these forms)
From a diachronic perspective, /t/ is present in modesty but not in secrecy and vacancy because of a postclassical Latin sound change that turned t into the affricate [ts] before [j], except for when the t was in a st cluster. As far as I know, this was (at this point) a purely phonologically conditioned process. The effects of this process are also seen in various English words ending in -tion, -tious, -tial, -tian or -ce (e.g. relation, nutritious, partial); note that we see different pronunciations for words ending in -stion, -stial, -stian (e.g. question, bestial, Christian).
It's clear that English does not have any purely phonologically conditioned process like this that changes the t from secret to /s/ in secrecy. There are many examples of /ti/ in English, including after schwa or /n/ (e.g. ability, puberty, maggoty, certainty).
But your question brings up the topic of "morphophonological" rules. As far as I know, the exact meaning of "morphophonology" is a bit unclear, but we can say that it involves both morphology and phonology. In particular, "morphological" rules are often described as only applying in "derived environments", which would allow us to ignore words like certainty where the /ti/ sequence occurs within a single morpheme (the suffix -ty). Maggoty has /ti/ in a derived environment, but there are other parts of morphological theory that I think could be used to explain away this fact.
I won't try to pursue this in more depth though because even though it seems theoretically possible that English has a synchronically active morphological rule that turns t into /s/ in secrecy based on some aspect of the phonology of the suffix -y, it seems unlikely to me. I just don't think there's that much evidence for the existence of such a rule:
  • Obviously, in its surface form “secrecy” does not contain /j/ after the /s/. We also see /s/ that is word-final (on the surface, at least) in words like silence. So the conditions that applied for this sound change in Latin do not apply on the surface in English. We could try to formulate some very abstract analysis that derives both secrecy and silence from "underlying" forms containing /j/, but it's not straightforward to come up with appropriate underlying forms, and it might not really be "worth it" in terms of the amount of explanatory power such an analysis provides. See user6726's answer to my question What are current perspectives on analyzing word-final /i/ in English words like "potency" as synchronically derived from /j/?
    It seems to me that it would be simpler to just say that in the morphological system of Modern English, the phonological form of the (assumed) suffix -y is unrelated to the fact that it selects for the /s/-final allomorph of "secret" (and "vacant", etc.).
  • The nominalizing suffix found in secrecy is not very productive in modern English, and the fairly recently coined example of normalcy (along with the standard spelling of bankruptcy) suggests that some people think of -cy as a suffix. This raises the possibility of an alternative morphophonological analysis where the /s/ is part of the suffix, and the t is deleted rather than palatalized. That's not the diachronic origin of the form, but as a synchronic explanation, it seems fairly plausible (consider that many -cy words are -ncy words, and the contrast between /nts/ and /ns/ is neutralized for many English speakers). See Greg Lee's answer to this English SE question: What are the rules to pronounce the suffix “-tion” in English, “/-tʃən/” or “ʃən”? If this explanation is correct, than there is no need for a rule that turns t to /s/ before -y.
    I'm not totally sure how to explain modesty according to this model; one option might be to say that it has been reanalyzed as containing the suffix -ty, which is historically the source of the -ty in the similar-looking word honesty (from Latin honestas/Old French honesté). Or we could just say that it has -y, since there are still words like recovery or villainy that show -y as a nominalizing suffix.
    One problem for the t-deletion analysis as well as the t-fricativization analysis is the existence of the word baronetcy, with /ts/.
brass tacks
  • 18,116
  • 45
  • 91
First of all, it's morphophonology question. Secondly, there is no insertion, that you realize there is fricativization, in other words [t] → [s]. Thirdly, don't take it granted that there is a definite rule for that in English. Your teacher wants you to analyze the data given, not to find out the general grammatical rules of English.
About the data given, well, you have not written them down in here. I came up with some data myself:
secret /sikrət/ → /sikrəsi/
private /praɪvət/ → /praɪvəsi/ (US)
pirate /paɪrət/ → /paɪrəsi/
vacant /vekənt/ → /vekənsi/
decent /disənt/ → /disənsi/
celibate /sɛləbət/ → /sɛləbəsi/
might /maɪt/ → /maɪti/
modest /madəst/ → /madəsti/
honest /anəst/ → /anəsti/
According to the data given, one could come up with the result that if alveolar voiceless plosive is preceded by a schwa or alveolar nasal and proceeded by high front tense vowel, it turns into a fricative one. Elsewhere, it stays the same. The category including both schwa and [n] is called sonorant, but since it also includes [ɪ] this wouldn't explain it. If the data given doesn't have "mighty" as an example, one could say fricativization occurs in the environment of sonorants preceding the [t] in question.
Yanek Yuk
  • 176
  • [t] → [s] / .... ___ [i] Then, what should i write down the ... ? I can't write a C or a V because it could be either of them. – ayse Dec 03 '18 at 16:13
    [n] or [schwa] or the category that includes them. – Yanek Yuk Dec 03 '18 at 16:15
    Might > mighty is confounding data; the first is a noun, the second an adjective. The general pattern is the opposite. – Michaelyus Dec 03 '18 at 16:57
  • Oops! Thanks for pointing that out. Do you think then it is safe enough to assume fricativization occurs after sonorants? – Yanek Yuk Dec 03 '18 at 17:00
  • The existence of words like “normalcy” and the spelling of “bankruptcy” suggest that despite the etymology, modern English speakers may think of the suffix as /si/. – brass tacks Dec 03 '18 at 22:27
  • "Morphonogy" is a term in use. Sumelic's suggestion seems right to me. – Greg Lee Dec 04 '18 at 15:19
  • If take sumeris's approach we might as well think the morpheme being {-si} then "modesty" and "honesty" undergo deletion because they already have [s] before [t]. – Yanek Yuk Dec 04 '18 at 15:24
  • @YanekYuk: From an etymological perspective, honesty ends in the suffix -ty. I guess that could be an alternative (non-etymological) analysis of the word modesty. – brass tacks Dec 04 '18 at 21:55
It isn't just the insertion of an /s/, it is the change of /t/ to /s/. This change is conditioned by the preceding sound(s); it does not happen for /st/, and it happens for /Vt/ (where V is an arbitrary vowel).
Sir Cornflakes
  • 30,154
  • 128
  • but what about the word vacant? /n/ precedes /t/ but it's a consonant. – ayse Dec 03 '18 at 15:55
    Fricatives block the rule., glides and nasals don't. – user6726 Dec 03 '18 at 16:15
  • And what about “normalcy”? – brass tacks Dec 03 '18 at 22:27
  • @sumelic normalcy is a strange one, and it is later (historically) and rarer than normality according to Google ngrams: https://books.google.com/ngrams/graph?content=normalcy%2C+normality&year_start=1800&year_end=2000&corpus=15&smoothing=3&share=&direct_url=t1%3B%2Cnormalcy%3B%2Cc0%3B.t1%3B%2Cnormality%3B%2Cc0 – Sir Cornflakes Dec 03 '18 at 22:47
  • @user6726: Do you have any example for a fricative different from /s/ (the main candidate would be an f, but I cannot come up with any -ft vs. -fty or -fcy example)? – Sir Cornflakes Dec 05 '18 at 09:10
  • @ayse vacant/vacancy adds another rule to the ruleset. I don't know whether difficult/difficulty is part of the sample you are analysing–this would add another rule. – Sir Cornflakes Dec 05 '18 at 14:10
  • Since y comes from Latin, which didn’t have ft clusters, I don’t think it’s likely that there are any candidates for -fcy or -ft-y nouns. “Safety”, a -ty noun, has /ft/ in pronunciation, although not in spelling, since it is not Latinate in form. – brass tacks Dec 06 '18 at 00:49
