In biology, ring species is a population of subspecies in a geographically ring-shaped region, where individuals are close (in terms of interbreeding) if they live close to each other, but between the two "ends" they don't get along. Below is the distribution map of birds Phylloscopus trochiloides, where western subspecies (blue) and eastern subspecies (red) went too diverse to interbreed.
The obvious linguistic equivalent should be dialect continuum, a population of language(s) with spectrum of mutual intelligibility. But for the "ring" part, it should be a ring-shaped region where the speakers from both "ends" don't understand each other even though they are geographically close each other. Is there such one?
puzzlet
  • 405
    Also asked on [worldbuilding.se]: https://worldbuilding.stackexchange.com/q/147043/19004 – Sir Cornflakes May 15 '19 at 10:32
    No, because the overlapped ends when the ring is closed can't breed together in a ring species, while the overlapped dialects when a dialect ring is closed (as it well may have been, here and there) are just more neighboring dialects. Organisms only have one genome and can only breed with it, but people can have many languages and communicate in all of them. – jlawler May 15 '19 at 18:34
I don't think there are any ring languages, and I can explain why it's unlikely.
Remember that language evolution is only roughly the same as biological evolution, and the line between languages is only roughly the some as the line between species.
One big difference is that there just aren't nearly as many living languages as there are extant biological species, by orders of magnitude. Since the classic example of ring species is the Larus herring gulls, let's look at them as an example. There are many Arctic bird species. A few of them cover the whole circle. Of those, one, the Larus gulls, form at ring species. By contrast, there are only a handful of Arctic languages, and the widest-distributed small family is Eskimo-Aleut, which doesn't go any farther than from the Russian Aleutian Islands to eastern Greenland. So there's no opportunity for a ring language to form.
Also, many species share the same environment, in different niches, but languages are mostly all competing for the same niche. The fact that herrings spread around the Arctic means it's more likely for herring gulls to spread into the same territory. By contrast, fact that Samoyedic languages spread around the Arctic means it's less likely for Tungusic languages to spread into the same area.
So, the most widespread language family around the Arctic ends up being Eskimo-Aleut, which only goes from the Russian Aleutian Islands to eastern Greenland. (In Siberia, where there's more competition, the continuua are much narrower than that.)
There are places where you can find smaller rings of species, like your Himalayan example, but the same factors, and others, make it less likely to find rings of dialects.
Let's look at an example that superficially looks promising: Scandinavia. Finnmark Nordnorsk and Far Norrlander Swedish dialects are not mutually intelligible. But there is a chain of pairwise-intelligible Norwegian dialects all the way down and around the coast of Norway, and a chain of mutually-intelligible Swedish dialects all the way down the coast of Sweden. At the bottom, the southern varieties of Standard Norwegian are pretty close in intelligibility to Scanian Swedish, to the point where (if you wanted to annoy a lot of people) you could almost claim they were dialects of Danish.
But as soon as you look beyond the coasts, you'll see that the traditional inland northern Swedish and Norwegian dialects share features with each other. When species send out branches into thinly-populated areas, they tend to lose contact and diverge, but when languages do, they're carried by people who move back and forth.
Also, there's a constant pull on both dialects by their respective standard varieties—especially strong in recent times—which is part of the reason they're as divergent as they are.
Also, some of the Finnmark dialects aren't divergent just because Nordnorsk speakers keep moving farther north; much of the change comes from other people (mostly Sami) learning Norwegian as a second language, a kind of "horizontal transmission" that you don't see in higher animals in biology.
So, a ring seems likely to form only if the center of the ring really is nearly uninhabitable, if the language doesn't have writing and mass media, and if there's nobody else in the way.
Such a situation could arise somewhere in, say, the highland Trans New Guinean languages. But it would happen a lot less often than with biological species. And, even if it did, there's a good chance we'd never find out—the only way we could detect a highland TNG ring would be if we discovered and classified all of the languages before contact changed the map.
abarnert
  • 2,625
    @J-mster The Russian Aleutian Islands are the part of the Aleutian Island chain (the chain running across the Bering Strait) that are politically part of Russia. Mostly equivalent to the Komandorski Islands, and to the district of Aleutsky in Kamchatka Krai. That's where Nikolskoye is, which I believe is the farthest west any Eskimo-Aleut languages are natively spoken. – abarnert Jan 28 '19 at 23:27
Abarnert laid out quite nicely the reasons why this doesn't really happen. But you do sometimes get "rings": they're just a whole lot smaller and form for different reasons.
In northern Iberia, for example, the local Romance languages form a naturally-evolved dialect continuum from east to west. But in the south, there are hard boundaries between them. This could be seen as a very small ring.
The reason for this is politics rather than evolution, though. The southern Romance dialects (like Mozarabic) got displaced by Arabic during the conquest of al-'Andalus, and then Arabic was displaced by Romance again in the Reconquista. But by that point each of the Christian kingdoms had a national language, and the hard political boundaries between them didn't allow the natural dialect continua that formed in the north.
Draconis
  • 65,972
  • 141
  • 215
Possible, yes, but I don't know an example. But the following comes pretty close to it:
The Slavonic languages on the Balkans form a somewhat broken ring, almost encircling the Hungarian and Romanian language area: Going counterclockwise from Ukrainian via Ruthenian and Slovak to (first gap in the ring) Slovene, Croatian, Serbian, Macedonian and Bulgarian there is a dialect continuum. Between Bulgarian and Ukrainian is the second gap in the ring, when it were closed along the Black sea coast, Bulgarian and Ukrainian would exhibit a hard language boundary.
Sir Cornflakes
  • 30,154
  • 128
I find dutch-german to be a single ring language:
As a dutch speaker i can easily communicate with speakers of low german. Higher german is more difficult. Austrian german yet more so. But when i speak to a swiss german, we cannot understand one another at all. Yet the swiss german can be understood by an austrian german.
So high and austrian german share mutual intelligibility with both dutch and swiss german. But dutch and swiss german are not mutually intelligible.
Keep in mind that Im only defining the continuum in mutual intelligibility, not in official language designations, since those are sociopolitically defined and therefore inaccurate for pure scientific purposes. By definition of mutual intelligibility, Dutch and german are a single language, as are portuguese and spanish.
    I think this does not answer the question: That two ends of a dialect continuum behave as mutually unintelligle languages is not the point here, it is about the geographical ring shape that makes a contact between the two ends. – Sir Cornflakes Nov 19 '20 at 11:47
    Dutch and Swiss German are not geographic neighbours – they’re about as far apart as you can get in the available area… – Janus Bahs Jacquet Nov 19 '20 at 15:18
