The clusters /pr/, /br/, /kr/, /gr/, /tr/, /dr/, /pl/, /bl/, /kl/, /gl/ are all pretty common. But why are /tl/ and /dl/ missing? Is there any linguistic or historical explanation?
Maigo
  • I did see that post, but the discussion there is rather long and seems rather indecisive. – Maigo Jan 28 '19 at 23:58
The simplest explanation is that Proto-Indo-European did not have words with resolute initial *tl,dl,dhl, and there were no sound changes that created such clusters in most of our dialects (there are dialects where kl became tl, but they aren't well-known).
A related question is whether there is anything in the grammar of English that reflects this gap. It is also claimed (Clements & Keyser 1983) that English has a syllabification filter that prevents [tl,dl] in the onset – thus no words with initial "tl,dl". Actually, there are some, sort of, taken from other languages. In a small handful of cases, we are presented with "tl,dl", the best known example being Tlingit (the initial consonant is ɬ); other examples are Tlaxcala, Dlugos or Dlugosz, tlayuda. I believe that it is traditional Alaskan English to pronounce Tlingit as [klɪŋkɪt] (every traditional Alaskan that I know does so), but I believe that you have at least a 50% chance that other speakers of English would pronounce one of those tl-words with tl and not an epenthetic vowel or conversion to [kl]. I also suspect that this is because of Nahuatl influence, and does not apply equally to "dl". By way of contrast, English speakers cannot handle initial [ŋ] as in Nguyen, nor initial [nd, nt, nk, ng, mb, mp] where a vowel is inserted (Nkomo → [ɪnkomo, nəkomo]). The "can you say it?" test is at best weak support for a synchronic syllabification constraint (since some speakers may pronounce Tlaxcala with [kl]).
There is better evidence that there is an active constraint against [tl] onsets in English. In words like "atlas", /t/ is glottalized or even reduced to [ʔ], depending on dialect, following a rule that affects /t/ in syllable-final position. The syllabification [æt.ləs] is to be contrasted with [mæ.trəs] "mattress", likewise "gently" versus "gentry", with glottalization in the formwe and not the latter. The reason for the difference is that given an intervocalic consonant cluster in a stressed-unstressed frame, the longest possible sequence of consonants becomes an onset, so tr becomes an onset. Under the hypothesis that [tl] is not an allowed syllable onset, we predict that only [l] can go in the onset of the syllable, and [t] must be relegated to the coda of the preceding syllable.
user6726
  • 83,066
  • 63
  • 181
  • Thanks for the explanation! Can the absence of /tl/ and /dl/ be explained by the dispreference for clusters consisting of two consonants pronounced with the same place of articulation? – Maigo Jan 29 '19 at 01:06
    I would say not, because that would predict that you also can't have "snow", "stick", "drive", "try"; plus you get all of those clusters, parsed into separate syllables (i.e. at best it's about sequences in the same syllable). Also note "fault", "bold", "pant", "bind"... order matters. – user6726 Jan 29 '19 at 01:35
  • The explanation in the first paragraph assumes that all English words descend from PIE, but that's far from being the case. – TKR Jan 29 '19 at 21:35
  • The overwhelming majority do, and I mentioned the most salient examples of non-IE loans (plus Dlugos), virtually none of which have initial tl,dl. I don't think there are any non-IE dl-initial words. All borrowed tl-initial words are very recent, and I doubt that more than 20% of English speakers know the word "Tlingit", the best-known of that set. – user6726 Jan 29 '19 at 21:42
  • As pointed out in the other answer, Nahuatl tl-onsets are usually analyzed as a single lateral affricate /tɬ/ rather than a cluster /tl/, and at least according to Wikipedia the same is true for Tlingit. Dlugos, on the other hand, I'd assume is a borrowing from a Slavic language. Couldn't that be a more important difference than anything inherent in English phonotactics for /tl/ vs. /dl/? – abarnert Jan 29 '19 at 22:21
  • @abarnert: I think that the use of the English cluster /kl/ as a substitute for Tlingit "tl" suggests that whichever English speakers first started making this substitution thought of the "tl" as a cluster. – brass tacks Jan 29 '19 at 22:29
  • OK, so the reason Slavic dl- names aren't substituted that way is… recent borrowing from a "very foreign-sounding" language like Nahuatl or Tlingit vs. a "less foreign-sounding" one like Polish or Russian? If so, that seems plausible, but aren't there any dl borrowings from "very foreign" languages or tl borrowings from "less-foreign" ones to test that? – abarnert Jan 29 '19 at 22:43
  • @abarnert: I think that because of the scarcity of dl- borrowings, there isn't any clearly established way of adapting them to English phonotactics, as there is for the word "Tlingit". For me at least, the /kl/ pronunciation of that word is familiar because it is used by other English speakers, not because I myself have adapted the Tlingit "tl" to /kl/. I don't know whether specific English speakers with the name "Dlugos(z)" have established anglicized pronunciations; I would guess that some of them do. – brass tacks Jan 29 '19 at 22:51
I cited Blevins and Grawunder (2009) in a recent answer (to the question Are /tl/ and /dl/ rare onsets worldwide?), and I think that this source has some relevant things to say that I will summarize here.
Diachronic absence seems "accidental"
Specifically, in terms of history, Blevins and Grawunder say that Proto-Germanic lacked *tl and *dl onsets (p. 284). Proto-Indo-European had sequences of *t or *d + syllabic lateral (examples given: "*dl.h1ghós ‘long’, *tl.-né-h2- ‘lift.present’ "), but a vowel was inserted before syllabic resonants in Proto-Germanic. Blevins and Grawunder also mention the possibility of "rare" *tl onsets, "as in *tl@-ro- ‘high’(Orel 1998: 214)" (p. 289).
There doesn't seem to be any particular historical change that we can identify as being responsible for the absence of onset /tl/ and /dl/ in inherited English vocabulary; e.g. I don't know of a class of native English words that used to have tl- or dl- which became something else through a sound change.
In contrast, there is fairly clear evidence in Italic languages for various sound changes that got rid of tl or dl. This is only directly relevant to English in that a substantial portion of English vocabulary is borrowed from Latin or a descendant language; if Latin or French did have tl or dl onsets, they might have been introduced to English by such borrowings, but since they didn't, that couldn't have happened.
Word-initial /tl/ in borrowings
Word-initial /tl/ does exist in a few Ancient Greek words/names, and my impression is that it may be used on the rare occasions when people pronounce these in English; e.g. the initial "t" in the name Tlepolemus (Tlepolemos).
user6726's answer mentions other languages that have served as recent sources of tl-initial words in English.
Possible explanations for a synchronic rule
In terms of possible synchronic explanations, see page 287 (bold parts are summaries of information from that source, non-bold parts are my own commentary):
  • Blevins and Grawunder say that the Obligatory Contour Principle could play a role: this is where the idea of a dispreference of some kind for clusters of consonants with the same place of articulation.
    Obviously not all such consonant clusters are prohibited in English, but I think user6726's comment isn't particularly convincing as an argument against the relevance of this concept. The clusters sn- and st- start with s, which is known to show special behavior in combining unusually freely with a following consonant in English. The clusters dr and tr are indeed homorganic, so they seem more relevant.
  • There is a separate idea that /l/ in English is less sonorous than /r/, which could help explain why /tr/ and /dr/ onsets are allowed but /tl/ and /dl/ are not (Blevins and Grawunder cite Moreton 2002: 56–57 for this point).
    "Sonority" by itself doesn't seem to explain why we still see pl, bl, kl, gl, fl clusters, though.
  • There is perceptual similarity between /tl/ and /dl/ clusters and /kl/ and /gl/ clusters.
    I'm not super convinced by that last point: it seems a bit circular to me, since the perceptual confusion seen in studies of e.g. French and English speakers is certainly influenced by the phonotactics.
Word-medial /tl/ and /dl/
Of course, /tl/ and /dl/ do exist word-medially in English. Whether or not they are onsets depends on how you divide a word into syllables; unfortunately, there are a lot of different approaches to English syllabification.
In native English vocabulary, word-medial /tl/ and /dl/ arises at morpheme boundaries; e.g. in suffixed words such as wit-less, wet-ly, ghost-like or heed-less, friend-ly, child-like, or in compounds such as land-lord, wet-land.
There are also words where these sequences have arisen from syncope of a vowel in a word-medial unstressed syllable. This syncope is optional in synchronically inflected forms of verbs that end in /əl/, such as battling, settling, huddling. The word butler is historically derived from syncope, but can only has /tl/ in modern pronunciation. The "t" in "butler" can be glottalized, which may imply the syllabification "but.ler".
Word-medial /tl/ in classical vocabulary
Morpheme-internal intervocalic /tl/ is encountered in some words in the learned stratum of vocabulary that come from Greek. The example in user6726 's answer, atlas, falls into this category. Because of issues relating to how stress interacts with syllabification, I think a more relevant set of words for a discussion of English onset constraints is Atlantis, Atlantic, Atlanta (all stressed on the second syllable): as far as I know, no native English speaker pronounces these words/names with a tl- onset in the second syllable.
This might show a constraint against tl- as an onset, although it might just be accidental. English syllabification does not always maximize onsets, even before stressed vowels. For example, English clearly has pl- as an onset, but there may be speakers who use /p.l/ in the word "haplology": the American Heritage Dictionary gives the syllabification hap.lol.o.gy, although Merriam-Webster gives the syllabification ha.plo.lo.gy. (The distinction between medial /.pl/ and /p.l/ would be realized phonetically in terms of greater aspiration, or greater devoicing of /l/, in /.pl/.)
brass tacks
  • 18,116
  • 45
  • 91
  • For Wells' explanation of word-medial /tl/, what happens with "atlatl"? For the final tl, the second vowel is stressed, so we try to maximize the coda after it, but /tl/ isn't a valid coda, so we end up adding an extra syllable. But for the medial tl, the first vowel is unstressed, so there's no reason to maximize the coda, so that seems to predict a.tlat.l, even though I suspect most monolingual native English speakers actually say at.lat.l. (Although I don't know that a.tlat.l is any more surprising than mattr.ess…) – abarnert Jan 29 '19 at 22:40
  • @abarnert: maybe "Atlanta" would be a more commonly encountered example. I don't have "atlatl" in my ordinary speaking vocabulary so I would be tempted to pronounce it as a foreign word, with an approximation at non-English phonotactics. – brass tacks Jan 29 '19 at 22:42
  • @abarnert: And you're right that the syllabification of such words does seem to be related to the issue of permissible onsets. – brass tacks Jan 29 '19 at 22:43
  • You're right, Atlanta seems pretty clearly to break up the t.l despite the vowel being unstressed (and the diachronic difference between Greek and Nahuatl as sources probably doesn't matter in English pronunciations, especially given that the Greek morphemes are a + tlas, not at + las, anyway…). – abarnert Jan 29 '19 at 22:51
  • What about the fact (based on a single anecdotal experience, so maybe the answer is just "one man's idiolect"…) that a Mexican English pronunciation of a.tlan.ta sounds a bit weird but easily understandable (and reproducible) to American English, while a Mexican Spanish a.tlan.ta sounds completely baffling to Castilian Spanish? That seems to imply that if English does have a /tl/ onset violation, it's not a very strong one (as opposed to Castilian). – abarnert Jan 29 '19 at 22:54
  • Thanks for the answer! I still have a question: "a vowel was inserted before syllabic resonants in Proto-Germanic" -- wouldn't this be a "particular historical change that we can identify as being responsible for the absence of onset /tl/ and /dl/ in inherited English vocabulary"? – Maigo Jan 30 '19 at 02:47
  • @Maigo: That sound change wasn't specific to /tl/ and /dl/: we see the same kind of vowel insertion in words like full, from a PIE form starting with something like * pl̩h₁n-. But English nevertheless has words starting with fl- alongside words like full – brass tacks Jan 30 '19 at 02:51
