What makes schwa so special? On my phonology exam my tutor phrased the question something like: Why is schwa the ruler/king of vowels? I don't know what he meant by this but I suppose it's got something to do with the fact that all vowels tend to reduce to schwa before they disappear... What are your thoughts on this? How would you answer this question?
3I'd suppose that schwa is the basic vowel. Vowels are perceived in contrast to each other, arguably schwa in the middle of the diagramm, lacking any kind of modulation except for the vocal chords, may be the base truth for such contrast. You can get even less modulation from a voiceless breathing all the same, so I don't think it's correct to call schwa the mother of all vowels, semivowel onsets and offsets, glides and what not, but that's besides the point. If the question refered to specific material from the course, and if you missed it, we cannot help you. – vectory Feb 03 '19 at 17:47
When I pronounce this vowel, I would say it is the only one where there is absolutely no contraction of any muscle (except vibrating vocal chords) or any change in the mouth/throat/larynx/pharynx, and the tongue is simply relaxed. I just open the mouth and it's the sound that comes naturally.
So I suppose it is justified that it has the central place in the IPA diagram.
This central place corresponds to the vowel with the least alteration, the softest, the most relaxed: it is the most lenient vowel.
- 652
- 6
- 18
4This should be the accepted answer. Schwa is the most lenient vowel, and is present arguably in every language, phonemically if not phonologically. It does not have to be short, as @user6762 states; long schwa is still a schwa. – kkm -still wary of SE promises Feb 03 '19 at 17:40
@kkm the answer did without your comment not explain why schwa ruled or sired other vowels. – vectory Feb 03 '19 at 18:15
@kkm thx for the precision. I have edited and added your information in the answer. – Stephane Rolland Feb 03 '19 at 19:29
If schwa is basically special because it's the grunt we make when the mouth is open, is there a consonant that is special because it's the grunt we make when the mouth is closed? – Feb 04 '19 at 23:01
@BenCrowell hmmmmmmm I don't know ;-) Could it be
mwith voicing? orhwhen only breathing out ? – Stephane Rolland Feb 05 '19 at 01:02 -
The "consonant that would be special" would be the thing spelt humph or hmph in comic speech balloons, no? – Will Crawford Feb 08 '19 at 18:36
@WillCrawford At first I did not agree for the fricative
[f]sound at the end of "hmph". There's clearly a move to put teeth on the lips so as to pronouce it. But the more I play with it: when the breathing out is strong enough, there's clearly a[f]sound that starts to appear... – Stephane Rolland Feb 08 '19 at 19:31 -
This is a framework-dependent question. My guess is that he is referring to the representation of schwa, and the premise that it is "featureally empty". That is, front vowels have a frontness property, back vowels have a backness property, and round vowels have a rounding property. Schwa has none of these. That brings us down to the central unrounded vowels [ɨ ə ɐ] (and some other ancillary letters). The proper treatment of vowel height has been inconclusive, but it seems clear that the first cut is between high and non-high, and the low central vowel can be excluded as having an additional lowering feature. There is a line of reasoning that mid vowels are "more marked" than high vowels which would suggest that really [ɨ] is that special vowel that has no features at all. A typical caveat about "schwa" is that, many times, people use the letter "ə" when the vowel in question is in fact closer to [ɨ]. The claim that strict IPA [ə] is structurally special is untenable, on formal phonological grounds.
One phonetic story is that the formants of the vowel schwa are closest to those predicted for a uniform tube, with no constrictions. A second one is that it is extremely short (though there is a chicken-egg question here whether we call a vowel schwa because it is extremely short, or does being extremely short yield the formant quality associated with schwa?). In English for example it has less than half the duration of stressed [ʌ], and in a number of Austronesian languages (with no length contrast) it is also very short. There are certainly schwa-like vowels that are not highly reduced, what is not clear is whether by professional IPA standards those vowels are [ə] or [ɜ ɘ ɤ ə̹]. You can compare Ladefoged's performance of [ʌ] with his [ə], [ɜ] and [ɘ], and then match those standards against supposed schwa in some other language. I don't know of any IPA doctrine that says that "ə" can only be used for extremely short vowels, but it is a widely reported property attributed to "schwa", presumably based on ignorance of languages where a schwa-like vowel is of equal prominence to other vowels of the language. In the case of non-rhotic pronunciations of "bird", it is generally held by phoneticians that this is [bɜːd], not [bəːd]. I don't have a candidate for long schwa where the quality is IPA [ə] as performed by Ladefoged and others.
The claim that schwa is the king of vowels is a cute metaphor for something, good luck figuring out what. I would say that it is the meekest vowel, if I were inclined to talk that way.
- 83,066
- 4
- 63
- 181
1Show me a king of vowels and I'll show you an emperor with no clothes on :) – Luke Sawczak Feb 03 '19 at 17:43
it is extremely short -- surely not by definition? You can have a long or a short [ə]. – TKR Feb 03 '19 at 18:50
4@vectory It's like Bellos' joke that "247 is fascinating because it's the first completely uninteresting number". – abarnert Feb 03 '19 at 21:32
@TKR The claim might just be about English. If it's cross-linguistic, I suspect schwa would have the shortest average length, because there are many languages that have no morphemes with explicit /ə/ in them but have [ə] in reduction and/or epenthesis, and some of those languages are stress-timed, so what else is likely to average anywhere near as short? But yeah, the article should explain what it means. – abarnert Feb 03 '19 at 21:39
@abarnet I'd like to think it's more like a zero for vowel harmony, if a vowel won't be colored by a neighbouring schwa. Hence a/the should both have schwa and have little effect on following pronounciation, while German der/die/das/dem/den/ein/eine etc. cause ... something. I mean sg. der Mann but pl. die Männer. Consequently the same should be seen next to an/the. I'm speculating of course. – vectory Feb 03 '19 at 21:52
1@vectory Umlaut in die Männer isn't due to the definite article, but to the case ending. – TKR Feb 03 '19 at 23:07
@TKR the fact that man and men have become homophone speaks for my notion, though. Well, hardly. It would follow that invariable the should preserve the sounds, so there must be more to men. – vectory Feb 03 '19 at 23:12
@abarnert I was obviously replying to your comment on uninteresting numbers. – vectory Feb 03 '19 at 23:35
It depends if you're talking about phonology or phonetics.
In articulatory phonetics, "schwa" is often used as the name for the completely relaxed vowel with no particular constriction in the vocal tract. (Whether this actually corresponds to [ə] on the IPA chart is up for debate: the IPA vowel chart predates spectrograms, so it's defined in terms of "what things sound like" rather than formant frequencies we can measure.)
In this case, it's special in that it's the center point that you define all vowels in relation to. /a/ has a lower first formant, while /e/ has a higher second formant, etc.
In phonology, "schwa" is generally used as the name for a reduced vowel of any sort. The name itself comes from the Hebrew marking for an "extra-short" vowel (comparable to Slavic ь and ъ). So the idea that all vowels reduce to a schwa is kind of a tautology. When a mid central vowel isn't just something else reduced, the phonologists tend to give it another name: that's why "butt" is transcribed with /ʌ/ in most English traditions, even though the vowel is not particularly low or back: because it's not a reduction, and therefore can't be "schwa".
- 65,972
- 3
- 141
- 215
Is completely relaxed really accurate? If I breath completely relaxed, I'm not voicing at all. Panting may involve voice, but that might be a voluntary speech act. – vectory Feb 03 '19 at 18:19
I used to disparage the English ə/ʌ transcriptional difference but captured tokens of both and manipulated durations and amplitude so that they were equivalent, yet the qualities remain distinct. That persuaded me that the qualities are different. Are you saying (perhaps in your dialect) that the only difference is duration and/or amplitude? – user6726 Feb 03 '19 at 18:21
@user6726 Out of curiosity, what dialect were your tokens? My impression is that on the West Coast at least, the STRUT vowel tends to have some rounding, unlike schwa. – TKR Feb 03 '19 at 18:52
Seattle. I don't seem to have the tokens anywhere findable, but I'll see if I can recreate them. – user6726 Feb 03 '19 at 19:51
@user6726 May I ask the qualities remain distinct how? F1 is higher in STRUT, I assume? – Nardog Feb 03 '19 at 22:01
