Which language has the largest number of vowels with minimal pairs?
Are you asking which language has the largest number of vowel allophones? As opposed to phonemes? – fdb Apr 24 '19 at 09:01
Complementary distribution means there are no minimal pairs. Don't you mean contrastive distribution? – Nardog Apr 24 '19 at 09:50
@fdb No, I asking for language with most vowels with minimal pairs. – Rock Apr 24 '19 at 11:19
@Nardog If contrastive distribution is opposed to complementary distribution, then yes. – Rock Apr 24 '19 at 11:23
So you're asking which language has most vowel phonemes, not allophones? – Nardog Apr 24 '19 at 11:32
@Nardog Yes, I just want to know which language has the most vowels with minimal pairs. – Rock Apr 24 '19 at 11:34
1@Rock: the commenters are saying that the phrase the most vowels with minimal pairs is unclear. Can you say it in a different way instead of just repeating the same phrase? Minimal pairs distinguish phonemes, like bean and bin in English distinguish two vowel phonemes. English has about 15 vowels that can be distinguished that way, but there are many more different allophones for each of them. Are you looking for number of phonemes? Number of minimal pairs? Number of allophones? (infinite, that one). – jlawler Apr 24 '19 at 17:03
This is one of those "it depends" questions. Dinka (Bor dialect) has the vowels [i e ɛ ɔ o u a], as well as long and over-long versions of these (21 vowels), and 4 phonatory contrasts (breathy, hollow, model, creaky) → 84 vowel, which can have 4 different tones (H, F, L, R) giving 336. Unfortunately they do not also have nasal vowels.
You could redefine the question to as to eliminate properties like tone or length that can be factored out, but that is rather unprincipled and would lead to the ridiculous conclusion that Turkish has no vowels because you can "factor out" rounding and backness, not to mention vowel height. You could just stipulate a specific list of things, namely those things that are notated in the IPA with a diacritic as opposed to vowel-letter choice, and knock out phonation, length and tone that way (also nasalization). That would still leave you with the ATR problem, since there are atomic letter differences (i/ɪ, u/ʊ), but these can also be spelled [i̘/i u̘/u].
Some people think that diphthongs are vowels, which raises the question of what you mean by "vowel". Diphthongs are single phonological units (at some level of analysis) composed of two vocalic articulations – two vowel segments within a nucleus. If you exclude diphthongs, that will knock out a lot of languages. I did not include diphthongs in the Dinka count (Dinka has diphthongs).
English has, in one theory of transcription, the vowels [i ɪ e ɛ æ ɑ ɔ o ʊ u ʌ] which is sort of a lot of vowels (less than German), but it can also be reduced to [i e æ ɑ o u ʌ] plus an orthogonal length or diphthongization property.
There is a behavioral rationale that people might use to justify ignoring tone, or length, when counting vowels, which is that tone and length have a certain propensity to act "independently", for example tone can spread from vowel to vowel, or may be preserved under vowel deletion (and gets reassigned to a neighboring vowel). However, the same is true of vowel height, backness and roundness. To stipulate that tone and length should be excluded (and perhaps phonation type as well) based on this autonomous behavior, while not doing the same for backness and roundness is unprincipled. There are certain strong-universalist trends in phonological theory which do stipulate that tone and length are not features dominated by the root node (whereas phonation and nasalization are), so if you make those assumptions, then Dinka has fewer vowels.
In other words, it depends on your criteria for saying this thing versus that thing are "different vowels". The probable winner is Dinka.
- 83,066
- 4
- 63
- 181
This question is about minimal pairs. Are Dinka vowels in complementary distribution or not? – Rock Apr 24 '19 at 15:35
No, these are phonemically distinct, not just phonetic vowels. There are suitable minimal pairs. – user6726 Apr 24 '19 at 15:35
This line seems a bit of a straw man to me: "You could redefine the question to as to eliminate properties like tone or length that can be factored out, but that is rather unprincipled and would lead to the ridiculous conclusion that Turkish has no vowels because you can "factor out" rounding and backness, not to mention vowel height". – brass tacks Apr 24 '19 at 19:26
Why did you mention Turkish specifically as an example? It has harmony involving backness and (to a lesser extent) rounding, but no height harmony as far as I know, so I think Turkish vowel height can only be "factored out" to the degree that any feature of a phoneme can be "factored out". (And wouldn't this give one vowel phoneme, not zero?) – brass tacks Apr 24 '19 at 19:27
Also, there are specific reasons for (potentially) treating tone as something that is not a feature of a vowel phoneme but of some other unit: it's an arguable but not necessarily "unprincipled" choice. For example, there are languages where consonants also participate in the tone system. I'm not familiar with Dinka specifically, but you don't seem to give a reason in this answer for supposing that Dinka's 4 tones multiply the number of Dinka vowel phonemes any more than English's different levels of stress multiply the number of English vowel phonemes. – brass tacks Apr 24 '19 at 19:29
2My point is that people frequently object to including tone or length as being a property of a vowel, because these properties are "separate": you yourself seem to be raising that objection. Rounding and backness are "separate" from everything else for the same reasons that tone is "separate", and height can be (but is not demonstrably so in Turkish). In lieu of a clear specification of what it even means to "count vowels" given the option to ignore a property, it's impossible to answer the question, thus "it depends". – user6726 Apr 24 '19 at 19:52
Unless you take a fatalistic "no analysis is better than any other" approach, I don't see what you mean when you say that "Rounding and backness are 'separate' from everything else for the same reasons that tone is 'separate'". For which reasons? Rounding, backness, and tone don't behave identically in all languages. For example, for some particular language, we might suppose that rounding and backness are a property of vowel phonemes (rather than syllables) because they are only contrastive on high vowels, while tone is contrastive for syllables no matter which vowel phoneme they contain. – brass tacks Apr 24 '19 at 20:26
1For any specific reason for analyzing something as a property of a phoneme vs. a property of some other phonological unit, it's possible to make an argument that it's a bad reason, but I think it's unreasonable to dismiss this whole class of arguments just by saying "it depends on how you define things". Your proffered answer is based on your own definitions, so I think you should explain more why you think your definitions are right. – brass tacks Apr 24 '19 at 20:27
