Is it just a matter of coincidence or did the two language influence each other in some way?
Infinite
  • 303
    This is a question that is often asked and often answered with an acknowledgment that there is indeed an unusual degree of similarity, so I don't see why it should be closed even if it is a little terse (unless there's a duplicate). – LjL Dec 14 '19 at 15:16
    True. Though if one includes the historical phonology, they've got less similarity, but you can still discern patterns. Spanish has nothing like Greek's recursive V -> [i] history, for instance; but palatalization and spirantization of different kinds are common. – jlawler Dec 14 '19 at 17:07
  • I don't think we can argue for direct influence. There were Greek colonies in Iberia but there were Greek colonies in many places, and there were Phoenician colonies, and Visigoths and Moors. – Adam Bittlingmayer Dec 14 '19 at 19:41
    If we argue for indirect influence - maybe a common influence on both, like Vulgar Latin or Mediterranean Sabir - then we have to explain why Spanish ended up with a phonology more like Greek than Catalan and Venetian and Albanian did. – Adam Bittlingmayer Dec 14 '19 at 19:41
    Check out Langfocus's video on this exact topic. – Toby Mak Dec 15 '19 at 02:20
  • Related but very different. – Cosmas Zachos Dec 19 '19 at 16:03
  • @LjL in my experience lots of closings happen simply because of the ignorance of the person with enough points to close questions. – iconoclast Dec 24 '22 at 00:57
It is partly accidental and partly due to common PIE heritage. Let's look at a few similarities:
1) Lenition of intervocalic voiced occlusives - /b/, /d/, /g/ in Spanish and Greek have a fricative realisation between vowels and occlusive realisaiton at the beginning of the word and after a nasal.
This is a very frequent evolution of voiced occlusives. In fact, it happened in all western Romance languages to a degree (little in Italian, a lot in Spanish, massively in French - to a degree where even the resulting fricative got elided). Similar thing happened in Greek and many other languages. The reason behind this is thought to be that voiced occlusives produces only little pressure on the occlusion (because of glottis vibrating) and thus there is little need for the articulators to be pressed together tightly (as opposed to unvoiced), so the occlusive can easily become a fricative.
2) Apical /s/
In both languages there is just a single articulatory position for a sibilant, so it has a fairly wide space of articulation as there is not contrast in this space (e.g. compared to English or French distinguishing prealveolar /s/ and post-alveolar /š/), so the (Castillian) Spanish and Greek sounds are perceptually something in between.
In Greek, this is thought to be a direct inheritance from Proto-Indo-European, where the situation was probably similar. In Spanish, you could theoretically say the same but the situation is far more complicated. It is very likely, apical /s/ was present also in Latin as a direct heritage from PIE (and there it evolved often into /r/ in intervocalic position). Proto-romance and Old Spanish develop, however, a set of other sibilants, coming mostly from palatalised velar occlusives /k,g/. So they had, at one stage probably the following system of sibilants - dental, apicoalveolar and postalveolar (voiced and unvoiced). The ternary contrast is difficult to maintain, so it evolved. In most Romance languages, these merged to prealveolar [s,z] and postalveolar [š,ž]. In Spanish, the ternary contrast did not disapear but was reinforced - dental sibilants moved to interdental fricatives (like English TH in "death"), postalveolar sibilants moved to retroflex and later to velar fricatives, while the apical /s/ remained. Then the voicedness contrast was lost. You can see the reflexes of this in early Spanish loandwords in other languages, e.g. "don Quijote/Quixote" is pronounced [kišot] in French, and the name "Borja" (then pronounced [borža]) was rendered as "Borgia" in Italian.
3) Similar phonotactics - Ancient Greek words could end only with a vowel, or /s,r,n/ (not sure about current Greek though), Spanish words today typically end only with /s,r,l,n,d/.
It is very common in languages that word end consonants, particularly occlusives get dropped because very often they do not have any audible release and are only distinguished by formant transient on the preceding vowel, which may be a too weak cue.
4) Vowel system
Both languages have the set of five vowels /a,e,i,o,u/ but this is probably the most common vowel set in the languages of the world.
So in summary: The PIE phonology evolved through different pathways into the various descendant languages and by accident, the Spanish and Greek followed some of the same pathways or pathways giving a similar result. Actually this is not something spectacular given the variety of IE language family, especially considering that some of the above mentioned pathways are not exactly rare or surprising. They occur very frequently in languages of the world and the situation when two languages follow a multiple similar pathways is more of a statistical inevitability.
Eleshar
  • 2,363
Indeed, even though Modern Greek has some limited phonological affinities with Albanian and Bulgarian (which could be explained by Balkansprachbund arguments), it is strikingly phonologically different from Italian, with which it has been rubbing shoulders for millennia. (Yes, there is Italianate prosody in Greek island dialects and Griko, but it appears that, as the Langfocus video amply illustrates, M G has retained fewer tonal features from Ancient Greek than Italian possesses now! Indeed, in an odd reversal of history, modern Greeks marvel at the singsong features of Italian just as the Romans did for A G.) Despite millenia of lexical loans and interactions, it is still terribly easy for Greeks to mispronounce Italian, and vice versa, even though they can learn each other's languages flawlessly. Even Sicilian is decidedly on a different phonological plane.
This, then, might well amount to a tweak of the question above, or a subquestion even, as I am not expert enough to call it a conjecture: A dimension of similarity worth exploring is that M G was heavily influenced by Egyptian/Coptic in its transition from A G, while Spanish was influenced by N African phonologies. To my mind, see below, it might be interesting to contrast Spanish dialects which are more and less influenced by Arabic and Moorish dialects, in hope of discerning patterns. The dramatic shift in Greek phonology is well attested in Hellenistic Egyptian papyri, and their telltale spelling mistakes (Menardos).
My special focus point/question is the following.
Both Spanish and Greek have a fair amount of ambiguity/latitude in the consonant pairs b/β; g/ɣ; and d/ð . G has transitioned to the second variant from Ancient to Modern (with a few notable exceptions, when these consonants are preceded by n or m: so, Modern G has retained (exceptionally) ancient values in anDras, enDeka, komBos, emBaino, synGenes, etc, in fast, informal speech; it is a rule); while S is still right in the middle of the transition--even though I am unsure about its time scale and spread.
I should welcome insights and systematics in pronouncing Spanish, or even discerning the difference in Cordova/Cordoba, Habana/Havana, aɣua/agua, arredondo/arreðondo, viða, across S dialects. Are there well-known trends, and, if so, do they correlate with Moorish influence? (Again, the phonological contrasts to Portuguese, or Sicilian, for instance, are striking. Conversely, I am humbled by also noting the transition in French cheval, though.)
Cosmas Zachos
  • 196
  • I don't think there is much Moorish influence, because Portugal was also occupied, and Madrid (Castilian) is fairly far north. If anything it's Basque that shares the same set of sounds. – Adam Bittlingmayer Dec 19 '19 at 20:26
    What distinguishes Castilian Spanish from other (incl. Iberian) Romance would be the shift of f- to h-, the shift of -o- to -ue-, the shift of certain consonant clusters to ch and ll, the shift of j to x, the z/ç like theta... – Adam Bittlingmayer Dec 19 '19 at 20:30
  • What distinguishes Iberian Romance is tough to say, it's tough to name features that are true of all Iberian Romance and not true of any other Romance. (Maybe a bit easier if remove Catalan.) – Adam Bittlingmayer Dec 19 '19 at 20:33
  • Fair enough, but, Portuguese, Basque, Catalan, and the rest are strikingly different sounding than Greek. I focus on the pairs b/v, g/ɣ, and d/ð, because their transition is really shared by Greek and most Spanish dialects... – Cosmas Zachos Dec 19 '19 at 20:44
  • Yes they are, despite surrounding and mostly being very very closely related to Castilian Spanish. You tell me, how that could work? Easiest answer is that any claim of a special connection to Greek is... bullshit. – Adam Bittlingmayer Dec 19 '19 at 21:58
  • I'm not sure what you are saying: the phonological connection is indisputable and striking. The question we are in is asking for an explanation. You don't believe it is even worth spitballing about? In any case, I am specifically asking for pair ambiguities b/v, g/ɣ, and d/ð across Iberian dialects, even skipping explanations. – Cosmas Zachos Dec 19 '19 at 23:00
  • Superficial similarity (which is disputable) doesn't imply a "connection", let alone an "indisputable" connection. – Adam Bittlingmayer Dec 20 '19 at 14:08
  • You're taking the one dialect of Iberian Romance that, through random variation, sounds most like Greek. And it happens to be located in the exact middle of the peninsula. Fooled By Randomness. – Adam Bittlingmayer Dec 20 '19 at 14:14
    @AdamBittlingmayer All Romance languages in Iberia (Castilian, Asturian, Leonese, Extremaduran, Mirandese, Galician, Portuguese, Aragonese, Catalan/Balearic/Valencian, Aranese/Occitan) share the very same phonologic progression of [b→β], [d→ð], [g→ɣ], where voiced obstruents are realized as fricatives or approximates except following particular consonants or at the onset of an utterance. This is another step in the series that led to the voicing of many unvoiced obstruents when transitioning from Latin [p→b], [t→d], [k→g] as in the phrase “head to tail”, cabo a rabo <L caput, rapum. – tchrist Dec 20 '19 at 14:45
  • @Adam. I use "connection" as a synonym "indisputable similarity". It appears you are determined to not only controvert wispy explanations, but the very fact itself! I could unload supporting evidence, or you could just ask millions of speakers, but this question might not be the venue. Just consider that Italian completely lacks this phonological progression. – Cosmas Zachos Dec 20 '19 at 15:22
  • @tchrist . Thanks for the reassurance all dialects part-take in this... But I have, over the decades, run into S speakers who have not completed the progression and still use the voiced obstruents; challenging them, I have appreciated they barely register the difference. [I am also, in my Romance linguistics ignorance, intrigued by your "other" step in the series, which looks like a reverse Grimm's law progression!]. – Cosmas Zachos Dec 20 '19 at 15:34
  • @tchrist In the outlier case of Portuguese, "redondo" has two d s, so completely untransitioned; is there much known about the intensity of the transition across dialects? – Cosmas Zachos Dec 20 '19 at 17:44
    @CosmasZachos That depends where you are, as most Brazilian dialects of Portuguese never show intervocalic lenition of voiced stops. So in Brazil’s redondo both instances of phonemic /d/ remain (dental) [d̪]. But in Iberia only its second instance is blocked from becoming the fricative or approximate [ð, ð̞] by the preceding nasal. Certainly this is true of that word in Castilian, Asturian, and Galician, and given the lattermost I wager it’s also true of Portuguese there, but I’d have to listen to clips of native speakers to be sure. – tchrist Dec 20 '19 at 18:57
  • @tchrist Thanks; you answered my covert question hiding behind an "answer". Too bad I can't "accept" it... – Cosmas Zachos Dec 20 '19 at 20:22
  • I can confirm that b, d, g are never lenited in Brazil. In Portugal, there is great variation depending more on the speaker than on their region, I believe. I have seen some Portuguese people that weaken them extensively and others that never do. The fact that this doesn't affect Brazil at all, and Portugal incompletely, but is present in all dialects of Spanish, suggests that this was a Spanish feature that entered Portugal later. – theoremseeker Oct 21 '20 at 21:25
  • I'm commenting for something else, though: you mentioned that "modern Greeks marvel at the singsong features of Italian just as the Romans did for A G." I found that quite interesting. Do you have a textbook quote, or even better, a quote from Roman works themselves, on the singsong quality of Ancient Greek pronunciation? – theoremseeker Oct 21 '20 at 21:27
    @theoremseeker Lost track of it at the moment, alas! I recall a Roman being charmed by the melody of prosodic meter in contrast to the dryness of stress-based Latin. The Latin SE is the site to chase this sort of thing down, or maybe even ask a fresh question? – Cosmas Zachos Oct 21 '20 at 21:54
Just flew via Athens and passed the time thinking about this question. Warning in advance that phon* is not my strength, Greek is not my strength and my mobile keyboard doesn't have IPA chars.
First we should ask: are Greek and Spanish phonology actually that similar, and in what ways?
Similarities
poor in vowels - This shared by most major Mediterranean languages, including Semitic ones, but not Turkish.
poor in consonants - They are both fairly limited, not just in terms of inventories but in terms of contrasts and permissibility in certain positions.
θ like Greek theta or Spanish ç - Besides peripheral languages like Arabic, English and Icelandic, it's possible only Greek, Spanish and Albanian have this.
Probably something with rhythm and stress and timing. Actually this usually affects how a language or person sounds more than sound inventory does.
Differences
But if we break those down there are major differences, at least if we ignore recent loanwords:
Greek doesn't allow ch, Spanish has lots of it.
Spanish doesn't allow initial ts or ps or ks, Greek has lots of it.
Spanish doesn't allow initial st, sp, sm..., Greek has lots of it.
Spanish doesn't have words that end in unstressed i or u, Greek has many.
Spanish doesn't contrast s and z, Greek does.
In a sprachbund (or phylogenetic relation) situation we would expect the effect to be not limited to sound inventory, but for the notable sounds to be in corresponding positions in corresponding words.
The many cognates of various vintages show clearly that the rarer sounds that happen to be shared arose in very different ways, as they occur in different positions.
Barθelona vs Varseloni
Xuan vs Yannis
xeke vs seixis
bivlioteka vs vivliothiki
θiklo vs kiklos
θoloxiko vs zooloʝikos
galaɣsja vs ɣalaksias
Modern Greek orthography compensates for its limitations with curious digraphs - hence Ampou Ntampi and Nzini Novgkoront - essentially introducing some contrasts.
We would also expect similarities in other areas, like grammar.
My bets
  • There is some sort of Mediterranean and Greco-Roman sprachbund. Coasts had continued contact with each other for thousands of years. So expected similarity between all language pair there is higher than random.
  • Spanish is the Mediterranean and Greco-Roman language best known worldwide and in the Anglosphere right now. So we hear "Greek sounds like Spanish" more than "Spanish sounds like Greek".
  • Italian sounds just as much like Greek as Spanish does. We could measure this, with a list of features, or for example with a spoken language identification machine learning model, or testing humans.
  • Perceived similarity is influenced by the languages we know. For example, English speakers can't say x or gh and therefore can't contrast them and therefore if one language has one and one the other they sound the same.
Adam Bittlingmayer
  • 7,664
  • 40
    Some of your similarities and differences seem arbitrary to me (words that end in unstressed i?). Your bets on Italian also seems strange to me. Some similarities you could have listed (which also distinguish from Italian): same vowel set, lack of gemination, dental and velar fricatives (even though their voicing is phonetic in Spanish and phonemic in Greek). Spanish ch is even (partly) paralleled by Greek palatal consonants. There might be an areal connection (Albanian?) but it isn't a "Greco-Roman sprachbund" if by that you mean to include Romance languages – b a Dec 16 '19 at 19:25
  • People take Sprachbund borders too literally. Essentially every language is in multiple sets, some which are subsets of larger but looser ones, and different dialect or registers of the same language or dialect continuum may be under varying influence. – Adam Bittlingmayer Dec 17 '19 at 07:37
    So how is Greek + Spanish + Italian a meaningful set? I don't see any features in common (except palatal nasal) that aren't common cross-linguistically – b a Dec 17 '19 at 09:18
  • The point is: "similar" compared to what? Italian, though closely related to Spanish, has some phonological features in common with Greek that Spanish doesn't. – Adam Bittlingmayer Dec 17 '19 at 11:16
  • For example: Initial st-/sp-/sm-.... Even the basic verb and noun morphology, like masculine plural, or 2nd-person plural imperative. Not saying it's massive, just putting the supposed similarities of Spanish in perspective. – Adam Bittlingmayer Dec 17 '19 at 11:19
    How does Spanish "not allow ks"? You even give one example of it yourself (galaxia) even though that's actually a Greek loan... but Spanish has its fair share of /ks/ even aside from Greek loans. – LjL Dec 20 '19 at 16:34
    Also as to "Italian sounds just as much like Greek as Spanish does": as a native speaker of Italian, not even close. Yes, I realize being native makes me more likely to conflate two languages that I'm not native in, compared to my own... but I can readily admit that Spanish shares a lot of grammar and vocabulary with Italian, and that depending on the context, I can often understand Spanish with little difficulty, while I certainly won't understand any Greek. This is not thanks to the phonology, though, but despite it. – LjL Dec 20 '19 at 16:40
  • Please edit your posting to replace "spelling pronunciations" with actual IPA symbols. You’ve made mistakes here, such as Spanish biblioteca pronounced [biβljoˈt̪eka]: remember there is no /v/ in Spanish!! You should also correct the erroneous mention of the "cedilla" when in fact the letters sometimes pronounced [θ] in Spanish are the letters C named ce and Z named zeta. Although /z/ is not its own phoneme in Spanish, the [z] allophone of /s/ occurs under regressive assimilation in words like mismo and desde. Its only phonemic affricate is /ʧ/ but [dʒ, ɟʝ] also occur phonetically. – tchrist Dec 20 '19 at 19:20
  • @LjL examen, exhibir , extremo... – Cosmas Zachos Dec 20 '19 at 21:27
  • @CosmasZachos I didn't this examples would be needed as they're plentiful, but yes. – LjL Dec 20 '19 at 21:32
  • @LjL You're not parsing my assertion correctly. I only wrote the Italian sounds roughly as much like Greek as Spanish does, not that Italian is (or even sounds) more like Greek than it is like Spanish. – Adam Bittlingmayer Dec 20 '19 at 22:29
  • @tchrist Yes thanks I should correct that to use IPA symbols when I'm back at a full-size device. – Adam Bittlingmayer Dec 20 '19 at 22:33
  • @tchrist Re z in mismo I wrote that Spanish doesn't contrast s and z and I what you wrote only supports that. – Adam Bittlingmayer Dec 20 '19 at 22:35
    @AdamBittlingmayer that's not how I was parsing it. To me, as a native speaker of Italian, Greek and Spanish sound much closer to each other (if I discount the fact that I understand a number of Spanish words, and almost none in Greek) than either does to Italian. Most of the phonological features that are being attributed as being common to Greek and Spanish are not present in Italian. – LjL Dec 20 '19 at 22:37
  • Alright, your comment was mostly about Italian and Spanish being similar. – Adam Bittlingmayer Dec 20 '19 at 23:28
  • Italian may lack "most" phonological features common to Spanish and Greek (although I'm not sure I buy it, they probably all share plenty that are super common), but what does that prove? Italian and Greek also share features that Spanish lacks. So compare it against that. – Adam Bittlingmayer Dec 20 '19 at 23:32
  • Albanian has both ð and θ if you are not including Icelandic and Faroese as "continental". – hippietrail Dec 24 '19 at 14:03
  • Thanks, that further undermines the whole assumption. – Adam Bittlingmayer Dec 24 '19 at 14:21
