I'm trying to understand why in most theories of syntax, the subject of a sentence is the sister of the verb, and not the child eg:
S -> NP VP instead of VP -> NP V (NP...)
The latter feels more intuitive to me because:
  • The verb semantically constrains the subject just as it constrains the object, eg. #Jim drank a shoe and #The shoe drank coffee. It "feels" like the subject is controlled by the verb.
  • While S -> NP VP simplifies the structure of an English sentence, it complicates the structure of a SOV sentence where you could say VP -> (NP...) V.
It's hard to find a discussion on this point, since in most theories it's taken as axiomatic.
nathan
  • 181
  • @AlexB. Could you explain your last comment? My intuition is that drink imposes a restriction on the subject to be animate, ie. "the man drank coffee" vs "#the shoe drank coffee". So in this scenario, the verb is the subject's "parent" semantically but the subject's sister syntactically. – nathan Dec 14 '20 at 04:17
  • Could you also explain what you mean by your first example? I guess "it dawns" could be analysed as both S -> NP(it) VP(dawns) or VP -> NP(it) V(dawns) with "it" being a semantically empty dummy subject required by English phrase structure – nathan Dec 14 '20 at 04:19
    "Do you think we should base our cross-linguistic description on rules of English grammar" Definitely not. I'm trying to understand why most theories of syntax have the subject outside the VP. – nathan Dec 14 '20 at 05:23
    In the framework I follow, the subject is an external complement of the verb. – BillJ Dec 14 '20 at 15:24
  • Would you be able to write an answer making an argument for why you think that’s the correct analysis (at least in English?) @BillJ – nathan Dec 15 '20 at 01:41
  • @nathan I've posted an answer, though I very much doubt if it accurately answers your specific question. – BillJ Dec 15 '20 at 13:31
    @Araucaria-Nothereanymore. It seems that I misread the question. Deleted everything. Thanks for encouraging me to re-read the OP's question. – Alex B. Dec 16 '20 at 05:15
    The question is excellent. The insight it expresses is articulated most vividly in Lucien Tesniere's grammar (1959), which of course inspired the dependency grammar (DG) approach to syntax. – Tim Osborne Apr 05 '21 at 02:12
First of all, it should be noted that in nearly all generative theories--even in ones which generate subjects inside the VP--the subject practically never stays there for long. Subjects generally move upwards into a position where they can receive Case; by most X' accounts, they move up into SpecTP (or SpecIP, etc.).
This is what BillJ's response is referring to; when they say, "[subjects] are different from other types of complement in an obvious way: they are positioned outside the VP", they are not referring to the place where subjects are generated, they're referring to the place where subjects generally end up after all the various kinds of movement have occurred. Objects and other verbal complements can also wind up outside the VP via movement due to various processes (topicalization, wh-fronting, etc.), and the promotion of an object to a location outside the VP is obligatory in object-first languages. But subjects are unique in that they seem inherently 'fated' to wind up somewhere far-flung from the VP. [Caveat: In clauses with a TP. Assume that I'm talking about clauses with a TP in all of this--"tensed" clauses, "finite" clauses, however you want to call them.]
We know that the subject of a verb has to be generated in a position similar to the verb, because, for instance the verb selects for the thematic roles of all its various complements. Yet, the hierarchical positions of the various verbal complements are assymmetrical: a verb can seemingly select for and assign the Case of a direct object, but not of a subject. So, in the past, we generated the subject in SpecVP. This allowed us to maintain the closeness of the subject and the verb, but allowed the verb to be closer to the object.
In some languages, we can distinguish a class of verbs called "light" verbs which seem to behave differently from other verbs. We'll call those other verbs "heavy" verbs--they're not called that in the literature, this is just for illustrative purposes. They always possesses a weak semantic meaning; prototypical examples include things like GO, TAKE, GET, DO, MAKE, and so on. Their properties vary from language to language, but here are just some examples:
  • In Inuit languages, light verbs can incorporate a direct object, but heavy verbs cannot, even when the semantics are nearly the same. In Eastern Québec Inuit, "he bought a table" (heavy verb) is niuviq-tuq (bought-3ms) saa-mik (table-obj.). But "he got a table" (light verb) is saa-taaq-tuq (table-get-3ms).
  • In English, a small number verbs of semantically weak verbs (have, make, take, get, give, etc.) form a disproportionate amount of lexicalized predicates equating to light verb + indefinite article + noun (make a mistake, have a smoke, take a break, give a fuck, do an inspection, etc.). These often interchange with heavy verbs: take a nap vs. nap; make a claim vs. claim; do a revision vs. revise; give a performance vs. perform; have a smoke vs. smoke; do a dance vs. dance; and so on.
  • In Yiddish, two verbs of great generality--ton 'do' and gebn 'give'--can be combined with a nearly any heavy verb root in order to create a sense of immediacy or intensity: Er tut/git a bak beygelekh (he does/gives a bake bagels) 'He is baking bagels [as we speak!]'.
  • In many Australian languages, only a small, closed handful of verbs of great semantic generality are capable of inflecting. All verbal expressions consist of such a (finite) verb plus a non-finite verb. "To dive" would be to go dive, "to hunt an animal" would be to do hunt an animal, and so on. The constructed language Kelen claims to be verbless, but in reality, it is simply doing what these Australian languages do--it restricts its verb set to a small number of semantically broad light verbs.
Which verbs can/cannot be considered "light" depends on the language, but they can obviously appear in addition to heavy verbs. And they can often appear together with heavy verbs and with other 'auxiliary verbs' like aspectual verbs and tensed verbs (I shouldn't have taken a bet on that horse; Yiddish: Ikh hob gegebn a hilf dem man 'I helped the man straight a way [I have given a help the man]'.)
So where do we put them in the tree? The fact that they can be lexicalized in ex. English and some Australian languages tells us that they have to be base-generated in a position nearby the verb and all of its complements. But we can't put them in SpecVP--that's where we put subjects! And we can't put them in CompV--that's where we put objects!
So, we created a new layer above the VP. We call it the vP, with a lowercase v, and that's where the light verbs go. But now what's the specifier of vP?
Well, this is when we run into the problem of ditransitive verbs and indirect objects. If we put the indirect object and direct object both as complements of V0, this gets us into some trouble. For one, it gives us a tertiary branching structure, which X' and later Bare Phrase Structure absolutely cannot abide. For another, this predicts that the c-command effects of direct and indirect objects should be exactly equal--V0 should c-command the DO and IO, and the DO/IO should c-command the V0 and each other. But we can tell that this is not the case--various evidences from binding effects/anaphora show that the IO c-commands the DO and the V0, but the DO does not c-command the IO. This suggests that the IO is higher than the DO. (In langauges like English; secundative languages like West Greenlandic show the opposite pattern.)
This works out for us because a new appartment above the VP just opened up in SpecvP. We can tell that the IO is more closely linked the verb than the subject is; IOs c-command the VP, but not the subject, so they cannot be higher than the subject, so the IO cannot go in SpecvP. This means that we have actually found ourselves a new home for the subject, up in SpecvP. (Also, subjects would have had to land temporarily in SpecvP anyways in the course of movement upwards to SpecTP even if they were generated in SpecVP, just like they land temporarily in SpecNegP and so forth.)
This has a number of consequences, and some of them turn out to be solutions to other outstanding problems. An interesting problem comes up with theta roles. You've no doubt noticed that some of the things called 'light verb constructions' are sometimes two verbs, but they're often a verb and a noun. Where does the subject get its theta-role, and does the "object" have a theta-role? The "object" of He took a drink is synonymous with He drank; so the subject is receiving an agent or experiencer theta-role, but the "object" is arguably not receiving one at all, as if it were fulfilling the role of the V0. In the aforementioned Australian languages, specific kinds of light verbs are associated strongly with specific subject theta-roles. And in English, there is a correlation--not strict, but present--between choice of light verb and the subject's theta-role. If the vP hypothesis is true, it is likely that we can actually define the v0 node as the element responsible for assigning theta-role to the subject. This changes how we represent verbs at an underlying level: all verbs are now associated with a V-node, which gives theta-roles to the IO and DO, and a v-node, possibly null, which gives theta-roles to the subject.
This is, it turns out, actually a very very handy thing. It gives a good reason for why subjects seem to be so much less strongly associated with the semantics and syntax of the verb than objects/direct objects do, and it definitively divides "internal arguments" (objects and adpositional complements etc.) and "external arguments" (subjects). The basic idea of "internal" and "external" arguments already had support before the vP hypothesis, but the vP hypothesis gave it an even firmer standing.
The account I've presented here is too simplistic, and it does not follow the original argumentation for the vP hypothesis; but it's the line of reasoning I've found most successful in trying to understand the vP hypothesis myself. We've of course developed even more complicated kinds of internal structure in the "VP shell" with things like AgrIOP and AgrOP, but the overall picture is consistent. There's further evidences for the vP hypothesis in some phenomena related to the differences between unaccusative and uneragative intransitives, where unaccusative subjects seem 'closer' to verbs in certain kinds of constructions (because unaccusative subjects are generated in the VP and unergative subjects are generated in SpecvP), and I believe also in some aspects of syntactic phases. But this should suffice to lay the very general outline of why we think (most) subjects are very probably generated in their own shell outside of the VP, and that most lexical verbs are actually syntactically pairs of a (usually null) light verb a (usually overt) heavy one.
It's been some years since I was last in a syntax research environment, to my dismay, so I do apologize if I have bungled the finer points.
Khove
  • 774
The object is a kind of complement since it satisfies the licensing requirements.
The subject is rather different: all canonical clauses contain a subject, so in a sense subjects are compatible with any verb.
However, certain syntactic kinds of subject are restricted to occurrence with particular kinds of verbs, so the concept of licensing applies here too. Take for example:
[1] [Whether we will finish on time] depends on the weather.
[2]*[Whether we will finish on time] ruined the afternoon.
The bracketed expression [1] is a subordinate clause functioning as subject of the larger clause that forms the whole sentence. It is, more specifically, a subordinate interrogative clause: the main clause counterpart is "Will we finish on time?"
A subject of this syntactic form has to be licensed by the verb (or VP). It is admissible with "depend", but there are innumerable other verbs such as "ruin", "see", "think", "years", etc. that do not accept subjects of this form. [2], for example, is ungrammatical.
Subjects do satisfy the condition for being complements, therefore. But they are different from other types of complement in an obvious way: they are positioned outside the VP, and hence are referred to as an external complement as opposed to other complements that are internal to the VP and referred to as internal complements.
BillJ
  • 830
    Thanks for your answer @BillJ! Your final point “[subjects] are different from other types of complement in an obvious way: they are positioned outside the VP” seems circular. My question is why is the subject outside the VP? – nathan Dec 16 '20 at 02:20
  • What was years supposed to be? Yearn? – Janus Bahs Jacquet Jun 17 '21 at 09:54
Re: "Why is the subject outside the VP in most theories of syntax?"
  • In the Minimalist Program - or even in the Government and Binding theory, so it must be in Haegeman 1994 then too - the subject of a transitive verb is base-generated as a specifier of vP (see any textbook, e.g Adger 2003, Carnie 2012, or any edition of Radford). The argumentation is well-known and there is no need to repeat it here (floating quantifiers, expletive constructions, subjects in Belfast English, etc.). This is known as the Verb-Internal Subject Hypothesis (in Hornstein et al. 2005 it is called the Predicate-Internal Subject Hypothesis). Andrew Radford (Radford 2004) writes that this hypothesis "has been widely adopted in research since the mid 1980s" (p. 244). That is why S (as a node) has not been used in generative syntax for at least 30 years (if not more), and the current standard practice is that T is the nucleus of a clause (hence TP; in the 80s and early 90s I think it was marked Infl and then I, if I am remembering it correctly). For instance, linguists of my generation (I graduated in 2009) have never used S - or any of the notation in your question - but of course we did read earlier work, so we are aware of it.
Re: "I'm trying to understand why in most theories of syntax, the subject of a sentence is the sister of the verb, and not the child."
  • Testelets 2001 (Chapter 1, section 5 "Центральное положение глагола," pp. 88-90) writes that the idea of the centrality of the verb could be found as early as 1888 (citing Potebnja 1888) but it was explicitly presented and explored in detail by Lucien Tesnière in 1959 (2015, open access, English translation by Timothy Osborne, an active participant of our site btw, and Sylvain Kahane):
    "it poses no difficulty for the hypothesis that the verbal node is the central node" (p. 99);
    "[...] it is difficult to place the subject on equal ground with the predicate. The subject often consists of a single word and cannot be fully expressed. The enunciation of the predicate, in contrast, is obligatory and in the majority of cases, the predicate contains many more elements than the subject" (p. 99);
    "This inconvenience disappears as soon as the verbal node is acknowledged as the central element and the stemmas constructed accordingly" (p. 99).
    Lucien Tesnière is considered to be one of the founding fathers of dependency grammar (correct me if I am wrong).
  • Dixon (2009, reprinted with corrections in 2012) also writes the following:
    "The predicate is the nucleus of a clause" (p. 98).
  • Van Valin and LaPolla 1998, e.g. fig. 2.6 in Chapter 2 (p. 26):
I recommend this book to anyone who is seriously interested in doing syntax.
  • Finally, Plungian (2011: 259) goes as far as to claim that the subject and object do not seem to be universal categories after all. He mentions Melcuk 1988, Bhat 1991, Testelets 2001 (Chapter 6), and Van Valin and LaPolla 1997.
Alex B.
  • 8,744
Let me first note that the shape of syntactic structures isn't affected by semantic constraints. As for the structural position of the subject, note that there's the so-called VP-internal subject hypothesis, you might want to read up on it but it's only marginally relevant.
Now to the gist of the question. In the theory of constituent-based syntax there are languages that have a VP and languages that don't. The former have a constituent that combines the verb with its complements (whereby the subject is determined structurally) whereas the latter have more or less freely floating verbs that don't structurally distinguish between their object and subject. There are a few technicalities such as how VPs work in VSO languages but the basic principle is pretty simple. In sum, it's language-specific.
Atamiri
  • 2,590
