The way I believe it happened was by the change of "w" into "v" and the fall of the velar "k". Furthermore, betacism caused the change of "v" to "b" in this word. Only in Romanian, maybe because of the inclination towards unvoiced consonants, "v" became "p" instead. This change seems very interesting to me because it didn't occur in the other main Romance languages, even though the change of "w" to "v" was a general phenomenon in Vulgar Latin.
I know I'm ignorant about linguistics and I'm deeply sorry if there are any errors in my question or theory.
Tristan
  • 8,262
  • 46
SarruKen
  • 189
  • Related: https://linguistics.stackexchange.com/q/31371/10559 https://linguistics.stackexchange.com/q/35428/10559 https://linguistics.stackexchange.com/q/31597/10559 – Draconis Sep 27 '21 at 21:34
    Latin qu/gu gives Romanian p/b; e.g., *quattuor / patru* . – Lucian Oct 11 '21 at 01:18
Labiovelars like /kʷ/ (that is, the Latin qu- sound) and /ɡʷ/ have turned into labial stops in at least some environments in a few different languages (almost exclusively in European Indo-European languages); it happened in Greek after the Mycenaean period (compare e.g. the verb ἕπομαι pomai 'to follow' with its Latin cognate sequor, both reflecting the PIE root *se-; in certain environments the labiovelars became dentals instead), in some but not all Celtic languages (Welsh pedwar 'four' but Irish ceathair, from PIE *etwóres), in the Sabellic Italic languages (Oscan pumpe 'five' vs. Latin quinque, from Proto-Italic *kʷenkʷe < PIE *penkʷe), and then again in some of the Romance languages (Sardinian and the Eastern Romance), as you've observed. There, it only happened in very few environments—possibly only before /a/.
Often in these languages /kʷ/ would become /p/ and /ɡʷ/ would become /b/, preserving the voice of the labiovelar (/gʷʰ/ was often trickier; it became /pʰ/ in Greek, for instance), including in Romanian: Latin aqua > Romanian apă, as you said, but Latin lingua > Romanian limbă. (I don't know much about Sardinian, but I would guess the unexpected voicing is just assimilation to the surrounding vowels. The gemination is due to aqua becoming acqua in certain areas during the Latin period, as complained about in the Appendix Probi.)
The process seems to be more immediate than you've outlined, with the labialisation of the phone going from being a secondary articulation to being the only place of articulation, at the expense of the velar aspect, in one step. If betacism were a factor, for instance, we'd presumably see some effect on inherited /v/ from Classical Latin /w/ in Romanian, but we don't.
Cairnarvon
  • 2,069
The change of /kʷ/ > /p/ is moderately common, cross-linguistically. It also happened in Osco-Umbrian aka "P-Italic" (Oscan pis ~ Latin quis "who"), the "P-Celtic" languages (Welsh pen < *kʷennom "head"), and most dialects of Greek (Attic hippos ~ Mycenaean i-qo "horse").
The usual explanation is that /kʷ/ has two articulations: one at the lips, and one at the velum (hence "labiovelar"). The change to /p/ involves losing the velar articulation and becoming purely labial. But it's also possible to lose the labial articulation and become purely velar; this happened in the "satem" Indo-European languages.
Notably, the /v/ derived from Latin /w/ and /b/ in certain environments did not become /p/ in Romanian: avea "have" < *avere < habēre.
EDIT: As TKR and pointed out, hippos isn't the best example since it comes from *ḱw rather than * (even if they may have merged before the change occurred). A better one, used by Cairnavon, is hepomai ~ Latin sequor.
Draconis
  • 65,972
  • 141
  • 215
    The labial in ἵππος actually isn't from a labiovelar, but from a cluster *ḱw (cf. Skt. aśva-). – TKR Sep 27 '21 at 22:02
  • @TKR True, but my understanding is that ḱw and kʷ merged early in Hellenic, so they went through the same develarization. – Draconis Sep 27 '21 at 23:48
    They couldn't have fully merged, or the reflex would be ἵπος. I suppose it's possible that *ḱw first became a geminate /kʷ:/, but there are clearer examples one could use. – TKR Sep 27 '21 at 23:54
    @TKR The notion that **ḱw* and **kw* have different reflexes in Greek is fringe. ἵππος would be the only instance of it, and as the geminate is not the only weirdness in that word, it's hard to take that as any kind of evidence. – Cairnarvon Sep 28 '21 at 07:04
    @Cairnarvon I've always seen it presented as communis opinio. Is there other evidence for the Greek reflex of ḱw? A priori the idea that kʷ > p and *ḱw > pp looks obviously plausible phonologically, whatever the problems with the initial vowel of ἵππος. – TKR Sep 28 '21 at 15:38
    @TKR I'm not aware of any other direct reflexes of **ḱw* (**ḱwṓ* obviously became κύων and is word-initial anyway, none of the other instances I can think of seem to have left any reflexes in Greek), but **ḱ* merged with **k* everywhere else, including before **u, as it did in the other centum languages, none of which show a contrast between *ḱw* and **kʷ*. As far as I know only Sihler has argued for such a contrast in Greek (could be he was repeating someone else, he's not good about indicating sources), and even he admitted the evidence, which is just ἵππος, isn't strong. – Cairnarvon Sep 28 '21 at 16:50
    @Cairnarvon Weiss presents the Greek contrast as a fact in his Latin grammar (p. 34), and Palmer implies the same. Certainly it would be good to have more evidence, but the idea is widely accepted AFAIK. (I don't see how the merger with plain velars is relevant -- we're talking about the contrast "velar + W vs. labiovelar", not "plain velar + W vs. palatovelar + W".) – TKR Sep 28 '21 at 17:19
    @TKR I was able to trace this proposal back to Meillet 1908 Introduction a l'étude comparative des langues indo-européennes (p. 64) https://archive.org/details/introductionltu01meilgoog/page/n98/mode/2up and I have never seen Antoine Meillet being described as "fringe" before. :) – Alex B. Sep 29 '21 at 13:26
