I am not a native English speaker. Recently i study some phonetics to improve my english pronunciation (and also french which i am currently studying). I noticed many words with phoneme /əl/ sound like [o] to my ears, like "peoPlE" or "canCEL". I feel like the final vowel of "cancel" and "cancer" sound very different. Can anyone explain this ? Thanks
3This reminds me of this picture of a preschooler's spelling attempts that does the rounds online every so often: ("chriego" for triangle, "srko" for circle, "ritigo" for rectangle). Which also makes me think it may be dialect- or accent-dependent, as reading "srko" for "circle" makes me hear an American accent. I don't think it would happen in a Australian accent like mine, but I could be wrong! – Tim Pederick Apr 28 '22 at 12:24
Short answer
A central lateral approximant, [l], will have an underlying vocalic resonance which can be plotted on a vowel quadrilateral in the same way as a regular vowel. The vocalic resonances of the various [l]s found in different languages vary in terms of their frontness and backness. Those l's whose vocalic resonances are central are usually referred to as 'clear' and those whose resonances are back (and which can therefore be thought of as being velarised) are usually referred to as 'dark'. Standard Englishes, like many other languages, use different allophones of l, depending on where the consonant appears in the syllable. In standard Englishes a dark l, [ɫ], is used in syllable codas and for syllabic consonants. This will have a [o]-like vocalic resonance, which is what the Original Poster has observed.
Full answer
The consonant /l/ in English is usually realised as an approximant. This means that although the tongue in such instances makes contact with the alveolar ridge, this doesn't prevent the air from flowing freely out of the mouth and there is no increase in intraoral pressure. The resulting sound is therefore phonetically vowel-like. The only difference between the production of an [l] and a vowel is that in the production of an [l] the blade of the tongue makes contact with the alveolar ridge and the side rims of the tongue are lowered and thus the air doesn't leave directly through the front of the mouth but flows out of the large side apertures this creates.
The resulting sound has an underlying vocalic resonance, or vowel-like quality, which, like other vowels, is affected by which part of the body of the tongue is raised and by the distance between this part of the tongue and the roof of the mouth. In other words, it may be described like regular vowels in terms of its closeness or openness along one dimension and its frontness or backness along another.
In most standard Englishes there are two common allophones of /l/. Broadly generalising, the /l/ which occurs at the beginning of syllables is realised with the vocalic resonance of a mid central vowel, something like [ə]. This is usually referred to as 'clear l' and is transcribed just as [l]. The /l/ that occurs at the end of syllables, in syllable codas, has the vocalic resonance of a close-mid back vowel or similar ( it may be anything from [ʊ] to [o]). This is /l/ is traditionally referred to as 'dark l' and is usually transcribed [ɫ].
The original poster has noticed, then, that dark l has the vocalic resonance of a close-mid back vowel. They could have a future career as a phonetician!
Vocalic /l/
It might also be that the Original Poster has been hearing instances of vocalic /l/.
For an increasingly large number of speakers syllable-final /l/ is now realised as a phonetic vowel, [ʊ], referred to as 'vocalic l'. In fact, many traditional RP speakers have long been using a vocalic l after bilabials in words such as people, but are simply unaware of it (and many will vociferously deny it right after producing one). The rise of vocalic l in RP, therefore, might be viewed as the spread of vocalic l to environments where it wasn't previously used.
- 4,002
- 15
- 39
6English /l/ is one of the last consonants native children learn to pronounce. And final syllabic /l/ comes off as /o/ very frequently when they're learning. In my partner's family childhood names become lifelong names, and her daughter Emily is known by everyone as Emo, because that's what she used to call herself. Note also that /w/ and /y/, the other approximants, are frequent substitutions for /l/; my daughter used to talk about her yunchbox when she was 4. – jlawler Apr 27 '22 at 15:13
1Have you listened to Eddie McGuire, who used to present the Australian version of "Who wants to be a Miwwionaire" - a TV program in which the maximum prize money is (according to Eddie) "a miwwion dollars"? – Dawood ibn Kareem Apr 27 '22 at 19:31
@DawoodibnKareem Very interesting! I'll have to hunt that down. [It's doubly interesting because l is normally clear before /j/ even though /j/ is phonologically a consonant. Eddie's variety seems to count /j/ as a fully fledged consonant allowing a vocalic l there. I'm assuming that he doesn't say 'mewwon' for 'melon', for example] – Araucaria - him Apr 27 '22 at 19:39
1No, he says "dollars" with an L sound (and presumably "melon" as well). It's only "million" that causes problems for him. – Dawood ibn Kareem Apr 27 '22 at 19:49
1Is this also the reason for yeísmo (pronouncing "ll" the same as "y") in Spanish? – dan04 Apr 27 '22 at 21:37
4Turning /lj/ into /j/ is definitely a thing in Australian English. Witness the way "Australian" itself gets turned into "Strine"! The process is something roughly like /əstɹeɪljən/ → /stɹeɪjən/ → /stɹaɪjən/ → /stɹaɪn/. – Tim Pederick Apr 28 '22 at 12:31
@dan04 Not sure, but see Tim's interesting comment re Australian English above. – Araucaria - him Apr 28 '22 at 12:35
