17
From my understanding, a tonal language is when a difference intonation of the word changes its meaning. Now: Italian for example (which I was told is not tonal) differentiates questions from affirmations simply on how you say the sentence (while other languages have things like a different word order or words indicating that what you're saying is a question): isn't this tonality, since you're changing what you're saying completely solely based on the pronunciation?
This is not just for questions: pretty much all punctuation represents a way of pronouncing the sentence which usually changes how people interpret it, and there's the fact that putting emphasis_ on a word will also (usually) change how people perceive the sentence, thus changing its meaning.
Don't most spoken languages do something like this? Is this tone, or is it something else?
Drake P
  • 111
AGL
  • 309
    Clearly Nicaraguan Sign Language is not tonal. – Joshua May 03 '22 at 01:12
    The tone differences between "We're having a baby." and "We're having a baby?" may change the meaning of the overall sentence, but they do not change the words themselves. In a tonal language, a different tone changes the individual words. – Mason Wheeler May 03 '22 at 17:19
    Don't confuse tone and intonation. Intonation is a suprasegmental feature. A tone in a tonal language is not. – Lambie May 03 '22 at 17:31
  • In Italian, changing how a single letter is pronounced changes the meaning of a word, for example vénti (twenty) and vènti (winds). How a sentence is pronounced to make it clear it's a question is a matter of intonation. – apaderno May 03 '22 at 17:41
    @apaderno That is is like Norwegian or Serbian (and Punjabi maybe?). It's tone, but only on stressed syllables, and so far as I seen, it only ever involves a small number of distinct tones. It's called "tonal accents" according to wikipedia. For some reason I don't know, it seems to be regarded as distinct from "true" tonal languages. – Omar and Lorraine May 04 '22 at 14:44
  • @OmarL Probably because in a tonal language that is true for every word. I was suggesting a better example using Italian (which is my first language). – apaderno May 04 '22 at 15:00
    @OmarL In Italian, these are distinct vowels, an open-mid and close-mid front vowel respectively, not a question of pitch accent. You are right though that the distinction between pitch accent and tone is not as clear cut as it is often presented. Tone sandhi occurs to some extent in all tonal languages, meaning that the actually articulated pitch of one syllable is to some extent determined by others in the word. Pitch accents just take this to an extreme where the pitch of all syllables is fully determined by the tone on a single syllable – Tristan May 05 '22 at 08:49
  • @OmarL Punjabi is usually described as fully tonal, not having a pitch accent. Japanese and Ancient Greek are other commonly cited examples of languages with pitch accents. Shanghainese arguably should be (as pitch of all syllables is determined fully by the tone on a single accented syllable), but it is usually described as tonal because it is a Sinitic language – Tristan May 05 '22 at 08:50
Most languages called tonal are more precisely described as having lexical tone. This means that tone conveys a meaningful distinction between different lexical items. E.g. in Mandarin, 妈 mā with a high tone means "mum", but 骂 mà with a falling tone means "to chide".
There are some languages with grammatical tone, where a shift in pitch conveys grammatical information. E.g. In the Ngiti language of the Democratic Republic of the Congo, four different tenses of the verb "to whistle" can be distinguished using tone alone: ma màkpěnà "I whistled" (recent past), ma mákpěná "I whistled" (intermediate past), ma makpéna "I will whistle" (near future), ma makpénà "I used to whistle" (past habitual). [source]
Intonation, and prosody more generally, can be used grammatically in a great many languages. A key distinction between this and grammatical tone however, is that grammatical tone occurs at the word level, whereas prosody occurs at the clause or sentence level.
This does open up a can of worms around determining what is a word and what is a clause, but in many instances, this is a useful enough distinction to be getting on with.
Tristan
  • 8,262
  • 46
  • Grammatical tone sounds like just a special case of lexical tone where the lexical items are just the different tense (or whatever other varies) forms - especially from a perspective where the language uses different spellings that convey the change in tone. – R.. GitHub STOP HELPING ICE May 03 '22 at 14:26
  • that seems to really stretch the definition of lexical to me. – Tristan May 03 '22 at 16:09
    @R..GitHubSTOPHELPINGICE Part of the definition of lexical tone is that it has the ability to produce the same effects as other phonemic elements; that is, if changing a /p/ into a /k/ will, a priori, change the meaning of the word in an unpredictable way, so will changing tone A into tone B. Despite not being segmentally distinct, lexical tones act a lot like just any other consonant or vowel. Grammatical tone does not: it is limited to a finite subset of combinations and the change in meaning is predictable. – Janus Bahs Jacquet May 03 '22 at 22:40
  • @JanusBahsJacquet: Thanks! That makes sense. But in real world languages, isn't it more of a correlation than a clear cutoff? That is, change in tone in general produces unpredictable change in meaning, but there are common patterns where the same shifts go with the same grammatical roles in some words. – R.. GitHub STOP HELPING ICE May 03 '22 at 23:19
    @R..GitHubSTOPHELPINGICE Well, that precise difference is the difference between lexical and grammatical tone. The two can coexist, though (as far as I know) they don’t usually, at least not fully; that is, languages that employ grammatical tone rarely use lexical tone to a very high degree, and languages that rely heavily on lexical tone (like Chinese, Vietnamese, Thai, etc.) rarely employ grammatical tone. – Janus Bahs Jacquet May 03 '22 at 23:24
13
It has been a long-standing challenge to define the difference between tone and intonation, since both exploit fundamental frequency as a physical exponent. The difference is generally drawn by reference to that which can be contrastive within the word (serves as a factor marking one word vs. another word), versus that which signals functional properties of collections of words in a sentence. However, intonational differences can be found within single words which are complete utterances, for you can utter "John" with various different pitch patterns, thereby signalling impatience with John, asking whether you are referring to John (vs. someone else), or sharply admonishing John. Also, there are languages like Zigua where lexically contrastive properties of one word (perhaps a specific noun, perhaps a particular verb tense) are realized not on the word that underlyingly bears that property, but on some following word (this is known as tone shift).
Attempts to define the difference in terms of physical substance simply don't work. The best characterization of the difference is framed in terms of how each functions, but identifying functions has proven tricky, because inflectional categories can be signaled with segmental affixes but also with tonal modifications: but the typical pragmatic distinctions signaled by intonation can also be signaled with segmental inflections. Indeed, the ambiguity reaches the point that one cannot definitively say, in certain tone languages, whether a certain regularity is the result of a tone rule, versus an intonational pattern. Example: in Shona, yes-no question can be signaled by changing a pre-pausal H tone to L – or by intonationally lowering the pitch of that H.
In other words, it may be impossible to devise a compelling argument that some fact of a language is "tone" versus "intonation". The main argument for treating that Shona phenomenon as a phonological rule of tone change is that is neutralized otherwise distinctive utterances. There is a theory that phonetic implementation does not fully neutralize phonological distinctions, which is IMO the most-viable diagnostic of the tone / intonation distinction.
user6726
  • 83,066
  • 63
  • 181
All languages have intonation (at sentence or phrase level), or the rise and fall in speech over an utterance but not all languages are called tonal.
Let's take Chinese (which I don't know at all). There is, however, a standard explanation of tones in Chinese as follows below.
So what is transcribed as MA in English has four tonal patterns.
Here is a chart of those tons:
The Complete Guide To Chinese Tones by Olly Richards [...]
Below is a graph showing you the pitch level of the four tones. And also the symbols used on top of the letters to represent them.
Chinese tones
So, in English, the letter a has many sounds and each is different. In Chinese, the pronunciation is the same for the phoneme is the same but it is the pitch ( flat, rising, dip and falling, are the typical descriptions of them in English ) within the phoneme that creates a semantic difference. This does not exist in a non-tonal language like English.
Take the word Ma, for mother in English. It will not be a change in pitch of the letter a that will make it mean something different. It will be the pronunciation of the a. For example, Ma meaning mother could presumably be: æ (as in mat) OR ɔː(as in maw) Those are two different sounds for the a in Ma. A child can shout out: "Ma, stop tickling me!" and draw out the a sound. Or, that same child can shout out: "Ma, I want to go now!" and rise and fall in the a sound, and that would be known as whining in English but does not change the word.
Whereas in Chinese, ma can mean: “mother,” “hemp,” “horse,” or “scold” depending on the pitch used.
It is rather difficult for English speakers to learn these tones after childhood. However, it can be done.
Please note though that this is nothing compared to Vietnamese which has six tones! So good luck with that, English speakers. :) I have tried over the years to hear the difference and cannot. (There are other tonal languages, like Thai, but I can't cover all of them. This is just meant to be a taste not a meal.)
Here's an explanation of them:
And notice how poetic this description of them in English is:
Vietnamese is a tonal language. Accents are used to denote six distinctive tones: “level” (ngang), “acute-angry” (sắc), “grave-lowering” (huyền), “smooth-rising” hỏi, “chesty-raised” (ngã), and “chesty-heavy” (nặng).
[Note: those tones also impact the written language.]
Vietnamese tones
Lambie
  • 729
    Not my downvote, but as I understand, isn't tone phonemic in Mandarin? Also a change in pitch contour is a change in pronunciation, surely? – Araucaria - him May 03 '22 at 02:07
  • @Araucaria-him Yes, it is a phonemic difference in Chinese but the difference comes from the pitch, not the syllable or letter after the m. – Lambie May 03 '22 at 17:26
  • The closest analogy I can give is some of the differences in the Vietnamese that are more difficult to hear is similar to the difference in saying "ahhhhhh" at the doctor and saying the same thing but with the slighest crackle of that sound that throaty sound the ghost in the Grudge makes. That's the difference between "mosquito" and "salt". – DKNguyen May 03 '22 at 17:34
  • @DKNguyen It must be amazing to be able to hear it. One day I asked a Vietnames lady to repeat the tones in several words over and over. And I was simply unable to hear them. :) – Lambie May 03 '22 at 17:39
