How does one decode a language? I bought a book the other day, and its like 3,000 pages worth of stuff. I'd like to read my book, but I'm not sure what language it's in or it's grammar, so what does the process of decoding a language look like? Who would I ask about this? How long would it take? Is it worth it?
Let us continue this discussion in chat. – Henery Johnson Oct 19 '22 at 21:27
The first step is to look for any indication where the book came from, for instance if the publisher is in Jammu, you would start looking at languages spoken in that (very) general area. I can write a book in English about things that happen in Central Africa, so you can only make limited use of subject matter or place of publication indicators.
Assuming there is no such information, and assuming that it is written in an unfamiliar script, you can look here. Ultimately what you need to do is compare your samples to all known scripts, which is a big but at least finite task. You might discover that it is written in Ancient South Arabian Script, which lets you eliminate many languages from consideration. Omniglot is the most-widely used online resource for looking up scripts. One problem is that most sources suppose that you have some idea what the history and typology of the script is, but you are asking about a script that you know nothing about.
Therefore you have to engage in pioneering efforts at decipherment. However, before getting too serious about that, you might look at other indicators, such as any artwork. Most places don't have Roman aqueducts; potted plants are a modern western development; Hellboy is a kind of contemporary meme. This raises the possibility, indeed probability, that the work is a modern western concoction. From the linguistic POV, this means you also have to consider that the supposed "language" is not a language, it is art that visually suggests "language". It could also be a con-script (constructed, not as in con-artist). Whereas actual language scripts are generally known (somewhere, perhaps not actually used), there are many con-scripts known only to a few people.
The first thing you do is collect all of the individual units. In your page, we can see a certain number of identifiable units, such as a think that looks like K and a thing that looks like F, then ò and so on. To the extent that you can reduce the system to a small set of recurring graphic units, you have taken the first stem towards decipherment. If you end up with 200 such units, that suggests one kind of system; 20 units suggests a different kind; 5000 suggests another kind (syllabary, alphabet, ideographic). This information may facilitate the slog through Omniglot or similar resources. In the present case, you should probably start here with the list of con-scripts.
If you can determine that the writing is e.g. "Ethiopic" (which it is not) then you follow a much more focused path, looking for presence of absence of certain letters which might rule out Amharic or rule in Blin. Then, if you can't find a speaker of the candidate languages to do the translation for you, you have to learn enough about the script and grammar to decide "No, that verb form is wrong for Blin, it could be Tigrinya".
- 83,066
- 4
- 63
- 181
Thank you! I got this at a pawn shop (I'm a conlanger and the handwriting was a big inspiration), so I've got nothing on it. The image does look a bit like HellBoy, but there are tons of red illustrations of a strange half-human thing. There are 36 symbols & what seems to be punctuation and spacing (though I'm not sure if the ⟨·⟩/⟨.⟩ symbol I assume to be punctuation is somehow a variant of the ⟨◆⟩), if that helps. I've tried them and it doesn't tell me much. The paper seems to be decently old, but reasonably so (my amateur guess is 2000~2010). Thanks for the detailed answer! – Henery Johnson Oct 19 '22 at 02:21
1@Henry Johnson: Can you describe the book's binding, if there is one? Outside cover, title page? Is it really more of a notebook? 2000-2010 is not old for a book. – Lambie Oct 19 '22 at 14:11
The pages are stuck onto a little hard-to-see spiral shape in a hard-cover like binding, but it all seems pretty crudely done. There is no title page, it just dives straight into whatever it's going on about. The cover is blank, and just has one word in the language "CheVng," written crudely in marker. It doesn't seem old, but it doesn't seem professional either. It looks like somebody tried to remove the spiral, and partially succeeded. There's also two strings put through the pages and the covers. The back of the book is just nothing. – Henery Johnson Oct 19 '22 at 14:18
@HeneryJohnson is there some reason you can't provide decent photos of all this, including several flat pages? – Tom Gewecke Oct 19 '22 at 19:57
@TomGewecke My phone is terrible, but I did provide a photo of a page. However, as Tristan noted, this question is not about the translation of a specific text, but the methodology thereof. – Henery Johnson Oct 19 '22 at 19:58
User6726's answer addresses how to decipher the text if you're able to identify the script (or at least a relationship to a known script), and does so well, but I'll attempt to address how you might decipher it if you aren't able to do so.
Deciphering unknown scripts can be hard, and if the language it writes (or a related one) is not documented can be even harder or essentially impossible.
The first thing you'd want to do is gather a list of distinct signs, together with their frequencies.
If this text actually encodes language, you'll expect this distribution to roughly follow Zipf's law. If it is wildly different it probably doesn't contain actual linguistic information.
As in user6726's answer, the number of distinct signs tells you something about the nature of the script. If there are thousands of signs, you're probably dealing with a logography (like Chinese hànzì); if there are hundreds it's probably a syllabary (like Japanese hiragana) or an abugida (like devanagari) if you can form a syllable table with each cell reasonably regularly derivable from the others in its series (each series will probably correspond to a consonant, and the columns to differing vowels); and otherwise it's probably an alphabet (like Latin) or an abjad (like Arabic).
Once you know the type of script, you can then make guesses as to the language and perform a frequency analysis, comparing the sign frequencies to the language (likely excluding signs you believe are punctuation, but it may be worth repeating with them included in case they are not actually punctuation).
For logographies you'll want to compare to word or morpheme frequencies, for syllabaries you'll want to compare to syllable frequencies, for alphabets you'll want to compare to phoneme frequencies (or possibly to letter frequencies if it may encode another writing system rather than the actual sound, something common in con-scripts made by people without much experience), and for abjads you'll want to compare to consonant frequencies. Abugidas can be treated as abjads (only looking at whole series) and separately comparing each column to vowel frequencies or can be treated as a syllabary (although this is likely to be more work and less effective).
This allows you to make guesses as to the values of certain signs which you can then use to try to transcribe parts of the text and see if it produces a comprehensible output.
As this relies on statistical methods it will generally be easier the larger your sample is. Deviations from expected sign frequencies will typically diminish like the square root of the size of the text due to the central limit theorem.
- 8,262
- 25
- 46
I tried doing it for a few pages and the text does seem to follow zipf's law. I think the script is an alphabet (because of the lack of diacritics), but it doesn't look like any alphabet I've seen. – Henery Johnson Oct 19 '22 at 12:21
1a lack of diacritics does not mean it's an alphabet. Syllabaries do not generally need diacritics, neither do abjads. From what you have said I suspect it probably is an alphabet of whoever wrote it's invention. I'd guess it probably encodes English (assuming you got it in an English-speaking country) and so that ought to be your first test, but if it is a conlang you're likely out of luck – Tristan Oct 19 '22 at 12:51
I doubt it's English, as the most common word throughout the text is "Ch" which cannot be a one-to-one for english's "the," so it must be phonemic transcription but that would imply that the word "C" is pronounced /ð/ which is impossible by english phonotactics. I believe that the number of symbols also points toward it being an alphabet. I suppose the most likely option is that it's either a rare language, a twin language (unlikely because generally such languages use words from the native language of their inventors and share a script with it), a hoax, or a conlang. – Henery Johnson Oct 19 '22 at 12:57
(cont.) I doubt that it's a conlang or a hoax, because if it were that means somebody made up a language & script, wrote a three-thousand page book nobody could read, and dropped it at a pawn shop for a couple of dollars. I already explained I doubt it's a twin language, for a multitude of reasons, which means it is most likely in a natlang. However, I am not sure which language it's in. – Henery Johnson Oct 19 '22 at 12:59
1the word C could be a reduced form of Ch before vowel-initial words (e.g. th'apple). I'd more normally expect a hard attack instead separating the two vowels but it may be different in different Englishes – Tristan Oct 19 '22 at 13:09
There are multiple cases of "C C..." which would be pronounced as /ð.ð. . ./. Perhaps this is simply a mistake on the part of the author, but I seriously doubt this is an English character substitution. @Tristan – Henery Johnson Oct 19 '22 at 13:21
1you may be right in that case, but further discussion along these lines is verging into us doing the work for you. Good luck in identifying the language and translating it! – Tristan Oct 19 '22 at 13:27
