Is vav-consecutive (converting perfect to imperfect and vice versa) unique to Biblical Hebrew or are there similar features in other languages, beyond the Afroasiatic family ?
See also this answer to Are there any languages where verbs in the past form are used with the future tense?
Clarification in response to comments: I am interested in conversion between tenses/aspects, not specifically in features which sound similar to vav/waw and/or resembling coordinating conjunctions.
psmears
  • 109
Roger V.
  • 980
    The Wikipedia article you link to describes the construction as arising on the way from Proto-Semitic to Central Semitic and says that, “Vav-consecutive is attested in other Northwest Semitic languages as well: with imperfect, in Moabite, in Deir Alla Inscription, and in Aramaic; and with perfect in conditional clauses, in Ugaritic, in Amarna letters, and in Phoenician. Yet, usage of vav-consecutive with perfect in a narration is unique to Hebrew.” – Does that not answer your question? – Janus Bahs Jacquet Mar 08 '23 at 15:22
  • @JanusBahsJacquet partially yes. I was mostly interested in going beyond the semitic languages. – Roger V. Mar 08 '23 at 15:23
    If the statement that the construction arose between Proto-Semitic and Central Semitic is correct, then the answer is presumably no: if it didn’t exist yet in Proto-Semitic, it can’t be shared with anything that branched off before Proto-Semitic either. It could have been borrowed into a neighbouring non-Semitic language later on, of course, but that seems unlikely, unless the target language was sufficiently closely related to be able to produce a proper parallel in its verbal system. – Janus Bahs Jacquet Mar 08 '23 at 15:28
  • @JanusBahsJacquet there could be similar constructions developing independently in other language families. – Roger V. Mar 08 '23 at 15:34
  • Theoretically, perhaps, but it seems extremely unlikely that a w-prefix with the specific function of switching a verbal conjugation’s perfect or imperfect semantics would develop twice. It could be that there are some circumstances in other languages in which the semantic denotations of two distinct forms/tenses/similar get switched around, but that’s much broader than just vav-consecutives. Germanic-style perfects with time frames almost fit that bill (viz., “I’ve been ill” meaning I’m not ill anymore vs “I’ve been ill for two days” meaning I’m still ill). – Janus Bahs Jacquet Mar 08 '23 at 15:52
  • @JanusBahsJacquet I don't mean that the sound should be exactly vav/waw or even that it should be similar in meaning to conjunction and. The question is about switching between temporal/aspectual forms (especially if in both directions). – Roger V. Mar 08 '23 at 15:59
    I think you should edit your question to make that clearer. As it stands, it reads like it’s just about vav-consecutives. – Janus Bahs Jacquet Mar 08 '23 at 16:01
  • @JanusBahsJacquet ok, I added a clarification. – Roger V. Mar 08 '23 at 17:12
As has been mentioned in the comments, forms corresponding to Biblical Hebrew wəqāṭaltí and wayyiqṭol exist in related languages. But these reflect a shared ancestor, or perhaps language contact, and not independent developments. So essentially I understand your question to be whether it occurs in other languages that a morpheme is used to "invert" (part of) the meaning of a form—based on the assumption that waC in wayyiqṭol "inverts" part of the temporal profile of yiqṭol, and that in wəqāṭaltí "inverts" part of the temporal profile of qāṭal.
But this assumption is flawed. The waw in neither of these forms is "conversive". This was an idea dating back to medieval grammarians, but has since been abandoned. Scholars don't agree how the Biblical Hebrew verbal system works precisely, but the notion of "conversive" forms cannot count on much support any more. There are several reasons for this.
For one, wayyiqṭol is etymologically distinct from yiqṭol. This can be seen in the forms of the III-ה verbs, biconsonantal verbs, and hiphil forms, all of which have a shortened form in the wayyiqṭol (e.g. wayyagged 'and he told' vs. yaggîd 'he will tell', hiphil of NGD). The wayyiqṭol goes back to a different form of the verb than yiqṭol. In many instances these forms have become identical due to sound changes, so that it seems that wayyiqṭol is based on yiqṭol, but from cases like the three mentioned before (III-ה verbs, biconsonantal verbs, and hiphil forms) it is clear that there were originally two distinct conjugations.
As for wəqāṭaltí, it is not clear that its meaning is really different from that of qāṭal. Most uses can be explained if the meaning of qāṭal is aspectual (perfective). The different stress pattern in some forms of wəqāṭaltí is inconsistent.
Another issue is that the meaning of the "converted" imperfect is not really that of the perfect, and neither is the "converted" perfect identical in meaning to the "imperfect". The wayyiqṭol is found in narrative texts to form the main story line where a distinction is made with qāṭal, which is often used for background information or a past perfect meaning. So it is not correct to say that wayyiqṭol has the same meaning as qāṭal.
All this to say that you are right to find these morphemes (when described as “conversive”) highly suspicious: there may not even be any language that uses morphemes to invert tenses.
A good recent study on these issues in Biblical Hebrew is Cook, John A. Time and the Biblical Hebrew Verb: The Expression of Tense, Aspect, and Modality in Biblical Hebrew. Linguistic Studies in Ancient West Semitic 7. Winona Lake, Indiana: Eisenbrauns, 2012. Of course not everyone agrees with Cook, but the book at least gives a very extensive review.
Keelan
  • 4,214
