12
As a native American English speaker from the Northwest, whenever I isolate the r in words like "right" or "rope" it's always /ɚ/, the same as the r in words like "first" or "girl" but the "ir" in first and girl is considered an r-colored vowel, but the r in "right" and "rope" is not considered a vowel
Going through the checklist for vowels:
Open vocal tract - check
Voiced - check
Nucleus of a syllable - while a lot of people would say no I'd say yes
Going back to words like first and girl, you could just as easily write them as "frst" and "grl" and they'd be pronounced the exact same (in American English), the extra letter is purely convention, the r is what's forming the nucleus, and in fact in American shorthand it's quite common to remove the unnecessary letters, in British English I could see the case for r not counting as a vowel since in words like first and girl the nucleus is moreso around the i, being pronounced more like "fest" and "gel"
Just as "turn" can be shorthand-spelled "trn" in American English, but "tun" in British English, and they make the exact same sound as the actual word in their dialect, because in American English the nucleus of the syllable is "r" but in British English the nucleus of the syllable is "u"
So if the American r fulfills all the requirements of a vowel, why isn't it considered one?
Wesley Inselman
  • 129
    Although the answer you got is extensive, I feel it's worth stating a relatively obvious thing (which is stated in the answer, but not prominently): something being a "vowel" from the phonetic point of view is not the same as it being a "vowel" from the phonological point of view. You may or may not be able to find a all-encompassing, good definition of phonetic "vowel", but regardless, when you're dealing with phonology, it's not so much about what the phoneme sounds like, but how it behaves. Hence rules like "nucleus of a syllable" (though you disagree), and user6726's tests. – LjL Mar 09 '23 at 18:42
  • Quick question: is the "w" in "how" or "claw" a vowel? How about the "y" in "toy" or "say"? R after a vowel behaves similarly to W and Y, as does R before a vowel. This is why we have the category "semivowel", for those tricksy sounds and letters that aren't quite vowels and aren't quite consonants, like W and Y and R and sometimes L. – No Name Mar 10 '23 at 12:22
  • @NoName: I would say that the "w" is not an independent grapheme in those words, but part of the digraphs "ow" and "aw" which each represent a vowel. – dan04 Mar 10 '23 at 16:00
    Are you suggesting that /r/ represents a vowel in "right" and "rope?' That seems like a really slippery slope. If it does, we would be essentially required to also call the /j/ in "yes" and the /w/ in "what" vowels, which no one does ("semivowels" is the farthest we go). In addition, English doesn't really permit two vowel phonemes to exist in the same syllable - a rule which would have to be amended to allow your proposed classification. – Graham H. Mar 10 '23 at 17:28
  • @dan04 Which is the exact same case with the "r" in the digraphs "er", "ir" or "ur", or with any R after a vowel in a non-rhotic dialect. I admit I'm blurring the line between spelling and speaking a bit, but the letters W, Y and R all behave identically after a vowel letter: They combine into a digraph that represents a single vowel sound, often a diphthong, but also often not because of that blasted Great Vowel Shift – No Name Mar 11 '23 at 11:50
  • Give this a listen: https://www.youtube.com/watch?v=Tjf_MOyB0K4 . It addresses when R acts like a vowel or consonant, and for which speakers. – Michael McFarlane Mar 13 '23 at 18:16
Many phonologists do consider "r" in "girl" to be a vowel, I being one. There are many reasons for people to consider it to not be a vowel. First, in "rabbit", nobody considers "r" to be a vowel, only syllabic r is a vowel. Second, "vowel" is a vague term in phonology, given the wide range of terms that can be used to talk about sounds. Vowel may be used to refer purely to degree of constriction, or it may be used to refer to prosodic status – a vowel is a thing in the syllable peak. Classical vowels like [a] satisfy all definitions of vowel and classical consonants like [k] usually satisfy none of the definitions for vowel, except in a few languages there are (controversially, e.g. in Berber) syllabic stops which are syllable peaks.
Also, it is clear that surface syllabic consonants in English can be derived by rule from əC sequences. There is a line of reasoning that says that if you can reduce all instances of [ɹ̩] to /əɹ/ then you should, so surface [bɹ̩d] could then come from /bərd/. This choice depends on a premise that one should minimize the number of underlying segments, a premise that is not universally accepted.
There is a distinction made in phonetics between approximants and other kinds of consonants – American English r is an approximant. Vowels and approximants share the phonetic property of minimal constriction. There are theories of phonological features with a feature "consonantal" which puts most consonants into the consonantal set, and vowels & glides into the non-consonantal set (this does not include /l/). The flapping rule provides evidence that r is in the non-consonantal (vowel-like) set: you get flapping in writer, sitter, barter, murder and not in falter or banter unless you delete the nasal and have a nasalized vowel (bæ̃ɾɹ̩).
Your feeling about r in rope etc. probably comes from "isolating" the consonant. There is a test for vowel status at the beginning of the word – the choice "a, an". I feel confident that you say "a rope" and not "an rope", but "an apple, an urn".
user6726
  • 83,066
  • 63
  • 181
    I think you may have misread the question. Much of this answer seems to be addressing the question "Why does no one consider the in 'girl' to be a vowel?"; but in point of fact, the OP didn't ask that question, and on the contrary, states that the in "girl" is considered a vowel. The only part of this answer that relates to the OP's question is the last paragraph. Can you maybe expand that paragraph, and drop the rest, to focus on the relevant answer? (If you're loath to throw away your work on the first few paragraphs, maybe you can write a self-answered question?) – ruakh Mar 10 '23 at 08:21
