Why does the English complementizer "that" look like the relative pronoun "that"?
for those
This question may need to be carted off to the English Stack Exchange, unless there are other languages in which complementizers and relative pronouns also resemble each other.
James Grossmann
  • 8,730
  • 41
  • 83
The reason is no doubt that, as in many other languages, the complementizer/conjunction introducing indirect speech comes from a neuter relative pronoun. The archaic/hypothetical construction was "I tell you that, that happened..." (meaning "I tell you that, which happened"), or "I tell you, what happened...". This neuter relative pronoun later acquired the characteristics of a conjunction, and the (hypothetical/potential) antecedent disappeared.
Neuter relative pronoun / conjunction-complementizer / neuter demonstrative pronoun:
  • English: that / that / that
  • Dutch: dat / dat / dat
  • German: das / daß / das
  • French: que / que / ce
  • Latin: quod / quod / hoc(ce) (or id, etc.)
  • Greek: ho(ti) / hoti / ho(de)
Note that the first two words have the same root in each Indo-European branch—Germanic, Italic, and Greek. Note also that the conjunction in classical Latin is not normally used to introduce indirect speech, for which the accusativus cum infinitivo was used, but for other, related subordinate clauses. In Greek, hoti could introduce indirect speech or a causal subordinate clause; the a.c.i. was more common for indirect speech, though. In Latin, the various uses of quod can serve as a nice illustration. All the following constructions/meanings are possible:
Mihi placet templum, quod fecisti. — "Me pleases the temple, that you made."
Mihi placet id, quod fecisti. — "Me pleases that, that you made." (i.e. "that, which")
Mihi placet, quod fecisti. — "Me pleases, what you made."
Mihi placet, quod fecisti. — "Me pleases [the fact], that you have made/done [it]."
Erravisti, quod fecisti. — "You have erred [with respect to the fact], that you have done [it]." (i.e. you have made a mistake with respect to doing this)
Peribis, quod fecisti. — "You will perish [because of that], that you have done."
Peribis, quod fecisti. — "You will perish, because you have done [it]." (most common usage of quod in the classical age)
% Dicit, quod fecisti templum. — "He says, that you have made the temple." (only in Mediaeval Latin, possibly Vulgar Latin)
Cerberus
  • 7,976
  • 49
  • All the English grammatical terms beginning with TH- (including the, that, then, there, thither, etc.) come from the PIE root *kʷo-. Just as all the English grammatical words beginning with WH all come from the PIE root *to-. In Germanic languages, PIE t changed to þ (which later became /ð/ in modern English), and PIE kʷ became /hw/, spelled WH, all courtesy of Grimm's Law. – jlawler Nov 17 '13 at 16:41
  • @jlawler: Right, I should probably have added information about the etymologies. I think your first two sentences contain typos, though? TH- comes from to-, WH- from kʷo-. – Cerberus Nov 17 '13 at 16:46
  • Yes, you're right. Sorry, but thanks for noticing. too late to change it, though. Anyone in doubt can consult Grimm's Law. – jlawler Nov 17 '13 at 16:55
