This question is influenced by another one I found on the German SE, "Warum nennt man in Deutsch die Zahlen 0, 2, 4 … “gerade” Zahlen?". It asks "Why call Germans the numbers 0, 2, 2 "even".
The following languages have these pairs:
  • German: geradeungerade;
  • Italian: paridispari;
  • Portuguese: parÍmpar;
  • Spanish: parimpar;
  • Russian: чётноенечётное.
Note that for all of them 'even' is expressed by the basic form and 'odd' is derived from that form.
Other languages like English use different words even and odd.
Edit:
I modified the question in reaction to the comments to reduce the number of possible results.
Are there languages where odd is expressed by the basic term and even is derived from that?
bernd_k
  • 369
    There are over 6,000 human languages currently spoken - you may want to reword the title of this question, unless you really want a list. – Alek Storm Oct 10 '11 at 18:38
  • @bernd_k I took the liberty to change the formatting of your question. I think the sense is the same. If you want to further improve it, you're obviously free to do so. :) A note: if you can provide a rough translation of that linked question, it would be really nice! :) – Alenanno Oct 10 '11 at 18:40
    Note that in English we do have the word uneven, which, while not being completely interchangeable with odd, can be used in a lot of the same environments: "They added a chair at the end of the table because we had an uneven number of people in our party." – musicallinguist Oct 10 '11 at 19:35
    Still, this question will generate a list which probably will not be useful – Louis Rhys Oct 11 '11 at 03:10
  • Yet another question that while people object to it here would be fine on the proposed languages.SE site. – hippietrail Oct 12 '11 at 09:03
    The question asks whether some language (with some properties) exist. I cannot see how a list would answer it logically. If such a language exists, the answer “Yes, Syldavian has this property.” would be definitive. If no such language exists, the problem is that we might never get an answer. (An intermediate option would be “This question is addressed in this paper of the Syldavian Society of Linguistics; they say they couldn't find any such language and they have a tentative explanation of that phenomenon. Such an answer would be very interesting.) – JPP Oct 12 '11 at 12:30
  • Danish: lige - ulige – mplungjan Nov 07 '11 at 21:17
    @JPP The problem is that only one answer may be accepted, and if there are multiple "correct" answers then accepting any one would be arbitrary. The best answer would not be simply a citation of a single language, but a link to research and a discussion of the applicability of that research. – Mark Beadles Oct 18 '12 at 16:28
    @MarkBeadles Correct. Although the part where JPP says that "this paper says there isn't such a language" is a good answer too. As long as they are not link-only answers or very poor answers, any "answer" is OK (i.e. be it negative or positive about the results). – Alenanno Nov 01 '12 at 11:12
  • Languages tend to use even-uneven (=odd) all your examples do that, additionally Hungarian: páros-páratlan – snuki Oct 06 '12 at 18:30
I think your question may reflect an instance of a much more general pattern. That is, suppose you find an expression X in a language, and another expression Y in that language, and you believe X and Y to stand in a "privileged" relation (two types elaborated below). It seems that, across languages, one is likely to find that X and Y occur as simplex (i.e., nondecomposable) lexical items asymmetrically: i.e., if Y occurs as a simplex lexical item in the language, so does X. But simplex X occurring in a language does not guarantee expression of simplex Y.
One concrete example to explain one notion of a "privileged" relation between two expressions is privileged antonymy. Consider the adjectives tall and short: we "feel" that these expressions are related in a way that makes the inferences in (1) and (2) valid, but not that in (3) (despite long on occasion meaning something very similar to tall):
  1. Mary is taller than John |= John is shorter than Mary
  2. Mary is shorter than John |= John is taller than Mary
  3. Mary is longer than John !|= John is shorter than Mary (where !|= reads as "does not entail")
Given what was discussed in the first paragraph above, we thus expect a language to exist where there is no word for short, but that conveys such a meaning via negating the positive adjective, e.g. not tall. One never expects to find a language that does the reverse, e.g. where short occurs with not short, and expression of simplex tall fails to occur.
Describing strong versus weak meanings, Larry Horn in his 1972 dissertation gives nice examples using the dual modals must and may, and adjectives like (un)able and (im)possible, to observe that in general, it seems the "positive" or "stronger" of a dual occurs as an expression simpliciter, while the "negative" or "weaker" is likely to occur as a combination of the positive/stronger expression with a negative marker. Note that such a synthetic construction carries exactly the (logical) meaning of what the negative/weaker expression as a simplex lexical item would carry.
Horn has some speculations about why this asymmetric pattern may obtain, but it has not so far been explained in detail, and how far such phenomena extend throughout lexical semantics is (I think) unknown. Understanding that the patterns even/ odd and even/ not even exist cross-linguistically, as opposed to odd/ not odd, feels of the same flavor of the above spread of examples. It is unclear to me how one might cast the pair even/odd in terms of antonymy or strength, however.
Alexis Wellwood
  • 1,966
