While I am not interested in hearing the common distinction made in introductory text-books, I am interested in hearing what meaningful distinction there can be between morphology and syntax. Is there any structural, or rather formal, difference between the two? Also if that distinction requires the concept of word, how does one formally describe that?
3Could you try to rephrase this (or at least the subject) as a question? – kaleissin Oct 17 '11 at 19:07
12For what it's worth, some people don't believe there's a meaningful difference between syntax and morphology. I think this is still a great question, since many people do believe in that difference and articulate it formally in various ways. But it's worth remembering that it's not totally uncontroversial. – Leah Velleman Oct 17 '11 at 19:14
1@DanVelleman +1 That would be the understatement of the year ;). I don't think anyone's yet found a bulletproof set of criteria for distinguishing syntactic from morphological phenomena - the debate has recently spilled over into psycholinguistics as well. – Alek Storm Oct 17 '11 at 19:31
Whatever you think morphology is and whatever about syntax, they do seem to be set together away from phonology on one side, and semantics/pragmatics on the other. – Mitch Oct 17 '11 at 20:14
@Mitch Are you implying that phonology and semantics/pragmatics do not interact? How do you explain the use of prosody in English to indicate the focus of an utterance? – Alek Storm Oct 17 '11 at 23:07
@Alek: not at all. I'm just saying within the groupings I mentioned there is a family resemblance that is not shared outside of the group. – Mitch Oct 17 '11 at 23:37
@Mitch I don't follow. Could you be more explicit? – Alek Storm Oct 17 '11 at 23:42
@Alek: phonology - sounds, syntax/morphology -words and word order, semantics/pragmatics - meaning. – Mitch Oct 18 '11 at 00:47
@Mitch Yes, I know the definitions of the relevant terms. What exactly do you mean by a "family resemblance" between them? – Alek Storm Oct 18 '11 at 01:55
@Alek: morphology and syntax have a family resemblance/are more alike each other and semantics/pragmatics are more a like each other, but between those two groups there is less likeness (in contrast to the usual strict demarcation: phonology, morphology, syntax, semantics, pragmatics). – Mitch Oct 18 '11 at 02:05
4'Word' is usually defined on a language-by-language basis, very problematic trying to develop a universal definition. Even within a single language there may be a distinction between the phonological word and the morphological word. As such, morphology and syntax can be easy to distinguish within a given language, but coming up with a cross-linguistic distinction is much more different. – Gaston Ümlaut Oct 18 '11 at 23:21
Note also that people often talk about "morpho-syntactic analysis" or "morpho-syntactic shizzle"; so they are often closely connected. – Cerberus Oct 21 '11 at 04:24
To add some connections to this question: It seems like what usually causes people to ask this question is studying agglutinative languages like Japanese. Traditional Japanese grammar considers "particles" to be different words (?bc. Chinese analytic grammar), while modern linguistic theories call them "suffixes" (?bc. European fusional grammar). This leads me to wonder whether adjectives, articles, prepositions, and auxiliary verbs should be called prefixes, and if the "separable verbs" in German and "circumpositions" in Persian can be one word, could other structures with words in-between? – Mr. Nichan Jul 02 '19 at 08:30
The Oxford Concise Dictionary of Linguistics defines morphology as 'The study of the grammatical structures of words and the categories realised by them', and syntax as 'The study of grammatical relations between words and other units within the sentence'.
As you point out in your question these (pretty standard) definitions depend on the notion 'word' to delimit the domains of each subject. The notion of 'word' is problematic as there's no good definition that applies across all languages. It seems that it's best (or easiest) to define 'word' on a language by language basis, although even then there are problems as different kinds of 'word' can often be distinguished depending on the sets of criteria used: often there is a 'prosodic word' (defined on phonological bases) which differs from the 'grammatical word' (defined in terms of morphosyntax).
If 'word' can be precisely defined in a given language then the domains of morphology and syntax can be fairly clearly distinguished, but if not then there is not a clear boundary.
So cross-linguistically the notion of 'word' is fuzzy, as are the terms 'morphology' and 'syntax'. But for most languages, and in most cases, it's still pretty clear what's meant by these terms; and of course there's the term 'morphosyntax' for boundary cases. So while these two terms are not precise they are still useful as a general way of referring to certain domains within a language.
- 14,687
- 7
- 61
- 146
- 6,697
- 30
- 46
The very first thing on the Syntax Topics handout for my linguistics classes was:
Syntax and morphology are the two parts of grammar.
- Morphology deals with the internal economy of the word.
- Syntax deals with the external economy of the word.
By which is meant that things that take place within the word are morphological, and things that take place between words are syntactic. Without a sense of "word", there would be no easy way to distinguish. But we'd need to distinguish anyway, because there are big differences between grammar as expressed morphologically and grammar as expressed syntactically. And plenty of examples to deal with.
In particular, there are many analytic languages where grammar is almost all syntax, like English or Mandarin; and also many synthetic languages where grammar is almost all morphology, like Russian or Inuit. In an analytic language word order is terribly important, and there are many little auxiliaries and articles and particles to augment the word orders. In a synthetic language, word order is mostly a matter of style or taste, because the structure of the sentence is all tied up and color-coded with the agreement phenomena that morphology enables.
There are other differences as well. Bound morphemes are very fussy about their order, and normally don't tolerate any variance. Syntax, however, spins off variation at the drop of a syllable, resulting in many competing patterns which frequently die off, but just as frequently fission into separate constructions. These are very different kinds of things, even if they do somehow "cover the same ground" semantically. It's not necessary to restrict one's observations to only the generalizations one wants to capture. Generalizations are nice, but facts are more useful.
You may encounter people who insist that "syntax" means "grammar". That's just the theory talking; normally they're just parroting somebody else's dictum, and normally this marks them as generative theory adherents. That's harmless unless you think they mean what they say; really they just want you to use their terminology as a mark of its superiority. Sort of like saying that "Mercedes-Benz" means "automobile". I.e, it's not true, or even really helpful, but it lays out your allegiance clearly and that's the important thing.
- 10,042
- 31
- 55
I think another way of getting at the same kind answer is to ask what can be done in morphology that can't be done in syntax. There are approaches to morphology where much of what is traditionally considered with morphology is handled with the same kind of formalism as is used in syntax, and morphology may be referred to as "word syntax" on occasion. However, I do not know of approaches to syntax that strive to account for most common syntactic phenomena using the language of morphology.
When word derivations have hierarchical structures, and affixes are given the status of functional heads, it may seem like it's syntax all the way down. There are some facts about inflectional morphology, however, which make syntax-like accounts difficult to pursue to their logical end. (See Ch.1 of Stump 2001 "Inflectional morphology" for discussion) One of these is non-concatenative morphology. In affixal morphology, it is not a real problem to treat the stem and affix as constituents of a tree: [[dog]N.root [-z]PL]N -> dogs. When the morphology is non-affixal, there is a dilemma. But how is "men" derived? In Distributed Morphology, stem-changes are handled in the following way: a zero affix triggers a "readjustment rule" which changes the stem vowel: men = [[man]N.root [zero]PL] -> /man-zero/ -> men. Stump considers this a resort to "extraordinary means", since it seems like quite a large coincidence that so many languages should have an identical (zero) affix triggering stem changes. Non-concatenative morphology is a challenge for syntax-like approaches to morphology because the basic units of syntax are considered to have a strict precedence relationship: for two constituents X and Y, X must either precede Y or follow it; tertium non datur.
Another issue is morphologically-conditioned phonological rules. Particular morphemes often trigger specific types of phonological alternations in a language (e.g. changes induced by suffixation of -ity on English nouns), but comparable syntactic phenomena, where, say, a particular type of category triggered an idiosyncratic phonological process in a sister constituent, seem very rare.
A third issue is variable exponence. A given property, when realized morphologically, may have a wide range of unrelated exponents. In a single language, plural on nouns may be realized by either a prefix, a change in the stem vowel, or a change in the tone, depending on the word. Parallel phenomena are hard to find in syntax.
If the issue is whether there should be a distinction at all, I suspect that it is in theory possible to remodel our theory of language structure so that syntax and morphology are modeled in the same way, but at the moment there are quite a few details of morphology which do not lend themselves to a syntactic explanation.
Let me fail to answer your question by asking another question -- what do we GAIN by drawing the distinction? By "ironing out" the distinctions, we can avoid having to postulate quite different grammatical architectures for polysynthetic vs. analytic languages, and we can capture the fact that there are generalizations across these languages. If we have distinct notions of morphology and syntax, the fact that subjects and objects agree with the verb in certain ways regardless of whether there's a word boundary between them or not is completely accidental. Put differently, why should we have phonological atoms be the same as syntactic/semantic atoms at the cost of generality across typologically distinct languages? Remember, although it gets debated a lot in various circles in Linguistics, the standard analyses of verbal morphology in English has pretty much always been syntactic at its core in the Chomskyan generative enterprise since LSLT!
- 734
- 4
- 7
2The distinction between syntax and morphology arose because they are two separate things in non-analytic languages. It is only in analytic languages that the divisin is blurred. That is to say, it works for English and some other languages but doesn't for the rest of the world. Keeping the distinction does not in any way prevent anyone from having the insights you mention. Abolishing it, on the other hand, introduces confusion into the description and understanding. – kamil-s Feb 26 '12 at 17:05
Actually, the traditional distinction between morphology and syntax is pretty clear. Morphology studies how words are inflected and new forms created, while syntax studies how they are combined into phrases and sentences. So, for example, do > does would be an issue in morphology while dog barks : does dog bark? would be an issue in syntax.
The whole confusion arose in the Anglo-Saxon world because English expresses with syntax most of what non-analytic languages express with morphology. As long as the main objects of study for linguistis were Latin and Greek, I don't think anyone mixed the two terms. But after WW2 English became the dominant language and with it, the confusion spread.
Linguists who are under weaker influence of American linguistics, however, i.e. those who did not study in an Anglo-Saxon country, or who do not specialize in theoretical linguistics, usually make a very clear distinction between syntax and morphology, often combined with looking down on those who don't.
You ask if the distinction is meaningful. Absolutely. It is only in a purely analytic language that syntax can tackle the issues of morphology. But not even English is purely analytic, so if you stick to the traditional understanding, even in English there are problems (e.g. the formation of plural) that syntax can't deal with. It is only because there is so little morphology in English that the term syntax came to mean for Anglo-Saxons both syntax and morphology simultaneously.
- 1,882
- 16
- 17
