I know what ergative verb is -
Consider the following sentences -
  1. I opened the door.
  2. The door was opened (by me).
  3. The door opened.
The verb open is a transitive verb in sentence #1, and sentence #1 is in active voice. The doer here is I, and what is affected by my action is door
Sentence #2 is in passive voice.
Sentence #3 is in middle voice. The verb open is used as intransitive way. And here the doer of the action (verb) is not important and is not mentioned. What is affected is the subject - door. So here the verb - open - is used in ergative form.
Consider sentence #1 and sentence #3. The object of the transitive verb in sentence #1 is the subject of the intransitive verb in sentence #3.
But all intransitive verbs can't be used in ergative form, nor all ergative verb can take everything as subject. For example -
He fired a gun.
The gun fired.
He fired a bullet.
A bullet fired (we can't use "bullet" as the subject of this ergative verb) - Incorrect sentence
MY QUESTION -
  1. All ergative verbs are transitive verb in nature. But when they are used in ergative form they acts as intransitive. Am I right?
  2. How to decide which verb can be used in ergative form and which verb can not? Is there any technique - logical or grammatical or anything else?
  3. How to decide which subjects are appropriate for a particular ergative verb, and which are not?
Man_From_India
  • 335
  • I think the distinction has to do with thematic roles of the object. "Bullet" would be the patient, and "gun" would be the theme or instrument. – prash Jul 18 '14 at 17:04
    I would suggest that you not use the terms "middle voice" and "ergative" when talking about English. These terms have a very precise meaning in linguistics, which is not the meaning that you are giving them. – fdb Jul 18 '14 at 17:04
    @fdb It's not so cut-and-dried as that. If you Google or Google-book 'English ergative verbs' or 'English "middle voice"' you will find the terms are often used in both scholarly and pedagogical contexts, alongside terms like 'mediopassive' and 'ambitransitive', to describe the English-language phenomena OP is concerned with. – StoneyB on hiatus Jul 18 '14 at 20:06
    wrongly, I would maintain. – fdb Jul 18 '14 at 21:00
    @fdb Perhaps - but no wronger than most of the old grammatical terms we've borrowed from Latin and Greek, or new ones that shift their application as they move from one language - or one linguist - to another. – StoneyB on hiatus Jul 18 '14 at 22:59
  • I'm not so sure "A bullet fired" is bad. I understand without a problem, and I doubt that it would strike one as bad in context. – Tim Osborne Jul 18 '14 at 23:23
    To call any English verb "ergative" is to use a metaphor. Whatever else English is, it's not really "ergative". What's at issue here is a pattern of lexicalization of stative, inchoative, and causative predicates. There are several different patterns, and some people have called some of them "ergative". This does not mean they are ergative, just that they seem to those linguists to resemble the way real ergative languages like Mayan or Caucasian or Australian languages behave. In some ways. – jlawler Jul 19 '14 at 00:42
  • Are you asking about English specifically or across languages generally? If the former please add the English tag. – hippietrail Jul 19 '14 at 04:18
  • "Middle" voice is actually one of "the old grammatical terms" borrowed from Greek and denotes a specific conjugation in Greek, Sanskrit etc. – fdb Jul 19 '14 at 08:50
  • @StoneyB How to decide which verb can be used in ergative form and which verb can not? Is there any technique - logical or grammatical or anything else? – Man_From_India Jul 19 '14 at 13:16
  • @prash Can you explain it a little more with, may be, some examples? – Man_From_India Jul 19 '14 at 14:07
  • @jlawler do you mean it like this? Say for example - I opened the door. I caused the door open. The door opened. This way we get "open" as ergative. Is it what you mean? – Man_From_India Jul 19 '14 at 14:09
  • @jlawler But if you take this example - the rose smells good - it can't be explained the way I mentioned just above this comment. Is there any other way to know which verb to use as ergative way and which verb not to? – Man_From_India Jul 19 '14 at 15:10
    @Man_From_India: No, that's not what I mean. If you want to call intransitive open an "ergative verb", that's up to you. I wouldn't. I'd just call it an intransitive stative verb. The rose smells good is completely different; this smell is a flip sense verb, with quite different syntax. I don't see anything to be gained by calling either of these verbs "ergative", especially since ergative is a term reserved for transitive subject nouns only. – jlawler Jul 19 '14 at 15:59
    @jlawler Since I believe I am the person who introduced OP to these uses of "ergative" and "middle voice" I owe some explanation. 1)There is at least a pedagogical need for a term embracing English verbs, like fire and open in OP's example, which appear with both agentive and non-agentive subjects. 2) I have employed the term "ergative verbs" since the early 1970s, relying on Lyons' Introduction to Theoretical Lingustics (1968), p.352: "The term that is generally employed by linguists for the syntactic relationship that holds between [The stone moved] and [John moved the stone] is... – StoneyB on hiatus Jul 19 '14 at 19:22
    'ergative': the subject of an intransitive verb 'becomes' the object of a corresponding transitive verb, and a new ergative subject is introduced as the 'agent' (or 'cause') of the action referred to. I am not alone in this use, as a Google-book search will show. 3) As for 'middle voice', English grammars have applied this term to verbs which behave this way since the early 19th century. – StoneyB on hiatus Jul 19 '14 at 19:35
  • @jlawler Thank you. I am not into anything about naming, call it whatever. But I am more concerned about this aspect of verb. *He opened the door. The door opened. He broke her promise.* but not *Her promise broke.* My question is how to decide which verb has got these kind of aspect and which verb don't. One thing is clear if the verb changes state as well as can take a causative we can use that particular verb this way. Is their any other technique to distinguish these kind of verb? – Man_From_India Jul 20 '14 at 01:18
  • Maybe you mean unaccusative verbs? I don't think ergative should be used in regard to English. – curiousdannii Jul 20 '14 at 05:45
    @curiousdannii Ok call it so. No problem, but how to test a verb whether it has unaccusative property or not. – Man_From_India Jul 20 '14 at 06:01
  • @Man_From_India what do you mean by "property"? I'm not sure whether these ergative/anuaccusative verbs are really all that distinct from regular verbs. Maybe it's just how they're used? – curiousdannii Jul 20 '14 at 06:19
  • @curiousdannii I mean how to test a particular verb to be used like an accusative verb or not. How to determine whether a particular verb is unaccusative or not. – Man_From_India Jul 20 '14 at 07:34
  • Please consider moving this to the [Chat] or another room if you prefer. It's hard to follow long threads under questions. – Alenanno Jul 20 '14 at 08:53
  • @Alenanno I don't know how to move this discussion into chat. Do I have to create room naming the same title of this thread? But how people will be notified? – Man_From_India Jul 20 '14 at 13:31
  • @jlawler Please tell me how to test if a particular verb has this property or not. – Man_From_India Jul 20 '14 at 13:32
  • Define the property and you define the tests. I haven't seen anything like a definition for what makes a verb (or does it refer to predicate adjectives and nouns too?) "(un)ergative". Oh, and I don't do chat. – jlawler Jul 20 '14 at 14:59
  • @Man_From_India You can name it what you want within reason. Maybe using the topic of the conversation is the best solution but again, up to you. – Alenanno Jul 20 '14 at 15:44
"The door opened"
One could derive this from "The door opened itself" with drop of "itself".
Of course, one can explain this with the linguistic term ergative. But the traditional grammar has no problem to explain such verb use with traditional terms (reflexive with drop of the ref. pronoun).
rogermue
  • 448
I do not have the linguistic competence of the users who commented the question. So I only took the question as asked, and looked also at wikipedia,
And the concept, as presented, looks very arbitrary to me.
Here are examples involving the verbs open and float.
1.a: The door opened,
1.b: He opened the door to a small garden,
2.a: The trunk floated,
2.b: He floated the trunks down the river,
2.c: The man floated near his capsized boat.
According to the analysis of a previous question, case 1.a is an ergative use of the verb open, used transitively in 1.b. But then the sentences 2.a and 2.b should be analyzed in the same way, which implies that 2.a is an ergative use of the verb float. But then, sentence 2.c should also be ergative. Is that the case?
And then, in successive variations, what of:
The man stood near his boat
The man walked near his boat
The dog walked near his boat
The man walked his dog near his boat
About question 1:
Wikipedia's answer is:
In linguistics, an ergative verb is a verb that can be either transitive or intransitive, and whose subject when intransitive corresponds to its direct object when transitive.
This seems to be illustrated by the question examples. But if you look at the second example:
He fired a gun.
You can also say:
The gun fired a bullet.
and that is transitive.
But what if the verb shoot is used.
He shot the gun
He shot a man
The gun shot a bullet
The gun shot a man
Though I am not sure one would say intransitively
The gun shot
So it all seems a bit more complicated that the simple rule of Wikipedia and your first question,
babou
  • 1,477
In order to understand what is meant by 'ergative verb' in English, it may be important to understand the concept of ergativity in the first place. Ergative (or ergative case) generally refers to the marking of agent in transitive constructions while the agent in in-transitive constructions is not marked or is marked in the same way as the patient of a transitive construction (this is called absolutive). Languages where the ergative construction dominates are called 'ergative languages' (although there are no pure languages and there is great variation in the alignment of intransitive Subject, transitive Subject [called Agent] and Object [sometimes called Patient] across languages).
This is in contrast to the accusative languages where the dominant way of marking the X Yed Z construction is like in the English: 'She killed him.' (Xnom Yed Zacc).
In this context, it makes no sense to talk about ergative verbs. Just ergative constructions or ergative case marking on the Agent (and/or absolutive on the Patient).
The ergative verb in English refers to verbs that are normally transitive but that can be used without specifying the object because the object is also the subject.
So compare the verb open when use as in
  1. John opened the window. / John baked the cake.
  2. John opened for Mary. / John baked all morning.
  3. The window opened. / The cake baked in 20 minutes.
  4. ?The windows opened itself. / ?The caked baked itself.
Only the examples in 3 are ergative because the unexpressed object (patient) and subject (agent) are the same.
An easy test of this is whether the sentence can be passivised with the indirect object marking the agent.
  1. The window was opened by John.
  2. (The door/it/something) was opened by John for Mary.
  3. *The window was opened. / *The window opened by John.
  4. The window was opened by itself. (in some sort of cartoon universe)
To answer your questions directly:
  1. All English ergative verbs are transitive (although some may also have intransitive variants). Ergativity is about expressions of transitivity.
  2. The decision on whether a verb can be used as ergative is largely semantic. Can the agent and the patient be the same and are they both expressed in the subject position? So for example, 'cut' or 'kicked' cannot be ergative because if you take away the subject you end up with either an ellipsis or an intransitive verb. E.g. The knife cut deep. or The mule kicks. You could imagine some metaphorical meanings to include ergativity such as 'The engine kicked into gear.' But it's not clear in this case.
  3. The decision about the subject is also semantic. Can the subject be an agent and patient at the same time? Contrast: 'Mary baked in the kitchen all afternoon.' vs. 'Mary baked in the sun all afternoon.' The first is intransitive use of bake and the second is ergative.
Dominik Lukes
  • 10,588
  • 27
  • 49
  • In (3), I would say that Mary baked in the kitchen all afternoon was a transitive active bake meaning 'produce baked goods', while Mary baked in the sun all afternoon was an intransitive stative/inchoative bake meaning 'rise in internal temperature via conduction from ambient environment'. English already has transitives and intransitives, statives and actives. But no ergative systems. – jlawler Aug 17 '15 at 17:32
    Sure. But this is all debate over terminology. These verbs happen to be called 'ergative verbs' by some people (https://en.wikipedia.org/wiki/Ergative_verb; also see Dixon). As you know, this is annoyingly quite common - the same terms don't refer to the same things in different languages. Even, languages that have the more traditional 'ergative' don't always exactly correspond to each other. Calling these verbs 'ergative' make some sense because of the S/O alignment - but I agree, it is more confusing than helpful. – Dominik Lukes Aug 18 '15 at 04:30
