I would like to play selected audio files through the built-in audio port on a Raspberry 3 that is running Raspbian Stretch Lite, from a python program. Unfortunately, none of the libraries or external applications that I have tried for this purpose work.
sudo pip install pygame
results in
Unable to run "sdl-config". Please make sure a development version of SDL is installed.
and
pip install sdl
fails with
Could not find a version that satisfies the requirement sdl (from versions: ) No matching distribution found for sdl
mplayer won’t install.
mpg321 comes closest, installing but then failing when used, with ALSA lib errors, and you can’t install a new version of alas-utils because
Could not find a version that satisfies the requirement alsa-utils (from versions: ) No matching distribution found for alsa-utils
What do people do to play music on this OS?
jdonald
  • 2,904
  • 39
Michael Stern
  • 115
  • I installed pygame using the command: "$ sudo pip install pygame" without any problem. I got the message "Requirement also satisfied, ...", I am using Rpi3B+ stretch 9 (regular version, not lite version). – tlfong01 Jul 08 '19 at 04:06
  • I also tried to import the pygame module in a python program and run the demo code of analog/digital clock and found everything OK ( https://www.pygame.org/project/994 ). I have not yet try any audio player though. – tlfong01 Jul 08 '19 at 07:56
  • related (if not dupe): https://raspberrypi.stackexchange.com/q/94098/19949 – Ghanima Aug 24 '19 at 09:58
I have just tested it with two favorite programs: omxplayer and mpv. I used a fresh flashed up to date Raspbian Buster Lite but it shouldn't make a difference to Raspbian Stretch Lite. Playing music with this programs works out of the box without an modifications.
For testing first I plugged in a simple earphone into the analog audio output plug of my Raspberry Pi 4B. Then downloaded a test mp3 file from Sample .mp3 download. I selected the smallest one:
rpi ~$ curl https://file-examples.com/wp-content/uploads/2017/11/file_example_MP3_700KB.mp3 > file_example_MP3_700KB.mp3
Then installed omxplayer:
rpi ~$ sudo apt install omxplayer
and played the test file:
rpi ~$ omxplayer file_example_MP3_700KB.mp3
Same with mpv:
rpi ~$ sudo apt install mpv
rpi ~$ mpv file_example_MP3_700KB.mp3
I would prefer omxplayer because it is lighter than mpv and explicitly supports the hardware acceleration of the Raspberry Pi.
Now play it from python3:
rpi ~$ python3
Python 3.7.3 (default, Apr  3 2019, 05:39:12)
[GCC 8.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import os
>>> os.system('/usr/bin/omxplayer /home/pi/file_example_MP3_700KB.mp3')
or playing it in the background:
>>> import subprocess
>>> subprocess.Popen(['/usr/bin/omxplayer', '/home/pi/file_example_MP3_700KB.mp3'])
exit()
rpi ~$    # exit from python3 but still playing
You may have a look at an omxplayer-wrapper. Look at google with python omxplayer-wrapper.
  • 42,107
  • 85
  • 197
How to play audio in Python3 on RaspiOS Bullseye lite (I'd recommend to use the current version) - because VLC supports many audio formats, I use this library.
Install pulseaudio:
sudo apt install alsa-oss libasound2-plugins libavresample4 pulseaudio pulseaudio-utils
Start server:
pulseaudio -D
You can display your audio sinks (outputs) with:
pacmd list-sinks
Playing is possible with pacmd as well but only WAV:
pacmd play-file  <path> <sinkno>
You have to specify the full, absolute path for the file.
Troubleshooting for pulseaudio:
Stopping server:
systemctl --user stop pulseaudio.socket
systemctl --user stop pulseaudio.service
Starting server interactively for output to screen:
pulseaudio -v
VLC: Install necessary parts of VLC:
sudo apt install vlc-bin vlc-plugin-base
Install VLC library for Python:
sudo pip install python-vlc
In Python:
import vlc
p = vlc.MediaPlayer("<audiofile>")
p.play()
Volume can be got and set with:
vlc.libvlc_audio_get_volume(p)
vlc.libvlc_audio_set_volume(p,50)
I hope this answer is helpful.
Additional hint: If you plug in your USB device, this device should be the default for audio output.
