My NetworkManager has suddenly stopped working on my raspberry pi due to which I am unable to connect to it either via putty or http. Configuration: I run a Raspberry Pi 3B+ with Raspbian. It is also running hassio on docker. Everything was running smoothly and I have not make any changes to the Pi. I was only fiddling with my router trying to change some wifi settings and my Pi went incommunicado. When the pi boots up it gives the following error:
NetworkManager has failed to start
journalctl -xe gives the following error:
hassio systemmd[6862]: NetworkManager.service: Failed at step EXEC
spawing /usr/sbin/NetworkManager: Exec format eror
pi@hassio:/usr/sbin $ systemctl status NetworkManager.service
â NetworkManager.service - Network Manager
Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2019-09-08 17:00:35 IST; 18min ago
Docs: man:NetworkManager(8)
Process: 497 ExecStart=/usr/sbin/NetworkManager --no-daemon (code=exited, status=203/EXEC)
Main PID: 497 (code=exited, status=203/EXEC)
CPU: 20ms
Sep 08 17:00:34 hassio systemd[1]: NetworkManager.service: Unit entered failed state.
Sep 08 17:00:34 hassio systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
Sep 08 17:00:35 hassio systemd[1]: NetworkManager.service: Service hold-off time over, scheduling restart.
Sep 08 17:00:35 hassio systemd[1]: Stopped Network Manager.
Sep 08 17:00:35 hassio systemd[1]: NetworkManager.service: Start request repeated too quickly.
Sep 08 17:00:35 hassio systemd[1]: Failed to start Network Manager.
Sep 08 17:00:35 hassio systemd[1]: NetworkManager.service: Unit entered failed state.
Sep 08 17:00:35 hassio systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
pi@hassio:/usr/sbin $ journalctl --boot --unit=NetworkManager.service
-- Logs begin at Thu 2016-11-03 22:46:43 IST, end at Sun 2019-09-08 17:20:01 IST. --
Sep 08 17:00:33 hassio systemd[1]: Starting Network Manager...
Sep 08 17:00:33 hassio systemd[1]: NetworkManager.service: Main process exited, code=exited, status=203/EXEC
Sep 08 17:00:33 hassio systemd[1]: Failed to start Network Manager.
Sep 08 17:00:33 hassio systemd[1]: NetworkManager.service: Unit entered failed state.
Sep 08 17:00:33 hassio systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
Sep 08 17:00:33 hassio systemd[1]: NetworkManager.service: Service hold-off time over, scheduling restart.
Sep 08 17:00:33 hassio systemd[1]: Stopped Network Manager.
It retries a few times and then gives up. Can somebody help me troubleshoot this please. What else would be of value to see in the configs?
file /usr/sbin/NetworkManager, and if it's a script does the text look sane? – jdonald Sep 07 '19 at 19:54systemctl status NetworkManager.serviceandjournalctl --boot --unit=NetworkManager.service– Ingo Sep 08 '19 at 10:05pi@hassio:/usr/sbin $ ls -ltr NetworkManager -rwxr-xr-x 1 root root 2095580 Nov 2 2018 NetworkManager@m , Maybe this error was always there, its just that I noticed it now, so I cant be sure what changed to cause this.
– Vijay Sep 08 '19 at 11:55dhcpcd. – goldilocks Sep 08 '19 at 13:52
