I want to run Raspbian from a USB flash drive on a Raspberry Pi 3B+.
What would be the performance difference in doing so, as compared to running Raspbian from an SD card?
I've been doing it for years and currently have a Pi2, Pi3 and Pi4 booting from external USB HDDs. The main advantages are bigger capacity and reliability, I've found SD cards easily get ruined by power interruptions but not the USB HDDs
Pi4 booting from external USB HDD - please share how you've managed this - is this a recent development (last week or so)
– Jaromanda X
Jan 30 '20 at 03:30
You are using a Raspberry Pi 3B+. This model supports booting from an USB storage device instead of a SD Card out of the box. Just flash the USB flash drive as you do with a SD Card, put it into an USB port and be sure you do not have an SD Card inserted. Otherwise it would boot first from the SD Card. For details look at USB mass storage boot.
The Raspberry Pi 3B + supports USB 2.0 specification which allows for transfer speeds up to 480Mbit/s or 60MByte/s.
USB flash drives can reach up 33MBytes/s, but there seem to be some limitations in the NAND itself so it will come down to the type of stick you get. However, the sd-card bus speed can reach up to 20MB/s read on the raspberry pi. So, the better choice here is a high-class USB 2.0 USB flash drive.
On the other hand, the payment would be concerned. It cost much less to buy USB 2.0 USB flash drive instead of a UHS-3/Class 10 sd-card.
In conclusion, I see a comparatively small benefit in booting from a USB flash stick, the price, and the speed.
Related sources:
Raspberry Pi 3 micro SD card speed
SD Card speed - Pi limitation ?
Max USB stick transfer speed for the pi?
SD Speed Class/UHS Speed Class/Video Speed Class
Finally Switched to SanDisk USB 3.0 Flash Drive.
Thank you guys.
All you have to do is.. Use Etcher to Burn to USB. And Open boot/config.txt and add this line to beginning of the file.
program_usb_boot_mode=1
And save the file. Plug In to Raspberry Pi and Enjoy
