The problem: I am trying to create an AP on a Raspberry Pi 3B (want to later try on a Zero W, too) running buster. I also want to have Internet connectivity to the Pi using my Wi-Fi. I have studied several tutorials such as:
https://thepi.io/how-to-use-your-raspberry-pi-as-a-wireless-access-point/
and others and successfully implemented a solution using eth0. However, what I want is that instead of eth0 the Pi should use wlan1. To this end I looked up various ways of doing using dual Wi-Fi:
https://www.processthings.com/post/66023171876/how-to-connect-your-raspberry-pi-to-two-wi-fi https://www.raspberrypi.org/forums/viewtopic.php?t=49283
I even followed this: https://www.raspberrypi.org/forums/viewtopic.php?t=191453
but I am unable to achieve my objective. Here’s what my files look like
/etc/dhcpcd.conf
interface wlan0
static ip_address=192.168.1.11/24
denyinterfaces eth0
denyinterfaces wlan0
/etc/dnsmasq.conf
interface=wlan0
dhcp-range=192.168.1.21,192.168.1.30,255.255.255.0,24h
/etc/hostapd/hostapd.conf
interface=wlan0
bridge=br0
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
ssid=Hello123
wpa_passphrase=asdasdasd
/etc/default/hostapd
DAEMON_CONF="/etc/hostapd/hostapd.conf"
/etc/network/interfaces
auto lo
iface lo inet loopback
#iface eth0 inet dhcp
auto wlan1
iface wlan1 inet dhcp
wpa-ssid Hello123
wpa-psk asdasdasd
I cannot connect to the net (cannot browse or ping) and ifconfig doesn’t show wlan1 at all.
So, what am I doing wrong? And is it even possible for wlan0 and wlan1 to coexist in this fashion? All the examples using hostapd only show eth0 bridges. In fact, I am OK even if the bridging doesn't happen - I just need the ability to connect to the Pi through AP mode and the Pi should be able to contact a website for data.
