I'm trying to setup a wifi to ethernet bridge on a RPi model 1B (maybe B+, I can't remember) to connect a device with ethernet only to a wifi network. It's a freshly installed system, so latest Raspbian. I have been following the guide posted by Ingo at this address: Workaround for a wifi bridge on a Raspberry Pi with proxy arp (the Static configuration of proxy arp procedue) and I have at least managed to connect the RPi to the wifi (which by the way uses WPA-EAP as authentication method, not WPA-PSK, in case it's relevant) using systemd-networkd, which is already something. However, when I connect the device to RPi's ethernet (first I connect the ethernet cable with the device on, then I switch on the RPi) the device is not getting an IP address. Running journalctl -b -e to get some logs yield this result (hopefully I've cut the log in the right places):
Aug 18 17:57:15 raspberrypi systemd[1]: Starting proxy arp routing service...
Aug 18 17:57:16 raspberrypi echo[631]: systemd-networkd-wait-online: wlan0 is online
Aug 18 17:57:16 raspberrypi kernel: smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Aug 18 17:57:16 raspberrypi systemd-networkd[110]: eth0: Gained carrier
Aug 18 17:57:16 raspberrypi kernel: device wlan0 entered promiscuous mode
Aug 18 17:57:16 raspberrypi systemd[1]: parprouted.service: Can't open PID file /run/parprouted.pid (yet?) after start: No such file or directory
Aug 18 17:57:16 raspberrypi parprouted[640]: Starting.
Aug 18 17:57:16 raspberrypi systemd-networkd[110]: eth0: Lost carrier
Aug 18 17:57:18 raspberrypi systemd-networkd[110]: eth0: Gained IPv6LL
Aug 18 17:57:18 raspberrypi systemd-networkd[110]: eth0: Gained carrier
Aug 18 17:57:18 raspberrypi kernel: smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Aug 18 17:57:46 raspberrypi systemd[1]: parprouted.service: Start operation timed out. Terminating.
Aug 18 17:57:47 raspberrypi parprouted[640]: Received signal; cleaning up.
Aug 18 17:57:47 raspberrypi parprouted[640]: Terminating.
Aug 18 17:57:47 raspberrypi kernel: device wlan0 left promiscuous mode
Aug 18 17:57:47 raspberrypi systemd-networkd[110]: eth0: Lost carrier
Aug 18 17:57:48 raspberrypi kernel: smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Aug 18 17:57:48 raspberrypi systemd[1]: parprouted.service: Failed with result 'timeout'.
Aug 18 17:57:48 raspberrypi systemd[1]: Failed to start proxy arp routing service.
Aug 18 17:57:53 raspberrypi systemd[1]: parprouted.service: Service RestartSec=5s expired, scheduling restart.
Aug 18 17:57:53 raspberrypi systemd[1]: parprouted.service: Scheduled restart job, restart counter is at 5.
Aug 18 17:57:53 raspberrypi systemd[1]: Stopped proxy arp routing service.
and now I'm not sure if this is a hardware limitation of the RPi 1 network card, or if I have made some mistakes somewhere (or if I need to adapt Ingo's guide to my specific hardware). Can anybody suggest something to make this work?
I'm sorry if this looks like a duplicate question - I actually wanted to comment on Ingo's answer but I'm a new user and I don't have the reputation to do that, I can only open a new question.
EDIT:
Following Ingo's request, I'm posting the output of ip addr:
inet6 ::1/128 scope host
link/ether b8:27:eb:43:13:45 brd ff:ff:ff:ff:ff:ff
inet 10.57.109.29/32 scope global eth0
inet6 fe80::ba27:ebff:fe43:1345/64 scope link
3: wlan0: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:19:86:52:00:bd brd ff:ff:ff:ff:ff:ff
inet 10.57.109.29/18 brd 10.57.127.255 scope global dynamic wlan0
valid_lft 43083sec preferred_lft 43083sec
inet6 fe80::219:86ff:fe52:bd/64 scope link
ip addr? – Ingo Aug 18 '20 at 21:32
