I know this is a old topic but even after reading dozens of comments i couldn't solve the problem. With hdmi plugged to raspberry everything is fine. When I don't plug HDMI my resolutioin is too big(in scale automatically vnc option) and small in scale to 100%. I've tried to modify parameters in config.txt but nothing. Maybe there is a conflict between config.txt and something else? I don't know I am a bit ignorant with this.
I try to post my config.txt. my uncommented rows:
*--uncomment to force a console size. By default it will be display's size minus
-- overscan.
framebuffer_width=1920
framebuffer_height=1080
--uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
--uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_foce_mode = 1
#hdmi_group=2
#hdmi_mode=82
dtoverlay=gpio-fan,gpiopin=14,temp=90000*
I also tried to uncomment hdmi parameters. but nothing. What could I do?
Thank you everyone. It's been all day i'm trying to solve this problem
anselboero
I had a similar issue with my raspberry and VNC Viewer. I managed to solve it by setting up the headless resolution to the resolution of my screen (the one I use to connect remotely, which is 1920x1080). Open the main menu (top left)>Preferences>Raspberry Pi Configuration>Display and set your resolution.
It is easier to do it this way with a screen than doing it with raspi-config.
Madho
  • This option is completely ignored for me and the Screen Layout Editor only shows 640x480 as the only option. – ScrappyDev Oct 24 '23 at 01:33
Don't fiddle with framebuffer (which is pointless on a Pi4)
Set the default resolution (preferably while a monitor IS connected) in raspi-config. Then you will have the same resolution whether a monitor is connected or not.
See https://raspberrypi.stackexchange.com/a/113873/8697
