How can I install GCC 4.8 on Raspberry Pi? Do I need to compile it from source? Should I update from Raspbian wheezy to a newer version?
In 2015-02-16-raspbian-wheezy is gcc-4.8 already as package (4.8.2), but not default. You can install it apt-get install gcc-4.8 g++-4.8 and then change the links in /usr/bin/
- 181
- 3
As long as your Raspberry Pi is up to date, then you can just download and patch GCC 4.8 to run on you Raspberry Pi.
Download GCC sources
$ wget ftp://ftp.fu-berlin.de/unix/languages/gcc/snapshots/LATEST-4.8/*.bz2
Extract sources
$ tar xf gcc-4.8-20120826.tar.bz2
Patch sources
We need to get and apply two debian specific patches for GCC:
$ wget http://anonscm.debian.org/viewvc/gcccvs/branches/sid/gcc-4.7/debian/patches/armhf-triplet.diff?view=co -O armhf-triplet.diff $ wget http://anonscm.debian.org/viewvc/gcccvs/branches/sid/gcc-4.7/debian/patches/gcc-multiarch-trunk.diff?view=co -O gcc-multiarch-trunk.diff $ cd gcc-4.8-20120826 $ patch -p2 -i ../armhf-triplet.diff $ patch -p2 -i ../gcc-multiarch-trunk.diff
Note: There will be a failed patch in libgcc, don't worry about it, as it's already been applied to gcc-4.8.
Recreate
.autoconf
files:$ cd gcc $ autoconf2.64 $ cd ../libjava $ autoconf2.64 $ cd ../
Compile and install GCC:
configure
;make
;make install
In case any of these options haven't worked for you (or you're running something newer), you can try this. I'm running Raspian with desktop (without included software) on a Raspberry Pi 4.
I went into /etc/apt/
and modified sources.list
. The second line in my file says:
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
After that, run sudo apt-get update
and sudo apt-get upgrade
, then finally:
sudo apt-get install gcc-4.8
***Side note: If you're also wanting to install g++-4.8 (like I was, for tensorflow), you'll need to add these two lines to your sources.list
file:
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
Again, sudo apt-get update && sudo apt-get upgrade
, and then:
sudo apt-get install g++-4.8
- 184
- 6
I tried the above -- ran into several issues. This might be easier (I'm trying it now):
http://www.raspberrypi.org/phpBB3/viewtopic.php?t=65516&p=481730
- 117
3If you could post the gist of the directions here, that'd be great! It helps prevent link rot if anything ever changes on the linked site. – Fred Mar 30 '14 at 19:37
The downside to this solution is that it forces you to update you ENTIRE system to Debian Jessie. This may very well cause compatibility issues for some users (myself included). – Ponkadoodle Jul 03 '14 at 00:04
In keeping with our policy regarding informationless link-only answers, if this post is not edited to contain information that can stand as an answer, however minimal, in 48 hours it will be converted to Community Wiki to simplify having it corrected by the community. – Ghanima Aug 31 '17 at 19:06
autoconf2.64
do? – HeatfanJohn Dec 18 '13 at 14:20wget ftp://ftp.fu-berlin.de/unix/languages/gcc/snapshots/LATEST-4.8/*.bz2
should do the trick to get their latest build of gcc 4.8. There's also a LATEST-4.9 and LATEST-4.10 folder as well. – Ponkadoodle Jul 02 '14 at 23:50configure; make; make install
commands? Because I'm not seeing any binaries, andgcc --version
still reports 4.6. – Ponkadoodle Jul 03 '14 at 00:36
