I suddenly couldn't wget a file after having gotten one 5 mins before.
I can no longer "ping google.com"
I can "ping 1.1.1.1"
/etc/resolv.conf:
#Generated by resolvconf
nameserver 1.1.1.1
nameserver 8.8.8.8
ifconfig for eth0(which is what I am using):
inet 192.168.0.142 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::15b5:7a2e:8121:e45e prefixlen 64 scopeid 0x20<link>
ether dc:a6:32:43:a3:9b txqueuelen 1000 (Ethernet)
RX packets 11804 bytes 1565414 (1.4 MiB)
TX packets 2577 bytes 301865 (294.7 KiB)
Output from route -n
Kernel IP routing table
0.0.0.0 192.168.0.1 0.0.0.0 UG 202 0 0 eth0
10.6.0.0 0.0.0.0 255.255.255.0 U 0 0 0 wg0
192.168.0.0 0.0.0.0 255.255.255.0 U 202 0 0 eth0
Result from traceroute 1.1.1.1
traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 0.420 ms 0.398 ms 0.369 ms
2 10.200.211.1 (10.200.211.1) 2.708 ms 2.540 ms 2.494 ms
3 192.38.10.89 (192.38.10.89) 21.809 ms 21.779 ms 21.640 ms
4 130.225.245.13 (130.225.245.13) 8.338 ms 8.277 ms 11.434 ms
5 109.105.102.160 (109.105.102.160) 9.342 ms 9.145 ms 9.119 ms
6 109.105.97.117 (109.105.97.117) 8.959 ms 9.468 ms 9.970 ms
7 212.237.193.246 (212.237.193.246) 10.997 ms 212.237.192.246 (212.237.192.246) 11.016 ms 10.305 ms
8 1.1.1.1 (1.1.1.1) 10.643 ms 10.550 ms 9.560 ms
1.1.1.1as your primary DNS? It looks like an odd choice. – Seamus Aug 11 '21 at 20:061.1.1.1is faster than8.8.8.8. I have also tested it with 8.8.8.8 as primary dns – Thomas Nykjær Aug 11 '21 at 20:111.1.1.1is the "cloudFare" DNS. Turning to yourroute -noutput, what iswg0? 2nd Q: Have you made any changes to your/etc/dhcpcd.conffile – Seamus Aug 11 '21 at 20:32/etc/dhcpcd.conffile? – Seamus Aug 12 '21 at 01:57@whatever) for them to get a notification. 2) You should consider usingsystemd-networkdinstead ofdhcpcdto control your network config - due to your non-standard setup. A good how-to is here. – Seamus Aug 13 '21 at 17:37
