This is on a system upgraded from Buster to Bullseye. Ethernet works fine, but WiFi cannot scan for available networks with "No carrier" error message:
pi@raspberrypi:~ $ connmanctl enable wifi
Error wifi: Already enabled
pi@raspberrypi:~ $ connmanctl scan wifi
Error /net/connman/technology/wifi: No carrier
I can see that wlan0 is there, not blocked by rfkill and wpa_supplicant is running.
pi@raspberrypi:~ $ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
pi@raspberrypi:~ $ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
pi@raspberrypi:~ $ systemctl status 579
● dhcpcd.service - dhcpcd on all interfaces
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2021-11-19 16:40:15 CET; 24h ago
Process: 429 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=0/SUCCESS)
Main PID: 489 (dhcpcd)
Tasks: 2 (limit: 4915)
CPU: 34.626s
CGroup: /system.slice/dhcpcd.service
├─489 /sbin/dhcpcd -q -b
└─579 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
Is there anything else I should check? Or is connmanctl not supposed to work on Bullseye?
@Milliways, connman appears to be installed as a dependency of lxde, which is what I have for desktop on the Pi:
pi@raspberrypi:~ $ apt-cache --installed rdepends connman-gtk
connman-gtk
Reverse Depends:
|lxde
piuser is not inwheelandnetworkgroups, but I assumed it's arch-spesific – Dmitry Grigoryev Nov 21 '21 at 11:01connman. I have done updates & fresh install of Bullseye & still havedhcpcd. Neither has connman. I did ask the author of that post, but got no sensible answer. I have seen nothing from RPT suggesting such a change, so I can't explain. The same version was in Buster repositories, and a slightly earlier version in Stretch. If you didn't install it (maybe on the image you updated) it would be interesting to examine the logs. If there was any change in NM I would expectsystemd-networkd. – Milliways Nov 21 '21 at 11:06apt-cache --installed rdepends connman-gtk. What do you have for NM GUI? – Dmitry Grigoryev Nov 21 '21 at 11:13lxde(which is standard desktop environment for PI) Recommends: connman-gtk, which presumably installs connman, so maybe it is a result of installing recommended packages. however it got there connman is incompatible with dhcpcd. If you don't want it I would just delete connman. I note Simon Long's comment that he is the only person supporting lxde. – Milliways Nov 21 '21 at 11:34lxplug-network, and if so, could you help me figure out what am I missing with it? – Dmitry Grigoryev Nov 21 '21 at 17:46The pi user is not in wheel and network groups... Yeah, those groups don't exist in Debian, but they have equivalents:wheel~sudo,network~netdev. I wondered if group memberships were changed during the upgrade? Anyway - from the discussion here, your other question, and this question this seems rather a significant issue! – Seamus Nov 21 '21 at 21:10piuser is still insudoandnetdevgroups, as it was before the update. It's probably a dist-upgrade issue, but I'm essentially OK with command line and don't want to waste another day on either rolling back a buster backup and re-doing the upgrade, or making a fresh install and then going through my bash history and /etc folder for all the changes I have made to my system. – Dmitry Grigoryev Nov 21 '21 at 21:31
