-1
For my final presentation this semester, I have setup a local network using RaspAP on my RPI 4+. I have a websever available locally @ 10.3.141.91 and I would like to assign it a domain name (example.com) so I don't have to type the IP adress. How can I achieve this?
vermar
    Make an entry in /etc/hosts setup DNS? The same way you would do this on any other Linux machine. – Steve Robillard May 28 '22 at 14:46
    Welcome -- you might want to clarify that it is on the Pi that you want to do this, ie., the "local server" is on some other machine that will connect to the Pi AP, and then the Pi will attempt to connect to the webserver on that other machine. If this is not how it is, then explain the details. – goldilocks May 28 '22 at 14:57
  • hello, yes some clarification. The local server is hosted on the RPI. Hopefully clients will connect to the RPI wifi AP and access the webserver not by typing a local IP address (10.3.141.90 but example.com) – vermar May 28 '22 at 19:10
  • RpiOS by default runs an avahi daemon, which implements mDNS. Most personal computers and smartphones also make use of this. Note that Steve's first comment is inapplicable due to your clarification. You should edit it into the question as it still reads like my previous comment. – goldilocks May 29 '22 at 14:06
  • Have you installed dnsmasq on your RPi? If not, how are you providing DNS resolution on your local network? Is your RaspAP part of a local network - or is it on a different network? If you're going to ask network questions, your question must provide some details. Otherwise, your only answer will be to read the "Milliways Network Tutorial". – Seamus May 29 '22 at 17:33
You can connect from most computers on your local network with hostname.local (for most this is raspberrypi.local)
See Connecting a Computer to the Pi in How to set up networking/WiFi
