I want to ssh into the raspberry pi from a mac and be able to run an application with a basic GUI.
SSH is already working and good. I thought it'd just be as simple as ssh -X myusername@mystaticip
Then I could launch my program via the command line and a pretty window would pop up.
Go the tightvnc route? There doesn't seem to be a tightvnc client for mac?
tarabyte
  • 665
To make the answer a little more explicit, here are all the steps I took to get it working:
On the raspberry pi
Install tightvnc server (designed to support lower bandwidth)
sudo apt-get install tightvncserver
Configure vnc desktop with screen resolution and color depth
vncserver :1 -geometry 800x600 -depth 24
On the mac
Enable the native vnc client on the mac:
System Preferences >> Sharing >> Screen Sharing
Open vnc via the terminal (the default port is 5901 I guess)
open vnc://myUsername@rpiIpAddress:5901
Note that you will have to start tightvnc server on the raspberry pi (or ensure that it's running) before you can accept anything on the client side.
On the raspberry pi
tightvncserver
tarabyte
  • 665
  • I have been trying to get this to work for DAYS using both Microsoft RDP and VNC Viewer and I always get a blank black screen and I can't even see lxtask from ctrl+alt+del. For whatever reason, running vnc from command line works. Excellent! – Jacksonkr Feb 16 '15 at 21:58
  • @Jacksonkr its linux, what did you expect? ;) – Martin Pfeffer Jul 10 '17 at 19:10
You can also use xrdp.This tool is easy to use and there are also some clients for mac.
To install on the Raspberry Pi
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install xrdp
on the mac, use this software:
  1. MS-RDP-Client
  2. cord
for german user, there is a tutorial
www.forum-raspberrypi.de/Thread-tutorial-xrdp-remote-desktop-verbindung-windows-android-ios-linux-mac-osx
Phil
You can use any VNC client on the Mac. The easiest is to use OS X Screen Sharing
Enter open vnc://pi@IP:5901 at the terminal prompt.
It is easier if you create shared keys, and put the public key on the Pi.
There is a little setting up for tightvncserver on the Pi to make it easier
