I am doing my NEA project right now and I have a problem using 2 TFT LCD. Here are more details about the LCD 2.8" LCD SPI, Driver: ili9341 with touch version 1.2, this a picture of it: enter image description here
I have connected the first LCD in the following Steps:
Step 1:
I connected the Screen to the GPIO to the following pin diagram:
Display GPIO #
VCC 3.3v
GND gnd
CS 8
RESET 27
DC 22
SDI(MOSI) 10
SCK 11
LED 13
Step 2:
I installed the tft9341 overlay:
git clone https://github.com/goodtft/LCD-show.git
cd LCD-show/
sudo cp ./usr/tft9341-overlay.dtb /boot/overlays/tft9341.dtbo
Step 3:
I updated the /boot/config.txt file
# turns spi on
dtparam=spi=on
# loads tft module for /dev/fb1
#dtoverlay=tft9341:rotate=270
# sets tft backlight pin on
gpio=13=op,dh
# or off at startup
#gpio=13=op,dl
and then restarted the Raspberry Pi and everything was working and the screen was connected to /dev/fb1 and I was able to control the screen with pygame.
Now I want to control the second LCD at the same time.
If someone knows how to help me I would be grateful
MatsK
  • 2,791
here is how I did it that's how I connected the screens to the Raspberry Pi:
Then execute this commands:
sudo pip3 install adafruit-circuitpython-rgb-display
sudo apt-get install fonts-dejavu
sudo apt-get install python3-pil
sudo apt-get install libopenjp2-7 libtiff5 libatlas-base-dev
pip3 install adafruit-blinka
this is for the coding for python Now we need to enable the SPI so to do that we need to execute this command
sudo nano /boot/config.txt
usually this line is commented so uncomment by simply removing the "#" before it enter image description here and add the following line also :
dtoverlay=spi1-1cs
then Ctrl+S and Ctrl+X now if you want to check if everything is fine tell now: execute the following command:
ls -l /dev/spi*
you should see this enter image description here and you can use this code it would work:
import time
import subprocess
import digitalio
import board
import busio
from PIL import Image, ImageDraw, ImageFont
from adafruit_rgb_display import ili9341
cs_pin = digitalio.DigitalInOut(board.CE0) dc_pin = digitalio.DigitalInOut(board.D25) reset_pin = digitalio.DigitalInOut(board.D24) cs_pin1 = digitalio.DigitalInOut(board.D18) dc_pin1 = digitalio.DigitalInOut(board.D26) reset_pin1 = digitalio.DigitalInOut(board.D6)
Config for display baudrate (default max is 24mhz):
BAUDRATE = 24000000
Setup SPI bus using hardware SPI:
spi1 = busio.SPI(board.SCK_1, MOSI=board.MOSI_1, MISO=board.MISO_1) spi = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO) # 0.96" SSD1331 disp = ili9341.ILI9341( spi, rotation=90, # 2.2", 2.4", 2.8", 3.2" ILI9341 cs=cs_pin, dc=dc_pin, rst=reset_pin, baudrate=BAUDRATE, ) disp1 = ili9341.ILI9341( spi1, rotation=90, # 2.2", 2.4", 2.8", 3.2" ILI9341 cs=cs_pin1, dc=dc_pin1, rst=reset_pin1, baudrate=BAUDRATE, )
if disp.rotation % 180 == 90: height = disp.width # we swap height/width to rotate it to landscape! width = disp.height else: width = disp.width # we swap height/width to rotate it to landscape! height = disp.height
image = Image.new("RGB", (width, height))
Get drawing object to draw on image.
draw = ImageDraw.Draw(image)
Draw a black filled box to clear the image.
draw.rectangle((0, 0, width, height), outline=0, fill=(0, 0, 0)) disp.image(image) disp1.image(image)
First define some constants to allow easy positioning of text.
padding = -2 x = 0
font = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf", 24)
while True: # Draw a black filled box to clear the image. draw.rectangle((0, 0, width, height), outline=0, fill=0) cmd = "hostname -I | cut -d' ' -f1" IP = "IP: " + subprocess.check_output(cmd, shell=True).decode("utf-8") cmd = "top -bn1 | grep load | awk '{printf "CPU Load: %.2f", $(NF-2)}'" CPU = subprocess.check_output(cmd, shell=True).decode("utf-8") cmd = "free -m | awk 'NR==2{printf "Mem: %s/%s MB %.2f%%", $3,$2,$3*100/$2 }'" MemUsage = subprocess.check_output(cmd, shell=True).decode("utf-8") cmd = 'df -h | awk '$NF=="/"{printf "Disk: %d/%d GB %s", $3,$2,$5}'' Disk = subprocess.check_output(cmd, shell=True).decode("utf-8") cmd = "cat /sys/class/thermal/thermal_zone0/temp | awk '{printf "CPU Temp: %.1f C", $(NF-0) / 1000}'" # pylint: disable=line-too-long Temp = subprocess.check_output(cmd, shell=True).decode("utf-8")
# Write four lines of text.
y = padding
draw.text((x, y), IP, font=font, fill="#FFFFFF")
y += font.getsize(IP)[1]
draw.text((x, y), CPU, font=font, fill="#FFFF00")
y += font.getsize(CPU)[1]
draw.text((x, y), MemUsage, font=font, fill="#00FF00")
y += font.getsize(MemUsage)[1]
draw.text((x, y), Disk, font=font, fill="#0000FF")
y += font.getsize(Disk)[1]
draw.text((x, y), Temp, font=font, fill="#FF00FF")
# Display image.
disp.image(image)
disp1.image(image)
time.sleep(0.0001)
this only works with the ili9341 driver display i am not aware of how I would do it with a different driver But if you want to find out how to do it I used these websites: -enter link description here -enter link description here -enter link description here Here is a picture of it enter image description here
