29
It seems like Raspbian has not been updated yet to deal with the Heartbleed bug. sudo apt-get update then sudo apt-get upgrade doesn't update anything (this is a system which was freshly updated yesterday so it is all up to date otherwise).
When I do sudo apt-get install openssl it tells me the latest version is installed, while openssl version tells me 1.0.1e is still installed. The first non-vulnerable version of OpenSSL is 1.0.1g, so how do I update to this?
Jamie Bull
  • 1,107
    I just checked my OpenSSl version from raspbian and it uses 0.9.8 which is not vulnerable according to heartbleed.com –  Apr 09 '14 at 19:24
The core affected package is libssl1.0.0, which if you can, just replace with the patched version, restart everything. You can try to download a binary, and manually install an arm-hf, using dpkg with the version 1.0.1e-2+deb7u5 for wheezy.
You can also use the jessie repository, just for this single one time update, which should get you version 1.0.1g-1.
After install and reboot you it is strongly recommended to revoke all keys and certificates and regenerate everything from scratch, using new passwords and vectors.
As of 09/04/2014 the main wheezy repository uses the patched version 1.0.1e-2+deb7u5 and as commented, you can get it like this:
> sudo apt-get update
Which will update the following packages:
libssl1.0.0 openssh-client openssh-server openssl ssh
*Here is how to selectively upgrade certain packages using jessie repository, without completely breaking wheezy, and will install the latest g version
Add the following two lines into /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb http://archive.raspbian.org/raspbian jessie main contrib non-free rpi
You then edit the file /etc/apt/preferences (create the file if doesn't exist) to tell apt in which repositories it should look to do an update. We put jessie on a low priorty so that when you use apt-get update it will ignore jessie and use wheezy repo instead. This is important for the step after this one.
Package: *
Pin: release n=wheezy
Pin-Priority: 900
Package: *
Pin: release n=jessie
Pin-Priority: 300
Package: *
Pin: release o=Raspbian
Pin-Priority: -10
Now, at your free will you can tell apt to use jessie instead.
apt-get update
apt-get -t jessie install openssl libssl1.0.0 openssh-client openssh-server ssh
*An extract from Chapter 6, Raspberry Pi Server Essentials.
Piotr Kula
  • 17,307
  • 104
    Can you show how to use the jessie repository for just one update? – HeatfanJohn Apr 08 '14 at 19:46
  • @HeatfanJohn was your site really hacked or are you just out of ideas for now? – Piotr Kula Apr 08 '14 at 20:13
    Thanks for pointing that out. The hosting company disabled my site a few months ago and my ISP blocks access to the site so I hadn't checked it in some time. I used Google to view the cached content and indeed it looks suspect. Thanks again. Your book looks great, I previewed it on Amazon. – HeatfanJohn Apr 08 '14 at 20:21
    This has been fixed right now, and I updated the raspberry pi with the normal repositories. – gabrign Apr 09 '14 at 08:56
    Yep, this is in the current updates:
    sudo apt-get update sudo apt-get upgrade
    The following packages will be upgraded: libssl1.0.0 openssh-client openssh-server openssl ssh
    – keithl8041 Apr 09 '14 at 09:44
    In my case, the latest version is 1.0.1e-2+rvt+deb7u6. I'm not sure what the rvt portion is, but the deb7u6 indicates to me that it's good. (Posting to help with searches.) – Tim has moved to Codidact Apr 11 '14 at 00:47
