14
I have a number of distros I'm playing with. I label the SD cards, but:
  1. They are in upside down
  2. I'm usually in another room from the RPi
I set up a service in init.d which lets me know via Pushover when my Pi is shutting down or starting up (using the API via curl).
I'd like this to include which distro I'm currently using.
I can see on my latest boot (playing with adafruit Raspbian):
Linux raspberrypi 3.1.9adafruit+ #8 PREEMPT Wed Aug 1 18:02:42 EDT 2012 armv6l
How can I get that information to include in my script?
I installed lsb-release, but that only gives me this:
pi@raspberrypi / $ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux testing/unstable
Release:    testing/unstable
Codename:   n/a
Which would look the same as my regular Raspbian.
In addition, I would probably like to indicate something myself about the particular instance on the SD card (since I'll probably have multiple of the same base distro). Obviously, I can just drop a file in the same place on each SD-card, but is there a convention for where to put that kind of information?
Cade Roux
  • 2,107
  • 27
  • Wow, cool. Can you point on how did you put together that pushover/init.d thing? I'll ask a question if you'll answer it :) – Zlatko Aug 09 '12 at 07:05
  • @zladuric Sign up at pushover.net for an account. The curl API is pretty simple. I set up a simple script in init.d as a "service" and it simply sends different notifications on start/stop. Technically it's a start stop notification, so if it ever gets "start" it will send a notification. In practice, nothing starts or stops them except boot and shutdown. If you want the full code, go ahead and post a question. – Cade Roux Aug 09 '12 at 13:40
  • here is the question: http://raspberrypi.stackexchange.com/questions/1531/how-to-set-up-pushover-service-to-tell-me-when-my-pi-is-shutting-down-or-startin :) – Zlatko Aug 10 '12 at 06:59
Try
cat /etc/*-release
On my desktop, it gives
NAME="Arch Linux"
ID=arch
PRETTY_NAME="Arch Linux"
ANSI_COLOR="0;36"
HOME_URL="https://www.archlinux.org/"
SUPPORT_URL="https://bbs.archlinux.org/"
BUG_REPORT_URL="https://bugs.archlinux.org/"
Having checked the official Raspberry Pi images (Raspbian and Arch), /etc/os-release is available on both and contains at least the NAME and PRETTY_NAME properties.
How do I extract the distribution's name?
That's quite simple, try
$ cat /etc/os-release | perl -n -e '/^NAME=\"([a-zA-Z ]*)\"$/ && print "$1\n"'
Arch Linux
  1. HowTo: Find Out My Linux Distribution Name and Version
Alex Chamberlain
  • 15,530
  • 67
  • 113
  • Looks good. Ultimately it doesn't matter if this is truly universal, as long as it works for the distros in question. And it would be easy to put one's own file on the filesystem if experimenting with one that doesn't have it by default. – Chris Stratton Aug 09 '12 at 13:06
$ uname -a
Linux raspberrypi 3.1.9+ #174 PREEMPT Sun Jul 22 19:04:28 BST 2012 armv6l GNU/Linux
John La Rooy
  • 11,947
  • 47
  • 75
As pointed out, you can use uname, but this will only show the kernel version. If you have the same kernel version on a couple of different distributions/cards (which is very likely since a couple of them are using the same foundation kernel), you will get the same result for each of them. So the best way to differentiate between distros is to use something other than the kernel. There is no universal way however. One easy way would be to use the hostname (and change it for every distro).
cat /proc/version /proc/sys/kernel/hostname
or
hostname && uname -a
tlhIngan
  • 3,372
Krzysztof Adamski
  • 9,615
  • 37
  • 53
