I use the Raspian Wheezy image on my Pi and I'm facing a small problem regarding the hdmi-output. Usually, I have to "plug in" the hdmi-cable (4:1 hdmi switch) and then the Pi to get a video signal to the TV.
Is there a possibility to start the desktop from ssh when the to cable is plugged in after the Pi's boot?
Just to point this out, I'm not looking for a desktop-client like VNC or xrdp, I'm just searching for a solution to fix my problem. What I already tried:
# export DISPLAY=:0.0
# startx
which resulted in
FATAL: Module g2d_23 not found.
michaeln
  • 131
  • It is unclear exactly what you are asking. Do you want to use hdmi, even if not initially connected? I can think of at least 3 other interpretations of your question. – Milliways May 16 '14 at 00:24
  • Yes, that's what I was trying to point out. I want to boot up my Pi, plug in the hdmi and then start the desktop-server from remote. – michaeln May 16 '14 at 14:48
  • Editing my config.txt did change it to the required behaviour. If you could answer my question with this link or close it as a duplicate, I would accept it as the correct answer for future searches. – michaeln May 17 '14 at 15:40
0 Answers0
