I'm running Arch, and when I shut down with the poweroff command (or with shutdown -h now) the 3 LEDs mentioned stay on. In addition, if I've plugged it into a screen, it displays
> POWER OFF
System halted
but doesn't actually power off - this text, along with the normal shutdown text, remains on the screen, and text I type on the keyboard still appears.
I assume that this means it isn't shutting down correctly, so what should I do to fix it? I've tried dd-ing over again, and the problem has persisted.
If it makes a difference, the last message printed before it claims to power off is Remounting Root Filesystem Read-only. I'm not sure if this is what it's supposed to do or not.
This is happening on a card where I've just dd'ed the .img I downloaded from the Raspberry Pi website, and it has persisted after copying the image again. It works fine in every other way that I've tried, and it boots up fine!
Sorry for only adding 1 tag - I couldn't find anything else appropriate!
EDIT: It seems to shutdown properly under the Debian image, so is this an arch problem rather than a raspberry problem?
Remounting Root Filesystem Read-only), so your data's safe. – scruss Sep 01 '12 at 11:56
