43
Has anyone done some web server benchmarking on their Raspi? I don't have my Raspi yet but I'm planning on using it as a web server and I'm interested to see stats for:
  • Number of requests per second
  • Latency response time between requests
  • Throughput (i.e. bytes per second)
If these are different for different web server software and OS combinations I'd also be interested to see a comparison.
Alex L
  • 7,605
  • 53
ToniWidmo
  • 753
    Can the vote to close please explain why? This is an objective question with an objective measurable answer. – ToniWidmo Jun 13 '12 at 10:44
    I can't answer authoritatively, but I reckon the fastest web servers in general are going to be the fastest on the RPi. My preference, Nginx. – Alex Chamberlain Jun 13 '12 at 11:07
  • @AlexChamberlain Thanks, useful to know, but I'd still be interested in seeing the kind of performance I can get from the device so I don't plan using it for a project beyond its capabilities... – ToniWidmo Jun 13 '12 at 11:09
  • See this page: https://cheapskatesguide.org/articles/raspberry-pi-webserver.html. The first part of the article talks about performance with a Lighttpd webserver. – anon May 03 '20 at 18:06
I expect that, as Alex says, the benchmarks will show that the fastest Linux webservers will still be the fastest, regardless of architecture.
If anyone wants to run benchmarks then the following tutorial has been useful to me:
How to perform benchmarks on a web-server
Serving Static Pages
I have tested the RPi using Apache serving a simple static page:
<h1>It works!</h1>
As a control group I used my primary webserver which totes the following spec;
Intel(R) Xeon(R) CPU           X3323  @ 2.50GHz
384MB RAM
The results are as follows:
Control
ab -n 1000 -c 5 http://www.ivings.org.uk/~james/index.html
Server Software:        Apache/2.2.14
Server Hostname:        www.ivings.org.uk
Server Port:            80
Document Path:          /~james/index.html
Document Length:        19 bytes
Concurrency Level:      5
Time taken for tests:   17.767 seconds
Complete requests:      1000
Failed requests:        0
Write errors:           0
Total transferred:      294000 bytes
HTML transferred:       19000 bytes
Requests per second:    56.29 [#/sec] (mean)
Time per request:       88.833 [ms] (mean)
Time per request:       17.767 [ms] (mean, across all concurrent requests)
Transfer rate:          16.16 [Kbytes/sec] received
Connection Times (ms)
              min  mean[+/-sd] median   max
Connect:       42   44   0.8     44      50
Processing:    44   45   0.9     45      59
Waiting:       44   45   0.9     45      59
Total:         86   89   1.3     88     108
Percentage of the requests served within a certain time (ms)
  50%     88
  66%     89
  75%     89
  80%     89
  90%     90
  95%     91
  98%     91
  99%     94
 100%    108 (longest request)
Raspberry Pi
ab -n 1000 -c 5 http://86.137.189.68/index.html
Server Software:        Apache/2.2.22
Server Hostname:        86.137.189.68
Server Port:            80
Document Path:          /index.html
Time taken for tests:   23.186 seconds
Failed requests:        0
Write errors:           0
Total transferred:      304000 bytes
Requests per second:    43.13 [#/sec] (mean)
Time per request:       115.930 [ms] (mean)
Time per request:       23.186 [ms] (mean, across all concurrent requests)
Transfer rate:          12.80 [Kbytes/sec] received
Connect:       40   44   5.6     43     116
Processing:    49   71 156.1     57    2157
Waiting:       47   53   6.7     55     104
Total:         91  116 156.1     99    2198
  50%     99
  66%    100
  75%    100
  80%    100
  90%    102
  95%    126
  98%    150
  99%    667
 100%   2198 (longest request)
Conclusion
Note: This is best treated as an estimate.
The results show that the Raspberry Pi actually performed damn well considering. It was only slightly less responsive than my primary webserver.
It should be fine handling a reasonably large number of requests.
Jivings
  • 22,538
  • 90
  • 139
  • That may be so, but what kind of performance can the fastest produce? I think you have both misunderstood what I'm trying to ask... – ToniWidmo Jun 13 '12 at 11:31
    I will perform some benchmarks on apache and get back to you. – Jivings Jun 13 '12 at 11:32
  • Thanks. I apologise if my question wasn't clear. Perhaps I muddied the water asking for comparison, when really stats for a standard LAMP stack was my main interest. – ToniWidmo Jun 13 '12 at 12:05
    The "A" in LAMP stands for the Apache HTTP server... – Roger Dahl Oct 02 '12 at 23:18
  • @RogerDahl: Yes it does. Why did you say that? – Jivings Oct 03 '12 at 07:20
    @Jivings: It was a comment meant for the OP. In the initial comment to your post, he indicated that he's interested in finding the performance of the fastest http server and seemed unhappy with your Apache based benchmark. Then he went on to implicitly ask for an Apache benchmark (the "A" in LAMP). – Roger Dahl Oct 03 '12 at 13:17
  • interesting. a "pie farm" might be a very cost effective server solution. – i put on my robe an wizard hat Jan 19 '13 at 17:15
  • @Jivings I see a public IP address on the Pi, but I doubt that your server and Pi have the same fast network connection. Are you able to conduct the experiment in a LAN? Can you test this with access logs disabled (or at least to tmpfs). Without access logs disabled, your results will be greatly influenced by the speed of your SD card. – Lekensteyn May 11 '13 at 08:43
  • @Lekensteyn These are good points. If I get a chance I will redo the experiment. – Jivings May 14 '13 at 08:43
Apache is not the best choice when serving static content, nginx is better suited for that. I did a benchmark using http://lekensteyn.nl/index.html as test document. It is a larger document than Jiving's example since 19 bytes is not realistic for an actual page. The results are quite amazing, the RPi even outperforms my work laptop (maybe because I have all kinds of kernel debugging switches enabled).
Here is nginx 1.4.1 running on Arch Linux (RPi, access_log off, wired ethernet):
$ ab -n 1000 -c 5 http://192.168.2.10/index.html
Server Software:        nginx/1.4.1
Server Hostname:        192.168.2.10
Server Port:            80
Document Length:        2159 bytes
Time taken for tests:   2.341 seconds
Failed requests:        0
Write errors:           0
Total transferred:      2392000 bytes
HTML transferred:       2159000 bytes
Requests per second:    427.18 [#/sec] (mean)
Time per request:       11.705 [ms] (mean)
Time per request:       2.341 [ms] (mean, across all concurrent requests)
Transfer rate:          997.86 [Kbytes/sec] received
Connect:        0    1   0.1      1       1
Processing:     4   11   1.0     11      20
Waiting:        3   11   1.0     10      19
Total:          4   12   1.0     12      21
  50%     12
  66%     12
  75%     12
  80%     12
  90%     12
  95%     12
  98%     17
  99%     18
 100%     21 (longest request)
This is my laptop (access_log off, wired ethernet):
Server Hostname:        192.168.2.12
Server Port:            80
Time taken for tests:   2.593 seconds
Failed requests:        0
Write errors:           0
Requests per second:    385.62 [#/sec] (mean)
Time per request:       12.966 [ms] (mean)
Time per request:       2.593 [ms] (mean, across all concurrent requests)
Transfer rate:          900.79 [Kbytes/sec] received
Connect:        2    6   3.4      5      82
Processing:     3    7   5.6      6      86
Waiting:        3    7   5.5      5      82
Total:          6   13   6.8     12      94
  50%     12
  66%     13
  75%     14
  80%     15
  90%     17
  95%     19
  98%     24
  99%     34
 100%     94 (longest request)
For completeness, my remote server. It is slower with the WAN connection being the likely bottleneck (access_log is not off either):
Server Software:        nginx/1.2.8
Server Hostname:        lekensteyn.nl
Server Port:            80
Time taken for tests:   11.074 seconds
Failed requests:        0
Write errors:           0
Total transferred:      2370000 bytes
Requests per second:    90.30 [#/sec] (mean)
Time per request:       55.371 [ms] (mean)
Time per request:       11.074 [ms] (mean, across all concurrent requests)
Transfer rate:          209.00 [Kbytes/sec] received
Connect:       25   27   2.3     26      59
Processing:    28   29   2.3     28      59
Waiting:       26   27   2.4     27      59
Total:         53   55   3.8     55     102
  50%     55
  66%     55
  75%     55
  80%     55
  90%     56
  95%     57
  98%     59
  99%     86
 100%    102 (longest request)
With more concurrency and higher requests count, the numbers should be more reliable as more samples can be included (when I ran ab against my laptop in wires/wireless mode, its numbers fluctuated highly). Note that when testing with access logs on, that file system buffers cause unpredictable write delays when the log directory is on the SD card.
Lekensteyn
  • 1,501
