I got my RPi a few days ago and I feel rather useless. This is for the very simple reason that I have yet to even be able to ssh into my pi. In other words, I have not logged into it, and I have not accessed it. I am trying to remotely connect to my Pi through my wireless laptop with an RJ-45 Ethernet Cable. I'm currently running Ubuntu 14.04 LTS and my pi is using Raspbian. The SD card I'm using is 8 GB. Whenever I attempt to ping it using nmap, it doesn't show up. (Also, I'm using a Model B Pi.) Any help would be appreciated., thanks. -Omega Emrys
PS: I know what the search bar is, don't tell me to use it please.
I finally found my pi's ip, except I'm not sure it's the right ip. Here is my ifconfig:
eth0 Link
encap:Ethernet
HWaddr 14:da:e9:51:d5:06
inet addr:169.254.8.18
Bcast:169.254.255.255 Mask:255.255.0.0
inet6 addr: fe80::16da:e9ff:fe51:d506/64
Scope:Link
RX packets:28 errors:0 dropped:0 overruns:0 frame:0
TX packets:2976 errors:0 dropped:0 overruns:0 carrier:19
collisions:0 txqueuelen:1000
RX bytes:9576 (9.5 KB) TX bytes:348018 (348.0 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:17547 errors:0 dropped:0 overruns:0 frame:0
TX packets:17547 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1701463 (1.7 MB) TX bytes:1701463 (1.7 MB)
wlan0 Link encap:Ethernet HWaddr 40:25:c2:51:3c:a4
inet addr:192.168.1.41 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::4225:c2ff:fe51:3ca4/64 Scope:Link
RX packets:719321 errors:0 dropped:0 overruns:0 frame:0
TX packets:377846 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1041273963 (1.0 GB) TX bytes:32401705 (32.4 MB)
wmx0 Link encap:Ethernet HWaddr 64:d4:da:5c:fc:92
UP NOARP MTU:1400 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:20
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
When I disconnect the Ethernet cable, the inet address at the very top disappears. However, when I try to nmap -sn the ip, it doesn't refer to the host as raspberry pi. Also, I do manage to ssh into it but when it ask me for the password and I enter "raspberry", it denies me permission, any help you could give me would be wonderful. Thank you very much, Omega.
(EDIT: It just changed the inet address to 10.42.0.1 after I unplugged and plugged the Ethernet a couple of times, which I'm guessing suggest that it is dhcp?)
(EDIT: I did as was suggested by Wilf, and this is what I got:
Nmap scan report for 10.42.0.1
Host is up (0.00012s latency).
Not shown: 998 closed ports
PORT STATE SERVICE VERSION
22/tcp open ssh (protocol 2.0)
| ssh-hostkey: 1024 25:d9:6c:8c:0c:3b:b6:3e:be:a7:f6:cc:9b:6b:87:70 (DSA)
| 2048 96:a3:fe:bc:27:c8:79:45:b5:a0:a1:d7:d0:1f:97:35 (RSA)
|_256 0d:77:5a:d0:6b:ae:04:00:6a:68:1a:17:b5:57:9f:31 (ECDSA)
53/tcp open domain dnsmasq 2.68
| dns-nsid:
|_ bind.version: dnsmasq-2.68
1 service unrecognized despite returning data. If you know the service/version, please submit the following fingerprint at http://www.insecure.org/cgi-bin/servicefp-submit.cgi :
SF-Port22-TCP:V=6.40%I=7%D=7/20%Time=53CBCF84%P=x86_64-pc-linux-gnu%r(NULL
SF:,29,"SSH-2\.0-OpenSSH_6\.6\.1p1\x20Ubuntu-2ubuntu2\r\n");
No exact OS matches for host
TCP/IP fingerprint:
OS:SCAN(V=6.40%E=4%D=7/20%OT=22%CT=1%CU=43809%PV=Y%DS=0%DC=L%G=Y%TM=53CBCF9
OS:3%P=x86_64-pc-linux-gnu)SEQ(SP=104%GCD=1%ISR=109%TI=Z%CI=I%TS=8)SEQ(SP=1
OS:04%GCD=1%ISR=109%TI=Z%CI=I%II=I%TS=8)OPS(O1=MFFD7ST11NW7%O2=MFFD7ST11NW7
OS:%O3=MFFD7NNT11NW7%O4=MFFD7ST11NW7%O5=MFFD7ST11NW7%O6=MFFD7ST11)WIN(W1=AA
OS:AA%W2=AAAA%W3=AAAA%W4=AAAA%W5=AAAA%W6=AAAA)ECN(R=Y%DF=Y%T=40%W=AAAA%O=MF
OS:FD7NNSNW7%CC=Y%Q=)T1(R=Y%DF=Y%T=40%S=O%A=S+%F=AS%RD=0%Q=)T2(R=N)T3(R=N)T
OS:4(R=Y%DF=Y%T=40%W=0%S=A%A=Z%F=R%O=%RD=0%Q=)T5(R=Y%DF=Y%T=40%W=0%S=Z%A=S+
OS:%F=AR%O=%RD=0%Q=)T6(R=Y%DF=Y%T=40%W=0%S=A%A=Z%F=R%O=%RD=0%Q=)T7(R=Y%DF=Y
OS:%T=40%W=0%S=Z%A=S+%F=AR%O=%RD=0%Q=)U1(R=Y%DF=N%T=40%IPL=164%UN=0%RIPL=G%
OS:RID=G%RIPCK=G%RUCK=G%RUD=G)IE(R=Y%DFI=N%T=40%CD=S)
Network Distance: 0 hops
OS and Service detection performed.
Nmap done: 1 IP address (1 host up) scanned in 23.92 seconds)
re (EDIT: Yes, the lights are lit up. FDK is Green LNK is Green, and 100 is yellow. ACT is the only one not lit up at the moment.)
(EDIT: Device Hardware Address: 14:DA:E9:51:D5:06)
ssh pi@10.42.0.1(or whatever the ip is now...) – Daniel Jul 17 '14 at 14:52nmap -O IPADDRESS(might be the-Aoption instead of-0, can never remember), do you get anything referencing to the 'Raspberry Pi Foundation'? You can also check a range of IP addresses - e.g.nmap -O 192.168.1.1-20. – Wilf Jul 20 '14 at 11:05MAC Address: B8:27:EB:0F:E7:65 (Raspberry Pi Foundation). If all the IP addresses on your network have the same prefixes (e.g.192.168.1.) , you should be able to check multiple ones usingnmap -O 192.168.1.1-20, where the last entry specifies the range to check. This also depends on whether the Pi is connected to the internet correctly at all - are the ethernet lights lit up? – Wilf Jul 20 '14 at 15:33
