I often SSH into my Raspberry Pi, which is connected to my network via a wired connection. The last time I tried to reboot it, though, it failed:
pi@raspberrypi ~ $ shutdown now -bash: /sbin/shutdown: cannot execute binary file
pi@raspberrypi ~ $ sudo shutdown now /sbin/shutdown: 1: /sbin shutdown: Syntax error: word unexpected (expecting ")")
I am currently running Raspbian.
Could the files be corrupted? How can I now safely restart it? Will I just have to power cycle it? Last time I did so, I had to reinstall the OS to get it to start up.
PitaJ
  • 211
The correct syntax to power off are:
sudo shutdown -h now
sudo halt
And for reboot:
sudo shutdown -r now
sudo reboot
Be sure you use either sudo or logged as root himself.
Ghanima
  • 15,855
  • 119
Willian Paixao
  • 352
I think the files are corrupted. Just reinstall Raspbian. (You can backup your files before doing that, if you rpi is still running)
You could try the:
sudo reboot
or
sudo poweroff
Commands
