I am trying to detect if a PiTFT screen is connected.
Is there some kind of GPIO pin I can probe and detect it to some extent?
Steve Robillard
  • 34,687
  • 103
  • 109
GuySoft
  • 895
    Other than printing message and asking the operator to press a button if he could read it ;) But I'd assume that the controller attached to the Pi by a serial interface has to report in somehow. After all there is a touchpanel and those values have to be sent to the Pi? The documentation at the given link is however quite scarce. – Ghanima Sep 14 '14 at 15:32
    @Ghanima You can't just print a message, because setup requires in some cases to re-flash the firmware of the pi. I am building a distro and I want it to support multiple screens – GuySoft Sep 16 '14 at 11:04
  • Sure, the first part of that comment was a little less serios. My question being that a display-touchpanel combination got to have a bi-directional interface. Thus the Pi should be able to send something and get some response... or at least that was what I hoped. – Ghanima Sep 16 '14 at 19:49
Old question, answering for someone else who might need it... Full disclaimer - this is what I collected in the last couple of days researching a different topic - there are might be better ways. That said, it seems there are at least a few possibilities for detecting a TFT screen. For one, you can query the device tree as described here:
$ cat /proc/device-tree/hat/product
PiTFT 2.2inch without Touchscreen (ILI9340)
You can also see if the backlight device is registered (found here):
$ sudo find /sys/ -type f -iname '*brightness*' | grep 'led'
/sys/devices/platform/soc/soc:leds/leds/led0/brightness
/sys/devices/platform/soc/soc:leds/leds/led0/max_brightness
Or read the status of the backlight led directly (will be 0 if off):
 $ gpio  read 18
You can also check if there is more than one framebuffer (TFT runs on fb1 unless you have more than one monitor):
$ ls /sys/class/graphics/
fb0  fb1  fbcon
You can probably also talk directly to the TFT controller, but the options above seem simpler.
Maksym
  • 131
