After installing node.js on a playground raspberry pi, i'm able to run node.js scripts.
Now i had a folder which a packages.config which contains a dependency to express.js
when running
npm install
i see that the packages are downloaded. but later on the procesessing failes due to write problems.
on the folder i've set some time ago
chmod 0777
I also have to mention that i copied the node.js application folder from a windows pc via samba to this public shared folder
Also clearing the npm cache didn't help
what am i doing wrong?
here the output when i type npm install express
npm WARN package.json SerialReader@0.0.0 No repository field.
npm http GET https://registry.npmjs.org/express
npm http 200 https://registry.npmjs.org/express
npm http GET https://registry.npmjs.org/express/-/express-4.11.0.tgz
npm http 200 https://registry.npmjs.org/express/-/express-4.11.0.tgz
npm ERR! error rolling back Error: EACCES, unlink '/be/Serial/node_modules/express'
npm ERR! error rolling back express@4.11.0 { [Error: EACCES, unlink '/be/Serial/node_modules/express']
npm ERR! error rolling back errno: 3,
npm ERR! error rolling back code: 'EACCES',
npm ERR! error rolling back path: '/be/Serial/node_modules/express' }
npm ERR! Error: EACCES, unlink '/be/Serial/node_modules/express'
npm ERR! { [Error: EACCES, unlink '/be/Serial/node_modules/express']
npm ERR! errno: 3,
npm ERR! code: 'EACCES',
npm ERR! path: '/be/Serial/node_modules/express' }
npm ERR!
npm ERR! Please try running this command again as root/Administrator.
npm ERR! System Linux 3.12.35+
npm ERR! command "/opt/node-v0.10.28-linux-arm-pi/bin/node" "/opt/node-v0.10.28-linux-arm-pi/bin/npm" "install" "express"
npm ERR! cwd /be/Serial
npm ERR! node -v v0.10.28
npm ERR! npm -v 1.4.9
npm ERR! path /be/Serial/node_modules/express
npm ERR! code EACCES
npm ERR! errno 3
npm ERR! stack Error: EACCES, unlink '/be/Serial/node_modules/express'
npm ERR! Error: EACCES, open 'npm-debug.log'
npm ERR! { [Error: EACCES, open 'npm-debug.log'] errno: 3, code: 'EACCES', path: 'npm-debug.log' }
npm ERR!
npm ERR! path npm-debug.log
npm ERR! errno 3
npm ERR! stack Error: EACCES, open 'npm-debug.log'
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /be/Serial/npm-debug.log
npm ERR! not ok code 0
