I'm new to RPI and to Python 3 and I have a problem running this code on a RPI 2.
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
redled = 4
greenled = 26
GPIO.setup(redled, GPIO.OUT)
GPIO.setup(greenled, GPIO.OUT)
count = 1
while count < 100000:
    GPIO.output(redled, 1)
    GPIO.output(greenled, 1)
    time.sleep(.1)
    GPIO.output(redled, 0)
    GPIO.output(greenled, 0)
    time.sleep(.1)
    count = count + 1
GPIO.cleanup()
I get this error.
Traceback (most recent call last): File "/home/pi/testreactionrepeat.py", line 7, in GPIO.setup(redled, GPIO.OUT) RuntimeError: No access to /dev/mem. Try running as root!
I was using this code with no problems a couple of days ago and can't figure out what I'm doing wrong now. I found a similar problem and the answer was to run "sudo su" but I get a syntax error when I try that.
Let's assume that your program is called
program.py
Open terminal and type
sudo python program.py
This will run your python program as root giving it the necessary permissions to access/modify the GPIO pins.
evolutionizer
  • 296
  • I get this when I type sudo python reactionrepeat.py into terminal. Traceback (most recent call last): File "reactionrepeat.py", line 3, in GPIO.setmode(GPIO.BCM) AttributeError: 'module' object has no attribute 'setmode' – nashville_bill Aug 21 '15 at 11:07
  • can you run "sudo apt-get update && sudo apt-get upgrade" in terminal, this will update your system with the latest software and hopefully with the latest RPi.GPIO modules and thuis fix this issue. – evolutionizer Aug 21 '15 at 11:33
  • I did the update/upgrade, and it appeared to go well. However, my code still won't run, even though it ran just fine a couple of days before I had the problem. I still get the same messages as before when I run the program and when I type in sudo python reactionrepeat.py. Could this be a hardware problem? – nashville_bill Aug 21 '15 at 21:53
  • @nashville_bill no this is definitely a software problem. Are you on the latest raspbian OS? – evolutionizer Aug 22 '15 at 03:22
  • I'm getting this experience with Ubuntu Mate 15.10 when trying to use dot3k. –  Mar 20 '16 at 17:10
  • @mjwittering can you please post the exact error that you are facing – evolutionizer Mar 21 '16 at 18:12
  • @evolutionizer the error I had was: "No access to /dev/mem. Try running as root!"
    The answer regarding permissions by Joan on this page resolved my issues: http://raspberrypi.stackexchange.com/questions/40105/access-gpio-pins-without-root-no-access-to-dev-mem-try-running-as-root.
    –  Mar 22 '16 at 12:19
